Question about Kenmore 51lb. Clear Ice Maker
Kenmore elite under the counter ice maker quit making ice after cleaning
Cleaned using cleaning solution and it stopped making ice
mastatech
  • 478 Answers
SOURCE: Will not make Ice
You need to relace the control board its easy to change but very difficul to get to the top has to be pulled off.
Posted on Mar 25, 2009
TheMobilian
  • 8220 Answers
SOURCE: we have a kenmore elite
Nickle guard is what you should use. Also you should clean around the compressor. Blow out the condenser. I have a service manual for you:
CLEAR ICE MAKER TECH MANUAL
Posted on Jan 26, 2011
machinetech7
  • 1344 Answers
SOURCE: kenmore elite model 50592000 ice maker problems
Note that the temperature in the freezer must be below 10 degrees F for the icemaker to cycle. The icemaker line is the smaller line (1/4") located in the back of the machine that runs from the valve to the filll tube. To test the valve and icemaker you have to manually advance the ice maker and wait for it to call for water with the 1/4" line disconnected from the valve. You can do this by getting a jumper wire, removing the cover of icemaker, which you jsut grab and pull off, and using the jumper wire insert one end of the wire into the cirle marked "M" and the other in the cicle marked "N". Leave there until you hear a click and sometimes see a little spark behind the modular head wheel. Also if you see ice in the maker that hasn't dumper and the teeth of the icemaker are facing any direction other than two o clock position, the icemaker is bad. Before doing any of the above though check the fill tube to be sure the no ice is blocking water from coming in.
Posted on Jun 05, 2012
Sea Breeze
  • 4654 Answers
SOURCE: After I run the cleaning cycle on my kenmore ice maker model, water is still in water pan and the unit will not make ice.
Here is a link to a Service Manual=>
15 inch and 18 in Automatic Ice Maker Service Manual
and then go to page 22 where the diagnostics begin. I am here if you have questions. The manual is very informative Thanks Sea Breeze
Posted on Dec 14, 2012
ogdad22363529
  • 313 Answers
SOURCE: My Kenmore Elite 3 cycle under counter ice maker has stopped making ice
check the filter when was it changed? is the water turned off call sears for help
Posted on May 02, 2016
May 02, 2016 | Kenmore Refrigerators
Kenmore Elite fridge Ice Maker quit spitting out ice. There are ice cubes in the maker, but it wont release them to the bin
One thing you can do is clean up the condenser coils, the toe kick plate, and the area around the compressor to where the air flows better and it might start working.Other than that your ice mold thermostat inside the ice maker itself could be bad. They are not to hard to replace on modular type ice makers: themobilian_2492.jpg
Jun 24, 2011 | Kenmore Refrigerators
Kenmore Elite Trio 795.77563600 Ice Maker Not Working
Try putting ice inside instead. if the machine gives you water then it's converting in reverse order.& still working. put the machine upright & youi'll get ice...
Jul 29, 2010 | Kenmore Refrigerators
I have a Kenmore Elite 59969 and no ice
six weeks old / prob still under factory warranty . but ck the tempts in freezer it must be 15 deg of colder to work . so reset the control for freezer to the highest setting then back one.. this should help .
Jul 03, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
My icemaker just stopped making ice today....please help
Hi, first , pour about 2/3 cup of water into the ice maker . If if freezes , and dumps , replace the water valve. If it does not dump the cubes , replace the ice maker. After pouring the water into the ice maker , remove the bottom kick panel , and clean the bottom coils , of dust , lint , pet hair , etc , as this will raise the freezer temp . An ice maker has to be 5 degrees , to operate , correctly . If ice maker starts working , after cleaning the coils , GREAT ! ( it does happen ) .
Take care
May 16, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Our kenmore elite bottom freezer is making a loud humming noise. It shuts off when door is open..and continues when door is shut. Temperatures are fine, no error message, it rarely stops..like it is trying...
Turned off the fridge, emptied the Freezer, used a blow dryer for 20-30 minutes, to melt ice that had built up in vents at rear of freezer.
Cleaned the freezer and reloaded...no hum..at least for now.
Sep 13, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Will not make Ice
Mar 25, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Ice maker won't stop making ice
it's time to replace the ice maker, it will not stop, the you can feel the small bar when it looks in to the of position.
Dec 10, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore elite 106.54619300 Ice maker just stopped working
sounds like the moter is burnt out and you need to replace ice maker try ebay
Apr 04, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore 51lb. Clear Ice Maker Logo
41 people viewed this question
Top Kenmore Kitchen Appliances - Others Experts
Charles T Nevin
Charles T Nevin
Sal DeAngelo
Are you a Kenmore Kitchen Appliances - Other Expert? Answer questions, earn points and help others
