Question about Standard Horizon Boating
Mike cable broken for cmp23w remote mike - Standard Horizon Boating
I have a Zenith Model B25AO2Z tv and programmed it through my cable remote. I just got a new cable remote and the first step to program a tv is to turn on the tv. I can't do that because the t
Have you ever tried to fix tv remote? Most of the remotes don't work due to broken led connection (Red circuled area). Try to resolder it, may be you might work it.
Nov 19, 2014 | Zenith B25A02Z TV
Bush cht100dvd pret
Try www.shopjimmy.com They have a lot of them.
Jan 06, 2014 | Televison & Video
MY DAUGHTER HAS A SOVEREIGN SV40, CLASSIC XC35 PETROL LAWN MOWER, AND THE CLUTCH CABLE HAS BROKEN. I WOULD LIKE TOP KNOW WHERE I CAN PURCHASE A REPLACEMENT. I'VE TRIED THE WEB WITHOUT SUCCESS. CAN YOU...
As far as i remember the SV40 was a non self propelled mower, it will only have an opc cable ( engine brake cable ) this is part no. 531206026, in the UK the parts are distributed through Flymo.
May 14, 2011 | Garden
Good afternoon, i am looking for an akai setup code for the lct3201ad tv/dvd combo for my comcast remote control. thanks, mike
Mike, there is another solution: if you subscribe for comcast cable, they will retrieve the code for you, without you leaving your place.their remotes are learning and can be programmed remotely via you cable box. If you don't have a valid subscription, there is a problem. You might need to get universal remote, what supports this brand.
good luck,
Alex's TV Service,
Philadelphia,Pa,
215-806-5980.
Jan 22, 2010 | Akai LCT3201TD 32 in. LCD Television
Broken plastic on minn kota steering cable
Hi!
Here's a schematic:
Edge 40
My guess is you need key# 80 (part# 2232360 cable drum pulley)
Good luck in your repair!
Mike
Sep 19, 2009 | Minn Kota Edge 40 Freshwater Bow Mount...
Mintek Fix
Depending on the connection, one loose solder point could be the problem. Unfortunately I have to leave for work so I can't help you any further until about 10:00 tonight (EST). I will post some pictures by this time tomorrow, though. Maybe those will help as well. Oh and just to double check, you cut the wires from the DVD player and soldered them so that the component cables now run directly into the motherboard, correct?
I'll post some more info just as soon as I can.
Ryan
Mar 11, 2008 | Mintek DTV-263 26 in. LCD Television
Display Not Working
i need code number for sony xr-m510
Jun 11, 2007 | Sony XR-M510 Cassette Player
Boating Logo
49 people viewed this question
Top Standard Horizon Boating Experts
Are you a Standard Horizon Boating Expert? Answer questions, earn points and help others
