Question about Xerox DocuColor 5750 Printer
Xerox 5335 error 005-132 - Xerox DocuColor 5750 Printer
What is error 027-502?
Appears to be error message related to networking.
26171215-uilodj0wn3aoics0ffhdkown-5-0.png see page 412 of 454 in the attached manual Xerox WorkCentre 5230A System Administration Manual Page 412
Apr 21, 2016 | Xerox WorkCentre 5325 5330 5335 Black...
Error code 116-330 xerox workcentre 5325
4+power saver button+stop button press&hold then machin on disply hard disk formet then machin off& on Now ready your machin
Jan 10, 2016 | Xerox WorkCentre 5325 5330 5335 Black...
Sln for Xerox wc 5330 error code 092-315
092-315 ATC Fail RAP
BSD-ON: BSD 9.3 - Development and Toner Dispense Control
The frequency at which the ATC Average Fail or the ATC Amplitude Fail has been occurring
has exceeded the threshold value.
NOTE: •
Although this Fault can be cleared by turning the power OFF and ON and it will be possible to output a few sheets of printouts, when this Fault has occurred a certain number of
times, it will no longer be clearable by turning the power OFF and ON. To clear it, clear the
value of NVM location [752-022] (ATC Average Fail) or NVM location [752-023] (ATC
Amplitude Fail) to "0" (
NVM Read/Write). If the machine is not repaired back to normal
status, this Fault will occur again during the operation.
• When turning the power OFF, turn OFF the power switch first and then the main power
switch.
Procedure
Check the following:
• The connection between the MCU PWB
P/J413 and the Xero/Developer Cartridge P/
J615
for open circuit, short circuit, and poor contact
• The Toner Dispense Motor for revolution failure:
Component Control [093-002] (PL 8.2)
• The Toner Cartridge for internal toner blockage
If no problems are found, replace the following parts in sequence:
• Drum Cartridge (
PL 8.1)
• MCU PWB (
PL 18.2)
See Service Manual page 827 (2-831):
https://docviewer.yandex.ru/?url=ya-disk-public%3A%2F%2FEXv3f5bJ9f7WprcvyqxuiVsXMlmyrp4nx2LzJa50u6s%3D&name=Xerox_WC_5335F_SD.pdf&page=827&c=55716712dd0d
Xerox WorkCentre 5335 Family 5325 5330 5335 Service Manual
Jun 05, 2015 | Xerox WorkCentre 5325 5330 5335 Black...
Fault Code: 016-405 Xerox WorkCenter 5335
This FC (fault code) 016-405 means that there is an error with your security certificates on the 5335 .Copy the link below into your browser and type 016-405 in the search field and it will provide guidance on how to resolve this issue.
NOTE When working with security certificates on Xerox equipment it is recommended you call them for support or have your IT person investigate, this is because if you delete any certificates and not initialize them again you can break some custom services installed on your machine.If you;re not sure if you have custom services running please call your IT department or Xerox for assistance.
http://www.support.xerox.com/support/workcentre-5300-series/support/enus.html
I hope this helps ...
Mar 06, 2015 | Xerox Office Equipment & Supplies
Xerox 5325 fault code 124-374
this error is mismatch serial no
go to dignostic mode go to adjusment other re input serial number
Sep 19, 2014 | Xerox WorkCentre 5325 5330 5335 Black...
Pls machin off
Now press & hold 2 minutes 4no button+power saver button+stop button press and then machin on showing hdd formet after some time ready to copy your machin
Aug 21, 2014 | Xerox WorkCentre 5325 5330 5335 Black...
984 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
