Question about Video Game Consoles & Games
Why do i keep getting disconnected in batt 4 - Video Game Consoles & Games
Batt.keeps going dead in 3 or 4 days when sitting
Does the battery hold power if you disconnect both cables ?
Apr 09, 2016 | Cars & Trucks
No power going to my radio after changing battery. Wanted to check fuses for the radio but I bought the vehicle without an owners manual. I need a fuse diagram for 2004 Ford Expedition please. Thank you
Radio is usually wired as an accessories fuse on the panel. Is it possible there is power but you need to re enter the security code?
If you don't have the paperwork you may be able to get the code from an online site when you enter the make model serial number. It might cost a couple of bucks? Next time you disconnect the battery, make up a couple of leads with croc clips on, wire them to a small 12v battery and connect them to your batt leads before removing the main batt and the small battery will have enough power to keep your radio/ alarm etc working when the main batt is removed.
Jul 21, 2014 | Cars & Trucks
I disconnected my battery in 08 tundra and now it wont idle
disconecting batt resets the computer. now it needs to learn how to set everything to run again. disconnect batt for atleast 60 seconds, re atach, start car it will start and die(dont press gas) do this over and over until it idles (could take up to 10 times). by pressing the gas you make the computer think it is idling to high so it keeps turning down the idle. it will idle fine after reseting computer and starting several times without hitting gas peddle.
Mar 09, 2013 | 2000 Toyota Tundra
Will it hurt the 03 kia spectra to disconnect pos from the batt while running. I'm asking because i did and it still ran and while using a volt meter to see what my batt getting, my wife turns o
Yes it can hurt the electrical system if you disconnect the battery while the engine is running.
It can toast the diodes in the alternator and cook the computer along with other problems.
You'll need to check the fuses and the engine computer.
Sep 03, 2012 | Kia Spectra Cars & Trucks
I just replaced the batteries in my Jazzy 1170 PLUS. Now my speed control lights blink constantly and the chair is totally unresponsive.I have double checked to be sure the freewheel levers are totally...
According to my 1170 manual the flashing lights are error codes. 1 red = low batt., 2 red = left motor disconnected, 3 red = Left motor wiring fault, 4 yellow = Right motor disconnected, 5 yellow = right motor wiring fault, 6 yellow = Inhibit active, 7 yellow =possible joystick fault, 8 green = possible controller fault, 9 green = Solenoid brake fault, 10 green = high batt. voltage
Feb 13, 2011 | Pride Mobility Products Jazzy 1170 XL Plus
97 checvy astro 4.3 6cyl. I replaced battery, Starter and the batt wont hold a charge. Is it possible to check the wiring from the alt to the starter without having to remove the alternator?
Yes, If you have a volt meter, jump and start engine, with engine running you should have approx 13.5 to 14.2volts that would tell me that batt is getting charged when engine is running. you said new batt would not hold a charge, I would be thinking about a parasitic draw(small amount of power) that in time will drain batt. things to look for are glove box lights, under hood lights that dont turn off. one easy way too see if you have a draw is to disconnect one batt cable, now use a regular (12volt non-self powered) test light and touch one end to batt cable and the other to empty batt terminal, with no light switches on and doors closed, this test light should not light and if it does then you have a drain on batt that will kill it say overnight.
Feb 12, 2011 | Chevrolet Astro Cars & Trucks
Dell inspiron 1525 battery doesnot charge
1. remove all external peripherals 2. try to use ac adapter alone check if laptop will power on. 3. put back batt in with ac adapter. 4. check bios (power on laptop keep tap on F2) 5. check for the bios version, battery info and battery health. 6. check if batt is 0% or 10% charge 7. check battery health and info if the ac adapter is determine or not. also check if batt is performing normally. 8. if batt has 10% charge then download the latest bios for your system. download it from support.dell.com
Nov 12, 2009 | Dell Inspiron 1525 Notebook
Audi a3
Does it keep running till the batt is flat? It could be the aircon condenser fan running - on the left as you stand in front of the car. This is a common prob with A3s of this age.
I have a '05 3.2L Quattro V6 and suffered the same prob. The batt is in the boot of the V6 and is sealed like Fort Knox so impossible to disconnect. After about 3 days with this the fan running constantly and having to put a charger on it every night I let the batt run completely flat to try and reset the complete system - no DIS lights - no starter motor clicks - DEAD. Then I jump started it and the prob disappeared completely. Everything is working perfectly ncluding the aircon. That was 4 days ago and 'touch wood' I've had no probs since. I know this won't work for everyone but it's worth a try before forking out £300+ for a new condenser fan unit. Good luck!
Oct 19, 2009 | 2005 Audi A3
Hi i have a Daewoo Lanos R Reg 1600. It keeps drianing the batte
I have replace the ignition switch itself in Hondas that had starting problems. The switches were worn out.My idea is maybe they use a simular switch. Unfortunatly I think the last one I bought was like $55.00 retail. If you do a ignition switch make sure you disconnect the battery first.
I hope this info helps.
Sep 27, 2009 | 1999 Daewoo Lanos
K618i drain energy faster
yup! replace your batt... if samething happens after replacing your batt then probably your phone has hardware prob. or short-circuited. hope not... hehehe...
just try replacing your batt...
Jan 02, 2008 | Sony Ericsson K750i Cellular Phone
Video Game Consoles & Games Logo
329 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
