Question about Back to Basics 600 Smoothie Plus Work Top Blender
Where can I buy gearbox collar for cuisinart fpb-5ch
Part burned
How do I remove old blade?
Hi Paul,
There is a collar on the base of the jar that screws onto the jar. You will need to unscrew the collar and fit a replacement blade. make sure the seal is replaced with the blade and the collar is screwed back securely.
See this link for the parts of the blender.
CUISINART CANADA SmartPower Premier 600 Watt Blender CBT 500C
Also see the product description for the blade.
https://www.youtube.com/watch?v=rdBxUAsT_TQ
Mar 04, 2015 | Cuisinart Replacement Cbt-Bg-1 Blender...
Blender is leaking
As we all know that blender is an electronic device from which you may face some problems while using it. One of the main problems is leakage, the neckline and gasket are the first problems that will give some inconvenience to you, it is a most critical part of your blender because they keep it sealed or water tight. I would suggest you the Best Blender Under 100 which is on your budget also.
Sep 18, 2013 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
I have had my Cuisinart SmartPower blender for about 10 years now and it has worked great. Recently there has been a black dust/stain/residue that is on the underside of the bottom collar/blade and on the...
At 10 years you are heading to replace it. With the blender bowl removed, try turning the connector the goes to the blades. Then do the same with the connector on the base. Whichever one doesn't turn easily is the one that is failing. Usually there is corrosion in the spindle of the jug and this causes tightness which in turn causes the connectors to shred. The tightness cause friction, which makes the plastic parts get hot. The blade should spin easily, the connector on the motor, not quite so easy. On some blenders you can switch the base on with out the jug being on it. Run it for 30 seconds and then switch off. If it stop dead, then problem is with the base and the spindle that goes to the motor. In a catering environment, I had a Hamilton Beach, shatter the base connector after 2 years. With blenders, you get what you pay for, Cuisinart aren't bad, but there are better makes if you use them a lot.
Aug 19, 2017 | Cuisinart SPB-7 SmartPower Work Top...
I tried to blend large piece of the frozen mango. It won't move and I continue trying . I smell little burned and the machine wont move again.
It sounds as if the motor has burned out. You may need to purchase a new blender or send it to the manufacture for repair if it's still under warranty.
Jul 14, 2011 | Cuisinart Blenders
I need the replacement glass bowl. My wife dropped and broke. It is the blender bowl for the Cuisinart Smart Power Duet, model FPB-5CH
Hi!!
Smart & Final carries a variety of glass bowls in plastic, glass and metal, at the cost or the S&H you would pay if ordering from dealer.
If helpful, click below.
Apr 08, 2010 | Juicelady JL600 Professional Work Top...
Cuisinart powerblend 500 blender doesn't work
sorry to hear of your problem. Do not delay to contact cuisinart customer service to return this defective item. Here is the link
Any requests concerning product returns should be directed to customer service.
1-800-726-0190
customerservice@cuisinart.com
Jun 11, 2009 | Cuisinart SPB-7 SmartPower Work Top...
Clutch on the jar of my cbt500 cuisinart blender is broken.
The clutch assembly is for the teeth on the base itself. If your problem is with the teeth that are connected to the bottom of the blade that sits in the jar, you want to order a blade assembly instead.
-Tha Mp3 Doctor (also loves Cuisinart)
Mar 21, 2009 | Cuisinart Blenders
Cuisinart fpb-5ch blender not working
Remove blender attachment completely, turn machine on and see if it will spin with all attachments removed - if it spins, then replace the blade assembly - parts available from Cuisinart. If it doesn't spin, send to Cuisinart for repair (call first).
Dec 11, 2008 | Blenders
Attaching top container to bottom tub.
Place food processor attachment on base
Put work bowl on gear collar with left slot just to the left of the tab on left side, slide until tabs click
Place work bowl lid on top of workbowl with tabs slightly to left of work bowl handle - slide into place until it clicks
Nov 13, 2008 | Cuisinart BFP-703 Blender
Back to Basics 600 Smoothie Plus Work Top Blender Logo
Top Back to Basics Blenders Experts
Mike
ray gallant
Are you a Back to Basics Blender Expert? Answer questions, earn points and help others
