Question about Canon P27Dh Calculator
Paper siZe? what kind of paper should i use?
  • 3 Answers
You can use any brand paper, as long as it is the right width of 2 1/4.
Posted on Nov 20, 2013
I WANT TO SET PAPER 15'x12' . KINDLY HELP SIR
Press START - Printers and faxes - right click Tally Line Matrix T6050 Printer - select Printing Preferences - find menu Paper size, select paper with size 15"x12". If not found, select used define or customize - insert paper size (width and height) - OK.
Set paper size on Microsoft office word 2007 - select Page Layout - Margins - Custom Margins - select tab Paper - on Paper size, select Custom size - insert height and width paper (15"x12") - OK.
Hopefully help
Sep 23, 2011 | Tally Line Matrix T6050 Printer
I am not able to print in legal size. When print preview is give its shows in A4 size even though the matter is typed in Legal paper size (8.4 x 14) my operating system is Windows 7. I downloaded the...
The paper size is typically a software setting, and not hardware. For example, try changing the paper size in Word..... Then the printer is a slave to this controlling software.
Mar 17, 2011 | HP PSC 1210 All-In-One InkJet Printer
Left side is cut off when print from email and web page
These kind of cut-off print issues are usually related to paper size. I suspect that your printer's settings are set to something different than the actual paper size being used. Check under the Advanced settings and look for paper size. It may be set to A4 or something when it should be US Letter, for example.
Mar 05, 2011 | Computers & Internet
What kind of photo paper do I use with this printer?
Any photo paper will work up to A4 size. It depends on the size of photo's you'd like to print. If you want 4 by 6 prints, any 4 by 6 paper will work, just remember to put it on the "Photo Paper" setting. Hope this helps, please rate! =]
Mar 04, 2011 | HP PSC 1210 All-In-One InkJet Printer
"Paper Size Error: The paper size selected in the
Problem may be the paper tray. You don't say what kind of printer you have and my psychic abilities are nil.
The paper tray has sensors that tell the printer what size paper is in the tray. Make sure that the tray guides are set correctly.
By the way all paper trays are "in" trays.
Print out a config sheet to see what size paper the printer is set up for for each tray.
Jan 11, 2011 | HP Office Equipment & Supplies
Whenever I print in envelope size there is always smudges. But when on plain letter size there are'nt any smudges. Pls. help me.
Check and change the paper type .May be the envelope you are using has different kind of paper so you need to select the particular paper type to fix this problem
Jan 10, 2011 | Office Equipment & Supplies
In tally HP laser jet 1020 is not accepting the paper size changes. though Paper type is changed from A4 to legal
just a point of interest have you tried this and have you set the size let it take, turn off for like 12 seconds and turn back on. to me its the same as with windows rebooting after any software change, they may not tell you but i always shut it off then back on to save any kind of setting or program, it may be a wasted step but i do it anyway.
the default paper settings
Make sure that the default paper size matches the width and length of the paper loaded in the tray. If the paper loaded in the tray is different from the paper size setting, the printer might print blank pages. For instance, the issue might occur if legal size paper (215 x 355 mm (8.5 x 14 in)) is in the tray, and the paper size setting is letter (215 x 279 mm (8.5 x 11 in)).
Follow these steps to check the default paper settings.
Click the Windows icon
Click Hardware and Sounds
Click Printers
Right-click the icon for the product, and then click Properties
Click Printing Preferences
Click the Features tab.
Compare the settings in the Size drop-down menu with the paper in the tray. If the paper in the tray is not the size in the Size drop-down menu, change the setting:
a. Click the Size drop-down list, and select more. The Size is window opens.
b. Select the size of the paper that is in the tray, and then click ok.
c. Click OK in the Printing Preferences window, and then click OK in the Properties window.
Jul 21, 2010 | HP LaserJet 1020 Printer
Although my document is set up for legal size when I print it only prints to the end of the letter size (on the legal size paper).
Try adjusting your paper try or you might just be low on your toner. How long have you had this printer and what kind is it?
Dec 03, 2009 | HP DeskJet 895cse InkJet Printer
HP Laserjet 3050, need to press ok each time printing
did it work before? check paper size for trays - suspect it is set for a4, change to letter size
Mar 12, 2009 | HP LaserJet 3050 All-In-One Printer
MF5770 ck paper size- change paper size
Go to the queue of print documents and continue deleting them until you get a message that reads no more in the queue. That will clear the error and then you should be able to resend with the correct paper size.
In our case the correct paper size was selected and received this error.
Jun 01, 2008 | Canon imageCLASS MF5770 All-In-One Laser...
Canon P27Dh Calculator Logo
old marine
old marine
