Question about Cell Phones
I cant read my brtmk2 thermostat
The dial is just dots not numbers so not sure what heating is set too
3 Suggested Answers
projdoc
  • 2237 Answers
SOURCE: Have a Caple fridge-freezer. dials for both have
large dots are colder.
Posted on Nov 12, 2009
  • 1121 Answers
SOURCE: 2nd Hand simpson 880 dishwasher cant read numbers
is control board problem, also check for mains voltage, normaly is a mains cables problems.
if is +\- 10% tolerance (110V or 220V) of machine supply is ok, then is control board is defective, needs to replace\repaired.
is normal after a storm, some dishwasher (electronic) control boards be burned.
Posted on Feb 14, 2010
After pot of coffee is brewed, the water in the reservoir seems to be overheating. It hisses and continues to come out of the sprayer, and there is a lot of steam coming from where I pour the water in. ...
This sounds like you need the thermostat replaced. Call bunn at 1 800 263 2256 and talk with parts. You need part number 35286.7000. On a VPS the thermostat is in the top of unit. Take the lid off and you will see it. It has a black dial and a silver probe wire coming from it to the top of the tank. It is fairly easy to remove and replace. Unplug the machine first. Unscrew the screw holding the old thermostat in. Then unhook the two wires from it. Take the rubber grommet out of the top of the tank and remove the thermostat and probe(the part that sits in tank) Put new thermostat in. Make sure the new rubber grommet is set at the red mark on the probe wire and then set the bulb into tank. Attach the two wires back onto the new thermostat(does not matter which wire goes where) and secure the new thermostat with the one screw. Make sure the black dial is turned all the way to the left and close the lid. Plug machine back in and wait for it to heat up again. If the water does not heat up enough turn the black dial all the way to the right.
Apr 06, 2013 | Bunn VPS Coffee Maker
Tip
Lux Thermostat 500
The Lux 500 Thermostat is an affordable programmable thermostat that gives you a very easy way to customize your heating and cooling temperatures to your schedule. The programming of this thermostat is easily the simplest that I have found in a programmable t-stat.
The Lux 500 series thermostats are a great economical way to reduce energy and utility expenses by raising or lowering your temperature settings a the times you set. The installation is so easy that most any DIY’er can install this thermostat. It has an easy to read display and the rotary dial makes the programming very user friendly.
A few of the other great features of this unit are, a keyboard lockout, and an air filter reminder.
This thermostat can be used on any 24v AC or 750mV single stage conventional heating/cooling system. Single stage heat pumps without auxiliary heat will also work with this thermostat.
Here is a summary of the features of this thermostat
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
  • 5 - 2 Day programming
  • 4 Periods per day
  • Large easy-to-read display
  • LUX patented user-friendly Speed Dial®
  • Filter usage monitor and alert
  • Default Energy Star approved program
  • Temporary Temperature Override
  • Temperature Hold
  • Keyboard Lockout
  • Temperature Calibration
  • Swing Settings #1 - #9
  • Fahrenheit or Celsius temperature Scale
  • 12/24 Time Format
  • Low Battery Warning Indicator
  • Mercury Free
As you can see this thermostat will give you a lot of great features at an affordable price.
on Jan 16, 2010 | Heating & Cooling
Tip
Rancilio Silvia does not heat.
There is a reset button inside on the front side of the boiler (you have to take the top of the machine off. There are 4 screws and remove the water tank). It is located between 2 black wires and is a red button. Push it in and test. There is also another problem that you might have. If the brew thermostat is bad it won’t heat. To test for this, push the steam switch and wait 15 seconds. Then open the steam knob and push the middle button and see if the water is warm. If it is then you need a new brew thermostat. That is the thermostat that has the red dot on the top. It sets on top of the boiler next to the steam thermostat. If you take the top off, make sure that the machine is unplugged.
If none of these things work check the heating element with an ohms meter. The reading in the terminals should be from 12 to 16 ohms. If no reading the elements is bad and you have to replace the boiler.
on Jan 01, 2010 | Coffee Makers & Espresso Machines
Imperial gas 40 lb fryer, replaced thermostat, now when you set the dial at 250 the oil heats above 375 and keeps climbing. What now?
Sounds like you have installed the wrong thermostat, or it's a bad one... If you need further help, please call us at 888-542-5959. If you have the model/serial number, we can make sure you have the right thermostat and/or get you the right one... Thanks, Susan REO reocincinnati@yahoo.com
Aug 23, 2011 | Imperial IFS40 Deep Fryer
Water doesn't heat up
There is a reset button inside on the front side of the boiler (you have to take the top of the machine off. There are 4 screws and remove the water tank). It is located between 2 black wires and is a red button. Push it in and test. There is also another problem that you might have. If the brew thermostat is bad it won't heat. To test for this, push the steam switch and wait 15 seconds. Then open the steam knob and push the middle button and see if the water is warm. If it is then you need a new brew thermostat. That is the thermostat that has the red dot on the top. It sets on top of the boiler next to the steam thermostat. If you take the top off, make sure that the machine is unplugged.
Jan 22, 2011 | Rancilio Silvia Espresso Machine
I own a White-Rodgers manual thermostat...Type 1F56N-444 (horizontal version). I own a 1-Heat 1-Cool single stage Carrier Electric Heat HVAC system. Pls answer two questions regarding the thermostat: 1)...
No that is an heat anticipator setting that should be set to the same amperage as the gas valve o your furnace.....do not adjust unless you can tell this or you coulld ruin the thermostat...
Jan 04, 2011 | Heating & Cooling
Where is the thermostat located in a 2001 BMW 325i? Would a bad thermostat cause the heater/air conditioner blower to not function?
The themostat is located on the front part of the engine next to the water pump (black peice of plastic with two hoses on it). If the thermostat was bad, you would have overheating issues going on.
This my sound simple but I have to ask, have you messed with the dial between the two grills over the radio? Max heat would be 3 red dots while max cold is 3 blue dots. If it's in the middle with no dots then that may be your problem.
Dec 13, 2010 | 2001 BMW 325
Nikon FG Exposure Compensation Dial
try to set the itty ***** red dot to 0 again make sure the collar goes down its the compensation mode once its down try turning the speed dial again i haven't had a film camera for about 8yrs i had a nikon 6060 which is almost like a fg . hope this helps
Jan 03, 2009 | Nikon FG 35mm SLR Camera
Heater will not stay lit on auto procom ml 300 blue flame
If you have an ML300HGA, it is a manual-control heater, which means you turn it on and you turn it off. No thermostat. It does not have an AUTO setting.
Likewise, the thermostat-controlled models do not have a Manual mode. If you have the ML300TBA, it has a thermostat and will turn itself on/off in order to maintain a room temperature.
On manual models, the numbers (if any) on the dial are heat output selections. Set the control to the highest heat setting and that's what it does until you turn it off.
On automatic thermostat models, the numbers on the dial are temperature selections. Set the control to the highest heat setting and the heater will continue running until it is 85-90 degrees, then shut off. Set it around 2 and it will maintain a temp of around 70 degrees.
All Procom heaters are either automatic (thermostat-controlled) or Manual. None are both.
Oct 05, 2008 | Procom ML300HGA Heater
Cell Phones Logo
18 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
