Question about Motorola Mobility RAZR V3
Some of the keypad not working
The right side of the keypad does not work. the 3, 6, and 9 doesn't work. what needs to be fixed or replaced. cingular won't help.
Well ok the membrain on your motorola razr is damage i'm not sure where can fix it but what u can do i go to the nearest electronic center and c what dey can do
Posted on Oct 09, 2007
Time features not working
SEE THE CAUSES AND PROCEED ACCORDING. GOD BLESS YOU
If you have a stuck key or non-responsive key, most of the time you will have to replace the keypad for this microwave oven repair. If your keypad is connected to your control board by a flat ribbon wire, try disconnecting it and clean the silver contacts with an ordinary pencil eraser. After cleaning, plug it back in and try it. If it doesn't fix it, replace the keypad unit. Some units actually have keypad tests to confirm your diagnosis of a bad key.If your keypad and control is the same unit, replace that unit. Another note, unlike stove/oven keypads and controls, most microwaves do not have error codes or tests to distinguish whether it is truely the keypad or control. Most of the time, it is the keypad that needs replacing, but a small percentage of the time it can be the control. Check the tech sheet if they can point you to the right part.
Oct 17, 2012 | Microwave Ovens
LED not working
see this causes and fix it. God bless you
Oct 10, 2012 | GE Advantium 120 Convection/Microwave Oven
Tappan 5030 microwave oven fuse is ok but no lights on keypad come on
see the causes and fix it. God bless you
Touchpad dead If you have a stuck key or non-responsive key, most of the time you will have to replace the keypad for this microwave oven repair. If your keypad is connected to your control board by a flat ribbon wire, try disconnecting it and clean the silver contacts with an ordinary pencil eraser. After cleaning, plug it back in and try it. If it doesn't fix it, replace the keypad unit. Some units actually have keypad tests to confirm your diagnosis of a bad key.If your keypad and control is the same unit, replace that unit. Another note, unlike stove/oven keypads and controls, most microwaves do not have error codes or tests to distinguish whether it is truely the keypad or control. Most of the time, it is the keypad that needs replacing, but a small percentage of the time it can be the control. Check the tech sheet if they can point you to the right part.
Oct 10, 2012 | Tappan TMS062E1 Microwave Oven
LG touchpad doesn't work
use the common sense,logically, fix it. God bless you
Aug 02, 2012 | LG Microwave Ovens
Hotpoing microwave
use the logically, clearly, fix it .God bless you
Aug 02, 2012 | Hotpoint Microwave Ovens
Touchpad not working
please see the next step. and fix it. God bless you
Aug 02, 2012 | Microwave Ovens
My LG Microwave is not working. The STOP/CLEAR button does not work
see the next steps: USE THE commons sense . God bless you
Lights come on, but can not program unit, Touchpad dead If you have a stuck key or non-responsive key, most of the time you will have to replace the keypad for this microwave oven repair. If your keypad is connected to your control board by a flat ribbon wire, try disconnecting it and clean the silver contacts with an ordinary pencil eraser. After cleaning, plug it back in and try it. If it doesn't fix it, replace the keypad unit. Some units actually have keypad tests to confirm your diagnosis of a bad key.
Aug 01, 2012 | Microwave Ovens
Display on my Sharp Carousel R-425EW stopped working, is there and easy part to replace?
see the next steps: use the common sense .God bless you
Jul 31, 2012 | Microwave Ovens
My nokia x2 keypad problem when open restart the mobile then working all keys, after 6, 7 seconds all keys are not working without power , names, 3, 6, 9 and camera. plzzzzz give me solution.
Hello first of all you need to check the keypad IC(Filter)....check that the ic has stains/something dirty.If not remove the switches which is stitches both sides of the main board and try.If the problem remains the same the only thing you need to do is to change the keypad filter (ic).So, the best to fix your problem is to contact mobile repairing shop.Good luck
Jun 20, 2012 | Nokia X Cell Phones
The key pad on my Motorola V3s RAZAR doesn't work the only button that works is the power button. All the other buttons don't work, how can i fix it myself.
If you're going to do it alone,follow this steps.
1. try to check if the volume up or down is working,if not, remove the battery cover and dismantle the lower panel at the back using a T6 precision screw,unscrew 2 screws and by using your thumbnail look for edge cover,insert and lift it up gentle (remember that a flex connector is attach on the right side If done,check the volume switch and remove the circular metal (keypad membrane) that is volume high and low apparently.clean it and align it when returning back before assembling it(might some shortage or hang buttons that's why keys are not working).,also try to check if the flex connector or socket is clean as well as the board socket connector cause keypad function has the line with it.assemble it and try if its working.
2. If the method above fails,need to replace the keypad flex cable.it maybe to risky for you to do cause the keypad connector is connected at the upper flip panel.i maybe reliable if you continue and there's a chance to break the lcd cause upper portion is to hard to dismantle.better bring it a mobile service center for keypad flex replacement.
hope this simple solution helps.
Jun 19, 2011 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
