Question about Bates Power Arm Extra Heavy Duty Stapler 224XHD Staples 240 Sheets
Chanel is clear, but staple will not come out when lever is lowered
How do I clear a jam?
You have to remove a clip & pin on the side of the staple machine to remove the lower portion where the staples are stored.
Mar 03, 2015 | Arrow Tools & Hardware - Others
How do i refill the staples on a sharp mx3501n printer
Do you have the inner finisher where everything is contained inside of the belly of the machine, or do you have the finisher that stands up next to the machine? If you have the stand up finisher does it have saddle stitch option and are those the staple we are talking about? There is normally a model number on the tag in back ex. FNX1, FNX2, or FXX1 . FNX1 isthe inner finisher and is easy to change the staples on. The front cover flips down right under the screen and then you grab the green lever and pull it to the left side of the machine. If you look inside the gap that is formed you will see a green lever pull this one down and then slide that unit down and into the gap. Save the white plastic piece with the green lever but pop off the clear plastic box by squeezing the two arrows that are printed on it and pulling up. then new staple unit will drop in. and then do everything in reverse to put it back together. Let me know if you have one of the other finishers and I can help with those too.
Oct 08, 2014 | Sharp MX-3501N All-In-One Printer
How to replace staples
If you have the internal finisher that resides in the center of the machine: open the slotted front cover, it folds down towards the ground, then push the green lever sideways to slide the finisher out to the left. Look inside the open area for a green item, push down to eject the cartridge. Pinch the clear cartridge on the arrow to eject the clear part, replace with a full cartridge and reassemble in reverse order. How to replace staples on Sharp printer internal finisher
Jul 21, 2014 | Sharp Mx-M363n Copier, Printer & Scanner...
Office chair lowers on its own
It will be one of two things, either the gas strut is no good and in this case you might as well get a new chair. Or the lower lever is stuck in the " lower" position, if this is the case freeing it up should cure your problem
Aug 28, 2013 | Furniture
How do i load the gun with staples
There is a clip at the lower rear of the stapler--lift this clip upwards which releases the staple tension device which is the clip, a rod, a long spring, and a 'U' shaped clip on the far end. Pull this device all the way out, insert one length of staples into the slot that is revealed, then reinsert the tension device until the small clip re-locks at the rear of the stapler frame. One staple ejects per squeeze of the firing lever--hold the nose of the stapler firmly to the material to allow penetration of the staple. Hope this helps!
Jan 03, 2011 | Arrow T25 Staple Gun
I wasn't able to pull all of the white tape surrounding the staples out when I loaded the staples. Now, the copier is saying that we need to load staples. How can I open the holder to remove the tape?
You have to be careful. Remove the bottom of the cartridge by releasing the four clips that hold it on. Make sure you put the little lever looking part in correctly when you reassemble. This is how the finisher determines the out of staples indication. Remove the staples and put them back in with the arrow aligning with the clear arrow on the cartridge.
Oct 29, 2010 | Canon imageRUNNER 5570 Copier
It's the max eh-c591xa need info on how to load. someone said to unscrew bottom to fix jam. hope this help will load also. wish me luck! AG
You can leave the stapler on the desk. If you pull the lever across the back, the top half will flip over and you can see the instructions and the clear plastice staple cartridge. You just pull it staight out. No screwdriver needed.
Aug 06, 2010 | Tools & Hardware - Others
Staple unit impossible to open
Has to be empty to open. At bottom there should be a small black lever that moves down to indicate staples are present. This sometimes falls out giving a false replace staples message. Cartridge itself must be replaced. This is the cartridge where you insert the staples into. Clear plastic with spring.
May 18, 2010 | Canon imageRUNNER 5000 Copier
How do I open the swingline model 900xd
It took me and my boss wrestling with this mongo stapler for 15 minutes to figure it out! :0)
To open the front end, pull up on the handle while simultaneously pushing down on the small black lever on the front. This takes some firmness and be warned, if it's jammed with staples it's going to take some serious force to get it open - watch your fingers!!! I strongly suggest the minute you get a jam, open up the front and clear it. Don't continue to staple in hopes it will work or clear itself or you will have a build up of jammed staples making it almost impossible to open and clear. Also note that when you open up the front end the staples tend to shoot out so be careful.
To open the back end to load staples, push forward and up.
Hope this is of help :0)
Dec 16, 2009 | Staples Swingline® 36115 Staple Guns Tools...
Stapler constantly shoots out staples even when there is nothing to staple.
There is a contact switch / lever on the staplers that engages the stapler when it is pressed. It must be stuck. locate the lever and see if that's the case, and release it if you can. just my 2 cents, because I'm a copier/fax tech -not a stapler expert :)
May 04, 2009 | Office Equipment & Supplies
Bates Power Arm Extra Heavy Duty Stapler 224XHD Staples 240 Sheets Logo
21 people viewed this question
Top Bates Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Bates Office Equipment and Supply Expert? Answer questions, earn points and help others
