Question about Panasonic KX-TA308 Phone
Call receptionist and dont get busy signal
HOW CAN I AVOID GETTING THE BUSY SIGNAL WHEN I CALL MY RECEPTIONIST AND SHES ON THE PHONE. I WANT HER TO KNOW SOMEONE IS CALLING HER WHEN SHES ON THE PHONE OR MAKING A CALL
  • Panasonic Master
  • 2,460 Answers
You need to dial two commands on the receptionist's phone. On the intercom dial 7311# for outside line call waiting signals and 7321# for inside calls. (0 cancels).
Carl
Posted on May 05, 2009
SOURCE:
Caller says my phone rings 2 x's and then the busy signal. I don't know how to fix this.
For purposes of discussion, lets say you are the caller. The "busy" signal may be a "reorder" signal. A reorder signal indicates that that the network inbetween your network and the recipient's network (or just the recipient's network) can not "find" a route back to your network. If you had received a busy signal, you reached the recipient's network but the recipient was on another call. If the problem is a "trunk" failure, the solution is beyond your reach. If it is a line failure, a call to the phone compan
Aug 07, 2017 | Lands Phones
I just added 1yr service to my phone and when i call it i get a busy sng
well if your calling YOUR number and don't have voice mail setup you will get a busy signal.. your also being charge for call.... so call yourself anytime and see if someone picks-up.
May 14, 2017 | Computers & Internet
Nortel startalk one of my extensions keeps getting calls and when answered there is just a busy signal on the other end. What is causing this?
If answering live call and is busy signal on the other end then could be a recording from far end....call a tech in.
If voice mail message is busy signal it could be same as above or Disconnect Supervsision is not programmed on the lines and with the carrier.....this detects when caller hangs up then system knows to hang up, if does not hangup then you get busy signal.
Oct 24, 2012 | NorStar Startalk Flash 2 Phone
Everytime that anyone calls the receptionist, her line is busy, How do I correct this issue? Thank you . Panasonic KX-T7630
A couple of ideas. Have the receptionist call you and verify that they are really at the extension you're calling. Then make sure you turn on Call Waiting Intercom on that phone. From the intercom on the reception phone, dial *7311 for Intercom and *7321 for Outside lines.
Now the phone will soft ring and visual indication when you get a second call if you're phone is busy.
If you've mapped a button to ring the receptionist and it's not working, you may have unprogrammed the button. That's reprogrammed by PROGRAM, the button and 1 plus the extrension (usually 101) and STORE or ENTER to save. PROGRAM exits programming.
Carl
Jul 22, 2010 | Panasonic KX-T7630 Corded Phone
Ringer/ Voicemail Bounceback
Well, this one is kinda tricky. If the receptionist knows there's no one there, they can use VoiceMail Transfer.
From the phone, the user can set CF Busy or CF Busy/No Answer with the following codes on the intercom:
Do Not Disturb *7101 / Cancel *7100
Call Forwarding2.gif (FWD)
– Both Calls *710
– Outside Calls *711
– Intercom Calls *712
2 (All calls) + phone no. + #/
3 (Busy) + phone no. + #/
4 (No Answer) + phone no. + #/
5 (Busy/No Answer) + phone no. + #/
7 (Follow Me) + your extension no./
8 (Follow Me Cancel) + your extension no.
So, if your voice mail is 500, you would dial *7105500# to set CF B/NA for intercom and outside calls.
The last piece of the puzzle is the timing. That's *713 (00-99). Start with 24 (4 rings) and go from there. If it hits the receptionist before the forward takes place, you probably have to adjust the recall timer for call transfer, a system program.
Carl
Aug 11, 2009 | Panasonic KX-T7630 Corded Phone
When calling our office, customers get a busy signal
Your voicemail system is down. You have to locate the card in the system usually all the way to the right in the cabinet, and reset it with the little black dip switch on the front of it. push it down and wait 5 minutes than push it back up and wait for a green lcd on the upper part of the card. Or you lost your voicemail system programming. You may need tech support or a tech to come out. ldtsnj.com
Jul 06, 2009 | NEC Dterm DTP 16D-1 Corded Phone
User's voicemail box is not answering the calls
There is also a setting for What extension to forward to..
Terminals and sets, forward busy and fwd no answer.
Forward on busy is no set correctly.
May 13, 2009 | NorStar CallPilot 100
Panasonic KX-TA308 Phone Logo
264 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Henk de Ruiter
Henk de Ruiter
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
