Question about Miele DG 4080 Stainless Steel Electric Single Oven
HAVE A MIELE SINGLE OVEN HAVING A RATTLING NOISE AT THE BACK NEAR THE FAN
HAVE A RATTLING NOISE AT THE BACK NEAR THE FAN WHEN OVEN HEATING UP AND THEN COOLING DOWN AFTER COOKING, DOES NOT RATTLE DURING COOKING
3 Suggested Answers
KevinWhite
  • 1902 Answers
SOURCE: ive got a miele classic single oven H363-1BP-KAT.
Hello & Welcome to FixYa
It indicates an open/shorted oven temperature sensor and to solve this problem the temp.sensor needs replacement. If you want to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more then this then it needs replacement however, if the reading is around or less then 1100ohms then it is the control board that needs replacement. Please get back to me if you have any other questions.
Kevin
Posted on Mar 21, 2011
  • 195 Answers
SOURCE: heating element hangs down in Miele oven
Hi dose it look like something broke off on the top of the oven , usually they have a small bracket with a screw in it , do you even see a hole for a screw ?
Posted on Dec 12, 2011
Heating element hangs down in Miele oven
Dec 12, 2011 | Miele H4780BP Stainless Steel Electric...
Replace fan motor in an electric fan oven
For all Free appliance repair videos visit our VIDEO TUTORIALS
1, If the fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the NEFF element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your NEFF fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your NEFF oven thermostat
4, A quite common and easily overlooked answer is if your NEFF oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
Jan 13, 2010 | Neff B1421 Electric Single Oven
Fan making loud noise
Hi
does the noise start as soon as you turn the fan oven on?
does the noise stop as you turn off?
just depending what make and model you have there is two fans
in it 1 is the fan motor inside oven at back and other
is the cooling fan which is at top of oven .you just need
to find out which one it is and just replace . then should be back to normal
regards dan
Mar 19, 2009 | Belling XOU174 Electric Single Oven
MIELE H 4641 PYROLYTIC OVEN
I HAVE THE SAME PROBLEM. KEEP HAVING TO TURN IT ON AND OFF TO USE IT.
Dec 26, 2008 | Miele DG 4080 Stainless Steel Electric...
Oven made a loud noise, pop, and then black smoke....could heating element go out?
sounds like it blew a fuse or the heating element burnt out on it,look to see if the element is burnt in two
May 16, 2008 | Amana AEW3530DD Electric Single Oven
Cooling and/or convection fan
I had the same problem. The screen protecting the fan bends into the fan from the heat. Take off the top front control panel (3 screws), reach in to the back where the fan is and push the screen back away from the fan. As always, turn the power off first to avoid shock. This should solve your noise problem.
Apr 08, 2008 | GE Profile JTP18 Electric Single Oven
Fan oven not heating, bosch hbn 202t
the fan oven element is separate from the grill element. the problem is that the circular element round the fan is blown. remove the back panel of the oven and you will see the element. replacement is easy. on most bosch, the element is removable from inside the oven but for some you have to remove the oven and take off the back casing
May 04, 2007 | Bosch HBL 5032 Electric Single Oven
Noisy Oven when heating up & fan spinning
Neth, Im not familiar with this oven but I thing someone is handing you a line. I've been doing this for 30 years now and never saw a oven cavity arch when heating. The fact is that there is something wrong with the fan motor or fan blades itself. Call this cat back and have them honor your warranty...Catriver..post back.
Sep 12, 2006 | Baumatic B180 Electric Single Oven
Miele DG 4080 Stainless Steel Electric Single Oven Logo
35 people viewed this question
Top Miele Ovens Experts
Paul Bade
Dan Webster
Dan Webster
John
Are you a Miele Oven Expert? Answer questions, earn points and help others
