Question about Sigma Powers Inc Rural King 6,500 Watt Electric Start Portable Generator 6500E
6500e generator runs no voltage - Sigma Powers Inc Rural King 6,500 Watt Electric Start Portable Generator 6500E
I have rural king 6500E electric start generator. I like to use the battery but do not know how to connect it. No instructions came with it.
This is computers not generators, please post in the correct category so that your question can be answered as i know nothing about generators !!
Aug 04, 2017 | The Computers & Internet
Putting new gas line on as I have had lots of trouble with gas leaks. anyway gasket fell off of carb. can you send a pic of how it goes on? the gasket that is
Mike,
Sorry to hear the carb is leaking. This happens when the Carb Float Needle gets stuck and is easy to rectify.
If you watch this video on YouTube it will show you how to free up the Float Needle. It is the same procedure on all Carbs:
https://www.youtube.com/watch?v=7LrBmeBcVnA
Dec 20, 2016 | Sigma Powers Inc Rural King 6,500 Watt...
I have a rural king generator 6500 E It starts fine but after a few Minutes it dies?
It sounds like it is starving for fuel. You probably need to rebuild the carb.
Oct 21, 2014 | Sigma Powers Inc Rural King 6,500 Watt...
I Have a Rural King Generator it starts Fine but only runs a few minutes and it shuts off
Make sure the gas is fresh. Also, take off the carb bowl and look for signs of gumming. If there is gooey stuff in the bowl, then the carb needs to be cleaned.
Sigma 6500E generator
First verify that the breaker for the outlets is not tripped and make sure that the generator is running at full operating speed. let it run for 5-10 minutes and check for output power. If there is nothing, there are two possible problems. One could be that the automatic voltage regulator is bad. The other is that the field needs to be flashed - a high possibility if the generator has not been run in a long time. There are many videos on the internet that show you how to solve both of these problems. Just do a search for No output from a portable power generator.
Mar 20, 2014 | Sigma Powers Inc Rural King 6,500 Watt...
Need a sigma 6500e assembly diagram
I just purchased a Sigma 6500E generator, there was no instruction manual with it. Did get in stalled, but couldn't find out where to connect the battery cable, also there was nothing about the engine at all. Does the battery get charged when the generator is running ?
I would hope that information is available for this unit. thank you
Dec 05, 2013 | Sigma Powers Inc Rural King 6,500 Watt...
Where can i find a manual for jd tek 6500e generator
JD Tek 6500E LPG Generator how to install wheels Battery handles
Mar 05, 2013 | Computers & Internet
I have a Generac 6500E. The electric start turns over the engine but will not start. Pull start works fine
If the pull start works, but the electric start doesn't try the following. Either give the battery on the generator a full charge, and if after a full charge it doesn't start, get a new battery.
Jan 20, 2013 | Generac GP6500E - 6500 Watt Electric Start...
Sigma Powers Inc Rural King 6,500 Watt Electric Start Portable Generator 6500E Logo
Top Sigma Powers Inc Electrical Supplies Experts
ken skalski
Gene Haynes
Are you a Sigma Powers Inc Electrical Supply Expert? Answer questions, earn points and help others
