Question about Nespresso Romeo E350 Espresso Machine
Nespresso Romeo - Need to reset to factory settings
2 Suggested Answers
micromatikal
  • 2777 Answers
SOURCE: I need the instructions for
It is fairly complicated, but luckily I found the manual for the device that goes into detail on exactly how to descale it. You want to go to page 8 of the manual. I will provide the manual at the end of my answer here...
Please make sure you rate my answer 4 thumbs up, it is extremely important to me. I would be forever grateful if you could do so. If you need more help on this question please just respond to my answer here and I will get right back to you.
http://www1.nespresso.com/precom/sav/pdf/HD_RO_en.pdf
Thanks
Tim
Posted on Oct 13, 2010
1.My Nespresso Pixie Lights never stop flashing. 2. I also want to reset to factory settings because the cup portions are off. 3. I feel the water temperatures is never hot enough for the coffee
1: Depending on how long you've had your machine, it may need descaling. The machines are preset for hard water - if you're in an area with soft water, try pressing and holding the Lungo button while you turn the machine on. Hold until the lights stop flashing.
2: The Pixie can be reset to factory settings by holding both buttons down before and when you turn the machine on, again until the lights stop flashing - this will reset to factory settings.
3: The temperature is preset to be the optimum temperature for the extraction process. If, after following the above steps, the temp is still too low, call the Nespresso Club and they will advise you.
Hope this is of help to you!
Mar 18, 2015 | Nespresso Coffee Makers & Espresso...
My nespresso stops half way though making a cup of coffee and have to press the button again repeatly to start it again
Has anyone operated your machine that was unfamiliar with the correct method. It sound as though the quantity has been reset. Try holding both buttons down while turning the machine on - hold till buttons stop flashing. This will reset to factory settings. Then, you can programme each button by holding it down whilst extracting, then releasing when the correct amount is extracted. It will remember this until you return the machine to its factory settings as above.
Hope this helps!
Mar 12, 2015 | Nespresso Coffee Makers & Espresso...
My nespresso is only creating 3-4 oz of coffee using the 6 oz button. Have descaled with no change. Any ideas?
Try holding both the buttons down and then turning the machine on while still holding the buttons till they stop flashing - usually about 2 - 5 seconds. This will reset to factory settings. Then you can reprogramme the Lungo button if necessary, by holding it down white the coffee is being extracted, till the amount you want is processed. The machine will remember this till you reset to factory settings.
Dec 06, 2014 | Nespresso Citiz C110
No water flow
i need any vodio abut this machine to see how work
Jul 20, 2014 | Nespresso Romeo E350 Espresso Machine
My romeo nespresso wont leave the descaling mode
"DESCALING" is not a "mode." When the display says "DESCALING," it means that it needs descaling. Follow the directions in your instruction manual.
Magimix M190 CITZ
Are you using genuine nespresso capsules? Are they seating properly. Open the slot where you put the capsule in and check its very clean and nothing is stuck in there.
Have you tried resetting to factory settings?
Apr 03, 2014 | Nespresso D300 Espresso Machine
I want to reset Nespresso citrix d 120 to Factory settings.
Try this:
http://search.aol.com/aol/search?&s_qt=sb&q=hespresso+citrix+d120+reset+factory&tb_oid=07-01-2013&s_it=amonetizetest1-ie&tb_mrud=07-01-2013&tb_uuid=20130107163427450
Dec 30, 2012 | Coffee Makers & Espresso Machines
I need the instructions for descaling the Nespresso Romeo E350 Espresso Machine, I have the descaling solution but not ... Solve It! Solve It! ...
Thanks
Tim
Oct 13, 2010 | Nespresso Romeo E350 Espresso Machine
What does F8 mean on display
the capsule dispenser is jammed. shut down the system using the button on the lower right side of the unit. when you turn the unit back on, the system will reset and it will fix itself. (courtesy of my brilliant husband)
Jan 03, 2009 | Nespresso Romeo E350 Espresso Machine
Nespresso C1OOB not sucking water out of the tank anymore
I had the same issue and spoke to Nespresso this morning.  To solve this you need to reprogram-put a capsule in the slot and place a cup on the drip tray-press and hold the lungo button until the coffee has reached the desired height in the cup and then release the button.  That should work and every time you make a lungo cup it should be that amount. Hope this was helpful.
Oct 19, 2008 | Nespresso C100B Essenza Single-Serve...
Nespresso Romeo E350 Espresso Machine Logo
32 people viewed this question
Top Nespresso Coffee Makers & Espresso Machines Experts
Joseph Hoffmann
Kolbrun...
Jay Finke
Jay Finke
Are you a Nespresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
