Question about Brother Sewing Machines
I want to thread a brother xl4050 sewing machine
Xl 4050 I need to see a manual telling me how to thread sewing machine
SOURCE: Brother XL-5130 Sewing Machine
Put the thread through one of the holes. Then put the bobbin on the spindle. Pull about 3 or 4 inches out of the hole and hold on to it. Start winding the bobbin. After about ten turns, or when the winding thread is secure, you can stop the machine and cut off this 3 or 4 inch tail. To insure that the thread winds up and down the bobbin and not off the top or bottom, there is probably a metal bobbin tension disk that the thread must pass around before it goes to the bobbin. It is probably on the left of the machine and may or may not be part of a thread guide. The thread must pass around this disk on its way to the bobbin in order to put tension on the thread so it will wind properly. If you can't find the disk, which is a small metal button or screw with some type of somewhat moveable spring cap, you can just get the thread to pass through your thumb and forefinger. Hold your hand 6 or 8 inches to the left of the bobbin and pass the thread between your thumb and forefinger so that it makes the thread go in a direct straight line to the bobbin. Pinch the thread only enough to keep it taught but not tight and let it flow through your finger to the bobbin. The thread should go up and down evenly on the bobbin. If not, move your hand up or down to position it so the thread will wind up and down smoothly. It will not be necessary to move your hand once you find the correct position needed for winding.
Posted on Jul 20, 2007
  • 27 Answers
SOURCE: Brother Sewing Machine model:CS8150 bobbin thread problems
The top of the machine is not threaded correctly. First raise the presserfot then rethread the machine. Bottom looping is usually caused by a lack of top tension. There could allso be a bur on the hook.
Posted on Feb 23, 2008
  • 10 Answers
SOURCE: HOW DO i THREAD A BROTHER BM2600 SEWING MACHINE
They have several brother diagrams and threading instructions @ http://www.sewusa.com. I hope this helps you.
Posted on Jul 24, 2008
SOURCE: I need a manual for
* Just in case *
Also .. FREE download available here or here >
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_XL_5130_5232_5340_EN_208.PDF
Posted on Jan 12, 2009
make sure that when you insert the thread *top hole bottom to top* that you turn the bobbin itself until you hear a click *that is the spring sliding into the ****.
Posted on May 02, 2009
I have a brother xl 5500 it keeps breaking the top thread no matter what i do
Go back to your instruction manual, some available online. to Re-thread the machine completely and make sure you are threading correctly. If that's not it, you may have thread jammed in a mechanism and it needs a technician's tools to get at it properly.
Cheers,
Kelly
Embroidery Services
San Diego, CA
Feb 25, 2015 | Brother XL-5500 Mechanical Sewing Machine
Can you tell me what kind of thread should be used with my Brother XL 2600? I can't seem to download the manual online.
If you go to this site and read the manual online go to page 28 it will tell you what thread to use with what fabric. It would not let me copy/paste
Scroll past the "download the document" go to "table of contents" click on view all then scroll down to fabric/thread/needle combinations click on it and it will bring you to the page.....
http://www.retrevo.com/pdf/18806dj992/30/FABRIC%2C+THREAD%2C+AND+NEEDLE+COMBINATIONS#q=Brother+XL-2600
Essentially
60-80 weight thread for medium and light weight fabrics
50 for heavy weight
50-60 for stretch
30 for top stitching
hope this helps lew
Feb 10, 2011 | Brother XL-2600
With my Brother 3750 sewing machine, it is hard to thread because the arm that goes up and down does not come out of the machine "case". I end up trying to almost blindly put the thread through...
Hello, Cwpetronio -
I hope I am correct in thinking your Brother sewing machine is in the XL series of sewing machines. If so . . .
I think you will find the instructive illustrations here helpful:
http://support.brother.com/g/b/faqend.aspx?prod=hf_xl3750eus&c=us_ot&lang=en&faqid=faqh00000467_000
I would think the instructions for threading the machine are in the owner's manual. If you do not have the manual, you can download on free here:
http://homeappliance.manualsonline.com/manuals/mfg/brother/xl3750.html
Note: The manual is in PDF format, meaning you will need Adobe Reader software (free). After you download the manual, I recommend you save it in your Documents folder using a file name you can find again easily - Brother XL-3750 Manual. You can print the manual for easy reference.
Best wishes.
Jan 19, 2018 | Brother XL3750 Mechanical Sewing Machine
Thread keeps breaking
go to www.brother-usa.com and download your manual for free, it will have a troubleshooting guide to tell you what to do. Some ideas are that it is not threaded right, tangled thread or wrong needle for the fabric you are using. I am sure there will be the answer in your manual.
Sep 18, 2010 | Brother XL-5130 Mechanical Sewing Machine
Top thread keeps breaking
Check your threading path with your manual. If, you look up your manual online at brother.com it can be made larger and you may spot your mistake easier.
Jul 20, 2010 | Brother XL-5130 Mechanical Sewing Machine
Thread is catching & breaking somewhere inside the machine before it gets to the needle. brother XL-5600 machine
According to page 18 of the manual, the only place the thread could be catching would be the tension discs or the uptake lever.
Lift the presser foot and run a heavier thread or flat, unwaxed dental floss through the threading procedure to see if this will clean out a thread that may have jammed into the discs.
Always thread with the presser foot up and make sure the uptake lever catches the thread.
If this continues, take the machine to an authorized Brother dealer for service.
Apr 10, 2010 | Brother XL-5600 Mechanical Sewing Machine
How do I thread my bobbin to my brother xl-5130
Here you are....download the manual for free.
http://www.brother-usa.com/manuals/default.aspx?PGID=3&R3ModelID=XL5130
Mar 24, 2010 | Brother XL-5130 Mechanical Sewing Machine
Thread tension for Brother XL 2230.
If you have pattern dials set correctly then I might guess that one or more sets may have been missed when the thread was being set up in the machine. most of these models show either arrows or numbers for each or way the thread needs to be routed.
Apr 26, 2009 | Brother XL-2230 Mechanical Sewing Machine
Threading and operation
http://www.devicemanuals.com/guide/Sewing%20Machine/Brother/Brother-XL-3022-Sewing-Machine-Owner%27s-Manual-T0RNeE5qUT.html
or i could photocopy pages from my manual and post them too you if that would help. (can't scan as my scanner doesnt work for some reason).
if not than nevermind.
Feb 10, 2009 | Brother LS-1217 Mechanical Sewing Machine
Sewing Machines Logo
54 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
