Question about HP Photosmart C3180 All-In-One InkJet Printer
Scanning problem Hello! I have been using my printer for some time now, with no issues. I finally decided to try and scan something, and cannot get it to work. Was there something I missed in the setup? I have had old scanners that had a lock on the bottom, but didn't see anything like that on this. It starts to try and scan, then stops and flashes the power light. I have turned on and off, unplugged, etc. and nothing helps. Thanks! I have an HP Photosmart 3100 series.
  • 1 more comment
  • kayti Mar 29, 2008
    how do i scan a picture to my computer
  • Anonymous May 29, 2008
    how to scan?
  • mowery Jun 10, 2008
    I tried to scan a picture for the first time and it won't work it says that the disk I have is not the right one. It came with my computer.
    Novelist:
  • 188 Answers
Hi Teneikm,
Please click on the web link given below and check all the link provided in the web page.
http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?rule=46151&lc=en&cc=us&lang=en&dlc=en&product=1146331
Your all question's will be answered through the web link given below.
Have a great day!
Posted on Mar 25, 2008
SOURCE:
Paper completely jammed
Lift feed panel, then the cover. carefully pull in thedirection of normal feed onto the scan plate. Do not try to pull out from the entrance.
Mar 13, 2015 | Canon Pixma MG3150 All-In-One Color...
How do you scan a document onto your computer
If your printer supports scanning, then the main issue you have is
software to control the printer and DO something with the document once it is scanned. Readiris is what I use. I have version 11 and I think they are up to 13, but it works GREAT. There probably are other pieces of software out there to handle scanning and result document manipulation. With Readiris, you can make the scanned item directly into a jpeg or a pdf. which is really useful. You might want to try download.com and search there. Good Luck
Mar 09, 2013 | Canon PIXMA MX340 Wireless Office...
I just got my new printer Canon Pixma MX420 yesterday. When I turn on the printer, the error 5100 occurs. The scree of the pritner askes me to see the manual, but I can find the solution page. I dont know...
Hello and Welcome to FixYa!
If you are facing Error 5100 then it means that the cartridge can not be detected by the printer.
Actually when the printer is not actually load the cartridge it shows error 5100
To solve this error follow the given steps:-
First of all turn off printer and remove both the cartridges from the printer, Now use a clothe moistened with alcohol to clean the surface contact on the cartridges where the terminals inside the printers touches, Return the cartridges and turn on the printer.Error will be removed.
Let me know If you have any more Confusion, questions or issue regarding your problem
I hope this solution helps you. Thank you for using FixYa!
Aug 20, 2011 | Canon Pixma MX420 All-In-One Printer
I have an HP Photosmart 3210 All-in-One (Printer-Scanner-Copier) and it recently has decided to stop scanning and copying. I have never had problems prior to this; and have tried disconnecting and...
We are not sure what could be the cause of this issue. There is a simple method to fix this issue
Click on the link below to download and run the HP scan diagnostic utility.
This utility will diagnose the issue and try to fix it as well.
Click on the link to download the utility program - Link
Oct 12, 2010 | HP Photosmart 3210 Printer
Takes 45 minutes for one scan!
You must have been scanning using large DPI settings. Try to use 100 DPI for scanning. Also make sure that you have alot of free memory on your system. Hard drive space also affects the speed of the scanning. If you are using a parallel printer port for your scanning, this will contribute to the slowness of your scanning.
I hope this helps. Have a nice day.
- HotRatchet
Dec 14, 2009 | Canon PIXMA MP600 all-In-One InkJet...
If I try to scan several pages(ex:15 pages), several of the pages
Go to HP website and download latest patches for this model.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=391182&lc=en&cc=au&dlc=en&submit.y=6&submit.x=9&lang=en&cc=au
Dec 07, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Printer wont scan
Remove the jammed paper. Unplug the printer from the mains and PC. Inspect the rollers, etc for tiny paper piece(s) that may be stuck, or other debris. Try to clean rollers and make sure they are dry. Keep printer unplugged for about 2 minutes and replug and try a test print. Also make sure that you have waited long enough for the printer to heat up before giving a print job. Finally, it could be an issue with the paper sensor. If this is the case, you will probably have to take the printer in for servicing..
Aug 21, 2009 | Lexmark X2500 All-In-One Printer
PRINTS TEST PAGE WHEN TURNED ON
Actually its not my solution... see http://forums13.itrc.hp.com/service/forums/bizsupport/questionanswer.do?admit=109447627+1235819514435+28353475&threadId=932709
"Holly" posted something that worked for me:
Holly Jul 6, 2005 07:09:59 GMT Unassigned Hello!
This is something you can try. Sometimes the printer doesn't understand that the alignment page you are scanning is for it to read, therefore you have to do a 'standalone alignment' on the unit before it actually does understand. Here is how you do it:
1. Hold Cancel and On, then release.
2. In sequence, press Cancel, Resume, Paper Type, Color Start Copy.
3. Another alignment page will print out and this is the one that you should actually put faced down in the scanner glass and press Scan.
^Hopefully that will be the last and final time that the alignment page prints out!!
Feb 24, 2009 | HP PSC 1315 All-In-One InkJet Printer
Scanning/Uploading Issues
in the HP print manager, you can go to scan, settings, and decide where and what format those scans become..if you need more help, then you might consider a shared screen service call with me..
Mar 28, 2008 | HP Photosmart C4180 All-In-One InkJet...
Compaq A3000 scan issue
The cartridges problem my be caused by the two retaining springs located under the cartridge resting area at the right side of the printer. I discovered them when I opened up an attemped to clean my A3000. Both springs were broken, an I can't tell where they were attached.
Oct 11, 2006 | Compaq A3000 All-In-One InkJet Printer
HP Photosmart C3180 All-In-One InkJet Printer Logo
184 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
