Siemens d 12 52 error code f26
The machine starts going without having to press start
  • 16 Answers
SOURCE: F26 Error - Door Switch?
when you hear clicked can you open the door?its should be locked...
Posted on Oct 13, 2008
  • 296 Answers
SOURCE: What does F26 mean
Hi, Well The error F26 does indicate a fault in the door switch circuit. There is a door unlock error that would display if the door is not locking or unlocking but the F26 means the control is not seeing the door switch open and close.This is most likely a problem with the door switch or a loose connection at the switch.
One thing to try first before scheduling service or replacing the part is to check the connections on the door switch.
You can unplug the washer first and remove the lower access panel and reach up to the door lock and try to feel for the connections and make sure they're tight.
Thanks! mannu_rakesh
Posted on Sep 12, 2009
blueextc3221
  • 15935 Answers
SOURCE: What does error code F26 mean?
DOOR SWITCH ERROR
If the door has not been opened for 3 consecutive cycles or the door switch is open while the door is locked for more than 5 seconds.
Possible Causes/Procedure
-Door not opened during 3 consecutive cycles.
1. Open and close the door.
2. Verify CCU operation by running a Diagnostic Test or any cycle.
-Door switch open while door is locked.
1. Push the door and check if it is completely closed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.$$$$
Posted on Sep 28, 2010
blueextc3221
  • 15935 Answers
SOURCE: I have a Kenmore washer HE2 plus and F26 is flashing
DOOR SWITCH ERROR
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.%%%%
blueextc3221
  • 15935 Answers
SOURCE: whirlpool wfw8500sr01 door locks and does not
DOOR SWITCH ERROR
Thanks for using FixYa&^%
Posted on Mar 04, 2011
Codes f26 and then f27 for maytag model MFH 0710
F26 code may appear the first time you try to use the washer. Open and close the door to clear the display.
The F26 code may also appear if the washer has run three cycles without the door being opened. Open and close the door to clear the display.
If opening and closing the door does not remove the error display, press Pause/Off or Pause/Cancel twice.
If Pause/Off or Pause/Cancel does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start. unsure of f27
Dec 23, 2016 | Maytag Washing Machines
What does f26 mean for siemens washing machine
F26 come up This error code indicates that the door needs to be opened and closed.The F26 code may appear the first time you try to use the washer. Open and ...
Jan 03, 2016 | Siemens Washing Machines
SIEMEMS WASHING MACHINE ERROR CODE F:26?
F20-30 is drain or intake
and can be within a given time
so can be something inside the pump or drum skin
or a bad intake valve filter ...
try reading the user manual
look at the makers site i found it easy...
and it has the error code list
your lazy or not looked...
youll find the info you need
try this also from a similar issue
http://www.manualslib.com/manual/770034/Siemens-Wfxd8400uc.html?page=34
look at the ' water does not enter the machine'
cross reference with other machines that c=share the same controllers
here is the answer i found about F26
The error F26 does indicate a fault in the door switch . There is a door unlock error that would display if the door is not locking or unlocking but the F26 means the control is not seeing the door switch open and close.
interlock
or a loose connection at the switch but not likely
its more likely a burned connection
and has high resistance so you perhaps need to check out the wires plug.. etc make sure the contacts are very good
The door switch is part of the door lock assembly part number 8183270 {not sure this is right}
this info is from a maker that uses the same chassis
not the same parts number
its prob the door switch ....!!!
Aug 17, 2014 | Siemens Washing Machines
F26 washing machine Siemens s1272
The F26 error code on the Duet washer is a door switch error.
Disconnect the unit for 10 minutes and plug back in to power.
Check the display for any kind of power indication.
If you have any leds of power indication, try adjusting the door switch.
May 07, 2014 | Washing Machines
My maytag commercial washer display a code F26
The F26 code may appear the first time you try to use the washer. Open and close the door to clear the display.
NOTE: If the error remains on the display, and the condition above has been checked, call for service.
Oct 23, 2012 | Washing Machines
Error code F26
If opening and closing the door does not remove the error display, press Pause/Cancel twice
Oct 22, 2011 | Whirlpool WFW9200S Front Load Washer
Fault code f26
Jul 30, 2011 | Maytag Washing Machines
Washer says f26 and won`t spin the clothes out. is there anything i can do?
If opening and closing the door does not remove the error display, press Pause/Cancel twice.
The above procedure is the specified way by whirlpool technicians to clear the error code.
Feb 02, 2011 | Washing Machines
What does F26 mean
Sep 11, 2009 | Washing Machines
Washing Machines Logo
54 people viewed this question
Top Washing Machines Experts
