Cleaut 32.dll not found
Right before I get to my desktop in the boot up process,an error message shows up -"the file cleaut 32.dll can not be found reinstalling the operating system may solve the problem,then I click ok and it prompts me to put in a password which as far as I know had never set up one then I click ok and it comes up with a blank desktop the only disk I have is a disk labeled windows xp drivers support cd for synet 583-pk netbook meso that came with it and I don't know if it's the right one, the operating system one to reinstall my system and plus and if it's the right disk it's not booting up which I don't know if that's because of the computer malfunctioning during the boot up process {turning computer on} so I need it to snse the disk if it's the right one or I need to know wher to find the right installation cd for this computer to try to reinstall the operating system any help on this would be great thanks
techniwiz
  • 275 Answers
SOURCE: ''Can't load kernel file'' error message on boot up
try to boot in the safe mode and tell me what happens
Posted on Nov 11, 2008
blueextc3221
  • 15935 Answers
SOURCE: windows system 32 hal.dll error after restoring e-machine
There's actually a number of reasons why these annoying little DLL errors happen, but the most common, is caused when new programs are installed over all old ones and the old ones are not completely uninstalled 100%, causing registry pile ups and of course, getting a .DLL error messages.
Another reason, is damage that's been done by malware/spyware/adware programs, attaching themselves to your PC and wrecking havoc, deleting crucial DLL files from your PC.
The hal.dll file is created during install from 5 other dlls. HAL is the Hardware Abstraction Layer and it's the interface between the system drivers and the actual hardware.
Copying hal.dll will not resolve the problem.
A lot of times the file will be reported missing due to corruption of the boot sector or of the file system
Causes of the "missing or corrupt hal.dll" error include, naturally, a damaged hal.dll file or a hal.dll file that has been deleted or moved from its intended location.
Additional causes may include a damaged or missing boot.ini file or possibly a physically damaged HDD.
Suggested remodies-
1. Restart the PC. The hal.dll error could be a fluke.
2. Check for proper boot order in BIOS. You might see the hal.dll error if the boot order in BIOS is first looking at a hard drive other than your main hard drive.
Note: If you've recently changed your boot order or recently flashed your BIOS, this may be what's causing your problem.
3. Run Windows XP System Restore from a command prompt. If this doesn't work or you're receiving the hal.dll error message before you're able to complete this process, move on to the next step.
4. Repair or replace the boot.ini file. This will work if the cause of the problem is actually Windows XP's boot.ini file and not the hal.dll file, which is often times the case.
5. Write a new partition boot sector to the Windows XP system partition. If the partition boot sector has become corrupt or isn't properly configured, you may receive the hal.dll error.
6. Restore the hal.dll file from the Windows XP CD. If the hal.dll file is truly the cause of the problem, restoring it from the original Windows XP CD may do the trick.
7. Perform a repair installation of Windows XP. This type of installation should replace any missing or corrupt files. Continue troubleshooting if this does not resolve the issue.
8. Perform a clean installation of Windows XP. This type of installation will completely remove Windows XP from your PC and install it again from scratch.
Note: While this will almost certainly resolve any hal.dll errors, it is a time consuming process due to the fact that all of your data must be backed up and then later restored.
Important: If you can't gain access to your files to back them up, understand that you will lose them all if you continue with a clean installation of Windows XP.
9. Replace the hard drive. Finally, if all else has failed, including the clean installation from the last step, you're most likely facing a hardware issue with your hard drive.
10. Perform a new installation of Windows XP after installing the new hard drive.
I have not tried it - but HERE is a free program purporting to fix the error.
Thanks for using FixYa - a FixYa rating is appreciated for taking the time to answer your FREE question.
Posted on Apr 10, 2009
  • 108 Answers
SOURCE: I have tried to install my windows XP operating system by booting at CD installer. But when the PC is ready for installation. It stop & message appears to "STOP c0000221 Unknown Hard Error systemR
not sure if this will really help but here's a Microsoft article which seems to deal with the problem: http://support.microsoft.com/default.aspx?scid=kb;en-us;Q314474 Good luck,
Posted on May 23, 2009
kamal1984
  • 1383 Answers
SOURCE: My desktop came up with a blue screen last week
First refix your RAM.
Then boot youre computer with winxp
Then go to recovery console.
Then type in command prompt "chkdsk /r"
then enter "y"
then it fixes error on disk.
Thats it.
Posted on Jun 18, 2009
SOURCE: Gateway GT5468 will not boot from Hard Drive or
First open cpu cabinet cover then reconnect RAM memory and both connection to harddrive. Then when you power up the computer press F1 or F2 or del or ALT+F2 key to enter in bios then load optimal defaults settings set first boot device as cd rom save settings and exit from bios. then boot it with disk you need to repartitioned the harddrive and reformat it .Then install copy of windows. If you are not able to see partition screen with windows disk then you need to use third party partition tool for repartitioned the harddrive. Let me know if you need further assistance. Thanks for using FixYa.
Posted on Feb 13, 2011
Have acer aspire one, when started got screen saying file missing or corrupt window root system 32 hal.dll, nothing else cannot bring up safe mode do not have windows xp cd, in nursing home cannot afford...
I am going to start with the assumption you have already tried to reboot, then next choices from there go kinda like this...
Run windows XP restore from command prompt. (From safe ,mode type C:\windows\system32\restore\rstrui.exe and press Enter. If this doesn't work or you're receiving the hal.dll error message before you're able to complete this process, move on to the next step.
Replace the boot.ini file (run msconfig) This will work if the cause of the problem is actually Windows XP's boot.ini file and not the hal.dll file, which is often times the case.
Note: If repairing the boot.ini does correct the hal.dll issue but the problem reappears after a reboot and you've recently installed Internet Explorer 8 in Windows XP, uninstall IE8. In this specific situation, IE8 could be the root cause of your hal.dll problem.
Right click on c: drive, click on properties, then tools, click on the error checking button, the put a checkmark in each box, Click start and it may say it needs to run on next reboot click OK the reboot. The physical part of your hard drive that stores any part of the hal.dll file has been damaged, you're likely to see errors like this.
Run a repair install of the operating system. This type of installation should replace any missing or corrupt files. Continue troubleshooting if this does not resolve the issue.
Nov 29, 2010 | Computers & Internet
Had to reinstall XP operation system, now I am getting 2 Intel Audio Studio Controller error messages. Error 53 file not found IASMXDLL.DLL and Run Time error 53 File Not Found IASBB.DLL.
If you find a dll called iasdll.dll on your pc, you may have a spyware program known as 'invisible activity spy'. This process may have been installed via an installation package (potentially when another application was installed). The 'invisible activity spy' process has been known to monitor activity on pc's by capturing your key-strokes. Either you downloaded a hacked board driver or you have a bad copy of XP.
Mar 11, 2010 | Computers & Internet
Windows system 32 hal.dll error after restoring e-machine
Suggested remodies-
Apr 10, 2009 | E-Machines eMachines Desktop PC
Dll fix
have you complete the installation fully? you need to make sure it complete.. you may want to read below link to have more understanding about dll error...
http://etech.maiila.com/repair-kernel-32-errors-and-fix-dll-file-error-messages
hope this helps...
Nov 05, 2008 | Ahead Software Nero 6.3 Reloaded (60096)...
Desktop Error Message
Probably this is a spyware, use a good anti spyware or do the following:
Run Process Explorer (right click on task bar>task manager>Processes) and Kill the Following Processes:
wscript.exe
dxdlg.exe (kill this one first)
Run Autoruns and under logon tab, remove
C:\WINDOWS\system32\wscript.exe C:\WINDOWS\system32\boot.vbs
Search for entries named wproxp and remove it
Remove the following files from your PC:
C:\WINDOWS\system32\dxdlg.exe
wproxp.exe (Most probably in your system32 or windows folder)
Jul 06, 2008 | Computers & Internet
Error - Kernel32.dll
Microsoft defines Kernel32 errors as follows: "The Kernel32.dll file is a 32-bit dynamic link library file that is found in Windows 95, Windows 98, or Windows Millenium Edition (Me). The Kernel32.dll file handles memory management, input/output operations, and interrupts. When you start Windows, Kernel32.dll is loaded into a protected memory space so that other programs do not take over that memory space. On occasion, you may receive an invalid page fault (IPF) error message. This error message occurs when a program tries to access the Kernel32.dll protected memory space. Occasionally, the error message is caused by one particular program, and other times the error message is provoked by multiple files and programs."
Sep 21, 2005 | Polaroid PhotoMax PDC 640CF Digital Camera
Microsoft defines Kernel32 errors as follows: "The Kernel32.dll file is a 32-bit dynamic link library file that is found in Windows 95, Windows 98, or Windows Millenium Edition (Me). The Kernel32.dll file handles memory management, input/output operations, and interrupts. When you start Windows, Kernel32.dll is loaded into a protected memory space so that other programs do not take over that memory space. On occasion, you may receive an invalid page fault (IPF) error message. This error message occurs when a program tries to access the Kernel32.dll protected memory space. Occasionally, the error message is caused by one particular program, and other times the error message is provoked by multiple files and programs." .
Sep 21, 2005 | Polaroid PhotoMax PDC 640 Digital Camera
Sep 21, 2005 | Polaroid PhotoMax PDC 300 Digital Camera
Sep 21, 2005 | Polaroid PhotoMax Fun 620 Digital Camera
Sep 21, 2005 | Polaroid PhotoMax Fun 320 Digital Camera
Computers & Internet Logo
David Payne
David Payne
