Error code 5E keeps coming up on my Samsung SW52ASP washing machine.
Please help? We've already checked the draining pump and it wasn't blocked, the drainage pipe has also been checked for blockages and nothing. There is also a loud clunking noise coming from it and it sounds like it plastic breaking.. Help!!
  • Washing Mach... Master
  • 17,130 Answers
You need to really check the noise from where the correct inference could be made. Seems that the drum or the moving system is under friction and needs a reset.
Posted on Nov 21, 2013
SOURCE: Rattling noise when my samsung
washing machine bangs when spinning
Posted on Mar 17, 2008
  • 236 Answers
SOURCE: Washing machine is not completing it's wash cycle
either you have a blocked hose to the pump or the pump itself is either jammed or the impellor has come off the shaft. either way i think you will need to replace the pump. i presume you managed to get the water out? if so i would say the pump is favourite.
Posted on Mar 16, 2009
  • 9 Answers
SOURCE: HOTPOINT WML 520, water keeps on coming into the
sounds like a fault with the presure system
Posted on Jul 30, 2009
SOURCE: Whirlpool washing machine "clean pump" error light.
take top off machine. look down right side and you will see a disc about 50 mm in diameter, attached to this is a small flexible rubber pipe, take this off at the disc and blow through it,( you will need some type of pipe to connect to the rubber pipe).this worked for me with the very same problem.
Posted on Mar 13, 2010
SOURCE: samsung WF7708N6W not draining. code 5e & 4e
code 5e showen washing want spin
Posted on Aug 15, 2010
5e error code
Samsung Washing Machine cleaning the pump & coin trap ...
? 5:11
www.youtube.com/watch?v=OofFb280Cn4
Jan 15, 2012 - Uploaded by whichwasher2007 Samsung Washing Machine cleaning the pump & coin trap .....you could try installing a new pump to avoid the 5E error, fixing the pump will ...
Sep 19, 2015 | Washing Machines
Samsung SW60ASP washing machine won't spin or drain
5E is a Drain Error Code.
This can be caused by a clogged filter in the washing machine or a blocked drain line in your house. There can be a few other reasons, but these are the most likely.
If you would like to try to repair it yourself, then follow these instructions:
UNPLUG the washing machine. Repeat, UNPLUG the washing machine!!!
Check the filter in the back of the washing machine on the bottom right-hand corner. Place a shallow dish under the filter. Loosen the filter to drain out the water. Remove the filter and clean it out. Look at where you removed the filter and you will see the water pump impeller. Make sure it can move and isn't locked up. Remove any debris from the impeller.
Replace the filter, and plug in the machine. Try a short wash cycle.
Check for leaks around the filter.
Mar 11, 2013 | Washing Machines
I have a Samsung front loader. It has been stopping with the error code 5E (filter problem ) for a few months now. Turning the machine off then on again after 20min gets it going again. The fault always...
The 5E error mean:
Pump won’t empty - not draining
As usual with these error codes for not draining the first thing to do is check the pump filter but, on Samsung washing machines, the drain pump itself is often faulty. You can find how to fix this problem on youtube, just text it "Samsung washing machine 5E error".
May 16, 2017 | Samsung WF520ABP - 5.0 cu. ft. Steam...
I HAVE BOUGHT SAMSUNGWA80V3 TOP LOADING WASHING MACHINE. I AM GETTING ERROR 5E and WATER IS NOT DRAINED OUT.PLS ADVICE.
this error comes if waste water pipe jammed or blocked
2. WATER DRAIN ERROR - Display shows 5E.
5E is displayed if the water level frequency detected is 25 KHz or less in the initial phase of the UNB -detecting cycle. The Water Drain error can be cleared by turning POWER SW OFF and back ON.
check the drain pipe that comes out the back of your machine
please message me back if this does not solve your appliance situation and please remember to rank how this opinion has helped Thanks again
Rick
Nov 09, 2010 | Samsung Washing Machines
I have a 7kg front loader which was half way through a cycle before stopping. It makes a warning noise and then SE or 5E flash on the display. It won't spin or drain and now I cannot open the door to get...
Hi dear.5E code meaning on Samsung washer's,DRAIN fault.1-Please check drain hose for kink or clogged where it gets end.2-Please slowly open the machine's filter & drain the water inside the washer.Take out the filter & check it,if there is any thing blocks the filter or pump,try to clean it & put it back.It should comes back to normal.(If non of that's happening you might have defactive pump,call service centre.)Run the spin program & make sure it's draining now.I hope that helps.Thanks.
Aug 29, 2010 | Samsung WF337AA Front Load Washer
Getting error 5e WF7708 samsung front loader. Have cleaned all filters nothing appears to be blocked. But it will not finish a cycle.
A 5E code means that the drain pump is iether clogged, with lint, impeller damage, drain hose clogged, or a loose connection on the pump connectors
Jan 06, 2010 | Samsung Washing Machines
Samsung b1245s washing machine
The error code HE2= water heater error (The heater element did not getting hot)
Unplug the machine to reset this error.
Try different cycle let see you still getting the same error.
May 07, 2008 | Samsung WF337AA Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
