Question about Motorola AP 6521 Access Point
Delete images file - Motorola AP 6521 Access Point
How can i delete a user account from my macbook osx
Hiya. So long as it's not the main (Administrator), account it's pretty straightforward:
Choose Apple menu > System Preferences and click Accounts.
1. Click the lock icon to unlock it, and type an administrator name and password.
2. Select the user account you want to delete, and then click the Delete (-) button.
3. Click OK to save the user's files on the computer, or click Delete Immediately to remove the user account and all the user's files. If you saved the user's files, they are stored in a disk image in the Deleted Users folder, in the Users folder. To see the saved files, double-click the disk image in the Deleted Users folder. To delete the user's files, drag the disk image to the Trash.
Hope this helps :)
-Darian
Jun 05, 2014 | Computers & Internet
I cant delete file protected photos on my camera Cybershot dsc-s750
Please unprotect the images and try to delete the files. I have attached the Manual of the Camera where you can get the instructions to unprotect the images.
http://www.docs.sony.com/release/DSCS750_handbook.pdf
Please refer to page # 43 of the above Manual to unprotect the images.
Feb 15, 2010 | Sony Cyber-shot DSC-W50 Digital Camera
Can't change my ym display image
Did you delete it from yahoo profile in program file? But that is not suppose to happen. Well click on displey image option on yahoo messy...click on browse and when the window for image will be appearing with list of image delete all the image (Delete Picture) showing there ....now click on browse and go to that folder where you kept the image you want to add as your displey image....and proceed...I think it will work fine....If that is also not works....check that you shared your displey image....Good Luck
Oct 16, 2009 | Yahoo Messenger
Have a sharper image mini camcorder that saves images and videos automaticly, how do i delete the images
Under menu go to files and hit ok,use the arrows to find the image/file you want and hit the vol button at the bottom of the camera, it will give you the option to delete
Oct 08, 2009 | Video Cameras
Problems deleting pictures from "My Images".
hi austin... pls try to go to your file manager/ phone or memory card storage/ images/ options/ delete (1 by 1) or delete all... for the other option just plug in your phone to your computer if the phone is a plug in play type... then open the My images folder and delete the images you want to delete...thank you very much...
Jul 10, 2009 | Samsung SCH-u340 Cellular Phone
Want to delete
When you scan things, it gets saved to a location on your computer as a JPG (image file). In the program you use to do the scanning it should tell you what folder it is in, it'll be something like "C:\Documents And Settings\Abc\Something\...". Or maybe "C:\Program Files\Canon\Abc\Something\blah...". Each scan is a separate image file. All you have to do is go to Start->My Computer, then navigate to the location where the files are being saved using explorer. Then select the offending image and hot delete.
Don't deleting things that aren't your scan, though. You can break your computer that way.
Dec 12, 2008 | Canon Office Equipment & Supplies
Need to delete memory
You need to remove the memory card from the camcorder and place it into a pc or photo shops computer. This will allow you to view the saved items on the memory card. You can then save these to disc and delete the contents on the card.
Jun 12, 2008 | Optimus DV-5040 Camcorder
Cannot delete image file 4rm gallery
format ur memory card once and then restore ur handset.reinsert sim and try.
Nov 11, 2007 | Nokia N70 Cellular Phone
Deleting Photos From The Memory Stick
Deleting Still images From The Memory Stick This procedure is nearly identical with all of our digital camcorders. The only difference you may find is that there may not be an enter button on your model. If this is the case, the menu dial serves as your enter button when you push it in. * If you want to delete protected images, you must first deactivate the image protection. * An image which has been deleted cannot be recovered. 1. Set the mode switch to MEMORY CARD. 2. Set the power switch to PLAYER. 3. Using the (FWD) and (REV) buttons, search for the still image that you want to delete. 4. Press the MENU button. 5. Turn the MENU DIAL to highlight MEMORY and press the ENTER button. The MEMORY SET submenu will appear. 6. Turn the MENU DIAL to highlight DELETE and press the ENTER button. Using the MENU DIAL, select either THIS FILE or ALL FILES and press the ENTER button. *THIS FILE : deletes only the file currently selected. *ALL FILES : deletes all files stored in the Memory Card. 7. A box will appear to verify whether you wish to delete the image(s). Using the MENU DIAL, select the item. *EXECUTE : deletes the selected image(s). *CANCEL : does not delete the selected image(s) and returns to the previous menu.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Motorola AP 6521 Access Point Logo
26 people viewed this question
Top Motorola Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Motorola Computer and Internet Expert? Answer questions, earn points and help others
