Question about Car Audio & Video
Boss 658ua wich speaker wires are hot and wich are grounds
4 Suggested Answers
TJBENGR
  • 121 Answers
SOURCE: car stereo
Sorry not all vehicle manufacturers use the same color codes, however your radio wants to know if the lights are on (to dim for night time), and also how dim you desire. Often more than one ground, also could be antenna up/down request.
Posted on Apr 21, 2008
  • 55 Answers
SOURCE: how to wire a vintage pioneer supertuner kp-500
THAT IS AN OLD RADIO....RED POWER .... HARD TO SAY ABOUT AMPS LOOK ON THE RADIO IT MAY SAY TOTAL AMPS....I WOULD SAY (APX 5 AMP) START WITH THAT .
BLACK .......YES GROUND FOR THE POWER ...AND ALSO FOR THE GROUND FOR THE 2 SPEAKERS
SO .....GRAY&BLACK SAY LEFT SPEAKER
AND....GREEN&BLACK SAY IS YOUR RIGHT SPEAKER IT EASY GOOD LUCK
Posted on Feb 21, 2009
logosc75
  • 625 Answers
SOURCE: when hooking up radio i hook up the ground wire
Your vehicle may have a factory amp that needs to be powered up.
Posted on Sep 25, 2010
No sound
This is one unit that doesn't seem to have a manual findable online but I did manage to find some vids that may help here:
https://www.google.com/search?q=boss+658UA+manual&hl=en&sa=N&source=univ&tbm=vid&tbo=u&ei=eelbUY2nKoHW9ATjwIDwDg&ved=0CHgQqwQ4Hg&biw=1440&bih=756
I hope this helps.
Mar 31, 2013 | BOSS AUDIO SYSTEMS Music
Hi there...i'm having a little problem installing my pioneer avh-p6600dvd unit...couple questions. I can't seem to identify the accessory line for the unit what color is it? Do i still need the brain even...
on the back end of the deck there are a series of wire thats attached to a push-in plug.you will find:
plain yellow-wich goes to permanent live(12-14v)
red -wich allso goes to permanent live(12-14v)
black-wich goes to ground/earth
light green-wich goes to ground/earth
blue and white-wich goes to the ignition wire of your vehicle(remote)
2 x green(rear speakers)
2 x purple(rear speakers)
2 x white(front speakers)
2 x grey(front speakers)
Mar 06, 2011 | Pioneer AVH-P6600DVD Car DVD Player
I would just like to have the wiring diagram for the Boss AVA 9060 model. Thanks!
wires are: red-ignition, yellow-battery or memory, black-ground, blue-remote for amp or antenna, orange-illumination (if it has one), the white, grey, purple and green wires are the speakers
Sep 17, 2010 | Boss AVA-9060
High pitched noise coming from speakers after installing stereo
check your wires if they are too near some big power wires and move them away from these high powered wires or check your grounds and make sure its a good ground by scrapping the connection until bare metal. Also its a possibility rca's or wires are getting pinched or not fully connected.
Apr 05, 2010 | Boss BV9560 Car Video Player
Which are the 12v wires on my car?i have a 1994 volvo 850 and am lost on where to start wiring my new radio wich wires go the power and wich goes to the speakers?
All the qires on your vehicle are 12volt.
Be careful on that. Seakers don't take voltage.
The red wire is normally the power wire to the radio, it is also bigger than the speaker wires. The Black wire is normally the ground for the radio and is also thicker and must be screwed to something on the dash board that is metal and a good ground Now all that is left are the speaker wires and you just match them to the ones you want.
Nov 14, 2009 | 1994 Volvo 850
How to wire a vintage pioneer supertuner kp-500
Feb 21, 2009 | Car Audio & Video
1996 chevy 1500
with the ignition in the "off" position get a test light and touch one wire at a time while cycling the ignition switch to the "on" position, When you see that the test light goes off when the ignition switch is in the off position then you found the hot wire, make sure you dont hook it up to the "alway hot " wire or you might drain the battery hope this helps.
Oct 18, 2008 | 1996 Chevrolet Express
Pioneer car stereo-how to hook up speaker wires
ok u have 8 wires because the other wire is just a ground.as long as u ground the other wires u should be fine. ok the wire that is marked ign. wire may be your mem.wich usally hooks to an orange wire the hot wire u have is just what it says hot that comp. at the end i blieve was a fuse .it sounds like the other part is missing.
Oct 01, 2008 | Pioneer AVIC-D2 In-dash Car Audio Stereo...
My Boss Amp keeps cuts off when I play the music from my stereo
check your ground wire and your remote wire, Wiggle them separately both at the amp and at the ground point. See if it cuts out then, and you;ll know which one. Also, does it have a light on it when it cuts out? if so, it could be going into protect mode, which wont allow it to turn on for a period of tine. Make sure the amp is not too small for the speakers you are pushing.
NGK
Sep 03, 2008 | Boss Car Audio & Video
Car stereo
Apr 21, 2008 | Car Audio & Video
Car Audio & Video Logo
22 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
