Question about Agri-Fab Agri - Fab Snow Blower - 42"
Craftsman snow thrower won't self propel
Have changed belts and friction wheel but unit refuses to drive in either forward or reverse. wheels will turn slightly when unit raised off floor but when pressure is added nothing turns
    Top Expert:
  • Agri-Fab Master
  • 2,931 Answers
Have you also changed the drive pulley? It is probably worn out of specification.
I recommend that you contact your nearest authorized service center.
I trust this information proves useful.
craftsman snow thrower won't self propel - helpful-uszrzov2vpx0k2p2rdejuao1-1-0_3.png
Posted on Feb 14, 2018
2 Suggested Answers
  • 16 Answers
SOURCE: CRAFTSMAN SNOW THROWER DRIVE WHEELS WILL NOT MOVE
well if it is a walk behind style it could be the drive is out of adjustment, also craftsman were famous for the cable mounts bending and that will throw them out of adjustment. follow the traction drive linkage down to the base of the blowe and there should be an adjustment, or it will be under the belt gaurd or even on the handle on some.
Posted on Feb 04, 2010
Snow blower runs and auger/ blade rotates but the wheels Anne not rotating. 2- stage Aries 5520. Not sure if the thrower piece is rotating. Any answers for getting wheel moving/ working
Most self propelled units have 2 belts. One for the auger, and one to power the wheels. Check the belts, and then check the drive assembly under the motor to see if it is engaging.
Dec 03, 2016 | Garden
Replace friction wheel in a snowthrower
it looks to me the only special tool needed would be
spring ring pliers.
just removing nuts or blots on the left side and spring clips on both slide axle out pull wheel over bearing then reverse put together
Feb 03, 2014 | Garden
Yardman snowblower won't self-propel
Do not start to do this but put the blower in gear like you would run to drive its self and try to turn the wheels by hand and if they turn easily then you may have a shear pin that is broken or missing in the drive pulley.
Just a thought.
Dec 12, 2013 | Yardman Yard-Man 31AH65LG701 357cc Gas...
Self propell wont work
check belts and tension
and drive wheel
Dec 29, 2012 | Craftsman Sears Snow Thrower Manual Model...
Snow thrower is self propelled. was working fine then stalled
check the bearings in the auger sounds like the froze up and now they need to be replaced (the smoking you saw was from the belts slipping on the pullies)..good luck
Feb 26, 2010 | Craftsman 16" High Garden Tractor Snow and...
Craftsman snow blower wheels wont move. Help!
If it is a 5.5 HP dual stage, like mine, it could be that the belt has popped off the friction pulley. If you drain the gas, tip the unit on its "face" and remove the large shield on the bottom you will see a 3" pulley attached to the drive shaft. There will also be what looks like a fan belt floating around in there. That fan belt nees to go on the pullet, as it serves as the friction disk tio drive the wheels. Good luck. this happens to mine ALL the time. very frustrating. :(
Jan 19, 2010 | Sport & Outdoor - Others
Self propel won't allow the mower to back up freely. works fine moving forward.
either the wire going to the transmission is not tight enough and need adjustment or belt needs replaceing
May 26, 2009 | Mtd 22" White Outdoor Self Propelled High...
SNOW BLOWER FRICTION WHEEL WON'T DISENGAGE
Use a good quality silicon lube and spray into the top of the cable. Do this until it comes out the bottom, a little at a time. Also, spray all pivot points. Don't use WD-40, it will freeze. Lube everything at the end of winter and again before winter.
Jan 31, 2009 | Mowtownusa Snow Thrower Starter Switch for...
Snow Thrower does not self-propel
Did you check under the handle area, near the blower itself for a transmission lever? This will engage & disengage the transmission.
Jan 25, 2009 | Mowtownusa Snow Thrower Starter Switch for...
Agri-Fab Agri - Fab Snow Blower - 42" Logo
199 people viewed this question
Top Agri-Fab Garden Experts
Joseph Mueller
Joseph Mueller
David Ellis Rhea
Ray Smythe
Are you an Agri-Fab Garden Expert? Answer questions, earn points and help others
