ACCO Electric 525 hole punch
How to remove jamed paper and where is the switch
3 Suggested Answers
  • 7 Answers
SOURCE: Broken electric 3-hole punch
There are two phillips screws in the bottom. Once they are removed, the top and bottom of the case are held together with clips molded into the case. Take a wide flat screwdriver and place it in the seam and gently pry it apart. Might want to start on the back in case you ****** up the plastic.
Posted on Oct 25, 2009
  • 32 Answers
SOURCE: Swingline Model 525 electric 3 hole punch
It has a safety switch. This switch turns machine on when it detects paper and off if it doesn't. Something wrong with sensor. Broken, paper stuck under it, out of position. Will have to open it up and check the sensor. ***Always remember to unplug any equipment before working on it***
Posted on May 09, 2010
Swingline 74030 manual hole punch handle is locked down
by locked down I am going to assume you mean it will not go back to the normal postion when it is not making a hole. this can be caused by too many of the scrap pieces of paper that are left from making the hole. clogging the punch area. remove all the excess pieces of paper that may be stuck in the whole punch, then try again, you may have to pry the handle and or push and pull it until it releases. do not use again until the handle moves smoothly, clean the areas around the punch.
Mar 07, 2014 | Swingline 74030 Manual Hole Punch SWI74030
Bindmate GBC has paper stuck
Pull out the papers slowly one by one starting from the page on top. They'll probably rip but it's the only way I've found to get them out (I've tried unscrewing the covers but the thing doesn't pop out). For the next usage only punch a max of 4 pages.
Oct 18, 2013 | Acco Brands Corporation GBC BindMate...
My hole punch won't release the paper. I have to jiggle it before it finally releases.
You are stacking too many sheets of paper. Reduce the thickness of the stack. Think of all the time wasted while trying to the paper released. Sometimes the holes punched may be ripped.
Aug 22, 2013 | Sparco High Volume Electric Three-Hole...
Jammed the machine too many papers. how can i get it unjammed
Unplug the unit ! Remove the cover if possible then carefully use pliers or vise grips to turn the gears that drive the punch cam backwards to get the paper out.
Dec 17, 2010 | Gbc ® 24-Sheet 3230ST Electric Two- and...
Apr 18, 2010 | Office Equipment & Supplies
RZ 220 Risograph error code A-16-525 after paper jam indication. No jam was present.
The master is stucked on the print drum,open print drum remove master and try again.
Let me know for futher help.
Jan 26, 2009 | Riso RZ220 Duplicator
Jan 22, 2009 | Office Equipment & Supplies
69 people viewed this question
k24674
