Question about RCA F25422 25" TV
Cable Input (Tuner)
Where can I find "Tuner" CTF5800 21027220 for RCA Model F25422 Serial Aa504b23818. Parts lists are woefully lacking.
  • Frank Thompson Oct 08, 2007
    Cable connector is broken off the box. Pulled anb broke wires and coils inside. Looking for replacement.
Call tiptop tuner 818 3451974or go to wwwtiptoptuner.com
Ben.
Posted on Feb 18, 2008
    Genius:
  • 1,694 Answers
The "tuner" is an intregal part of the mother board.It cannot be
purchased seperately.A new connector can be installed even
with mangled tuning coils. RCA part # 215543.....T
Posted on Oct 25, 2007
  • 790 Answers
Why? and what is your main problem? can you wright your problem please!
Posted on Oct 08, 2007
I have serial #107611268,model # f27668,classic #ctc203aas..i need to change from cable to antennae and can nit get any channels to list
This is an analog tuner tv,there are no OTA analog tv transmissions you need a digital converter box btween your antenna & tv
Aug 02, 2013 | RCA Televison & Video
I have a Panasonic 32 inch TV, Model CT-3268SV, Serial MD73150155, the terminal that is in the back of the TV, where you connect the cable is broken, I need to replace it, the part number listed is EN
The input socket [RF input] is the part of the tuner. If it has been broken, you have to replace the tuner. It is a box type unit, and can be bought from most of the electronic spare part selling shops at your town.
Jan 28, 2013 | Panasonic CT-20D11 20" TV
How do I connect my CD Player, Tape Deck and Tuner to the SU 300 Technics Amplifier
hi,
For connecting these to your amplifier you need 4 Stereo RCA Cable.
1.Connection for cd:
Take one of the RCA cable connect the one end (red/white) jack to the line out of your cd and connect the other end (red/white) to the CD input of Your amplifier.
2. Connecting the tunner:
Take one of the RCA cable and connect the one end (red/white) jack to the line output of you Tuner and connect the other end (red/white) to the TUNER input of your amplifier.
3. Connectiong the tape deck:
Now you have two RCA cable. Take one of the RCA cable and connect the one end (red/white) jacks to the PLAY out of the Tape deck and connect the other end (red/white) to the TAPE 1 play input of your amplifier.
Now connect the last RCA cable. Connect the one end (red/white) jack to the record input of the TAPE deck And connect the other end (red/white) to the TAPE 1 Record input of your amplifier.(this connection will help you to record to tape from cd or tuner. if you are not interested in recording then you can avoid this connection.)
Now you can select these three items from the frond plannel control switch of the amplifier.
ok
Jul 28, 2011 | NAD 218THX 2-Channel Amplifier
How do i get dish network to work on rca f25422 tv
Well, you have a couple options with this. You can use either coax cable, or RCA cables. If you use coax, you want to connect it on the receiver that says TV set out, and out the tv set on channel 3 or 4. If you use RCA cables, you want to connect these to the color coded connections on the back of the receiver labeled with a Green 1. The tv will need to be on channel 3 or 4, and a video in put, usually Video 1 or 2.
Becki Barned
DISH Network Customer Service
Feb 01, 2011 | RCA F25422 25" TV
Input selection between cable tuner and Aux. Input
you need an rca remote with input button. I see rca universals at Walmart and dollar stores for 5.99
Dec 04, 2017 | RCA Televison & Video
I have a rca model number F25422 perfect picture no sound what
I HAVE A 25' RCA WITH THE GUIDE PLUS ON IT. MY DVD PLAYER WILL NOT WORK ON THIS TV. HAVE ALL THE CABLES I NEED(RED,WHITE &YELL) AND THE CONVERTER BOX.
Apr 02, 2009 | RCA Televison & Video
Broken cable hook up
sometimes if the tuner is not damaged then a technician can put it back on... the other option is to tune the channel through a vcr.. essentally bypassing the tv tuner and useing vcr tuner. hook the cable to vcr then using rca jacks yellow red and white connect it to you tv(if it has rca jacks ...most have them these days.. sometimes on front and sometime on back or even on the side.. tune your tv to that input(video 1 or something like that.. then using your vcr remote change channel...its not a perfect solution but it will save you the 130 buck most charge to repair that connector
May 01, 2008 | RCA HD61LPW175 61" Rear Projection HDTV
No input from cable connection
Sounds likely you have a bad tuner. If you have a cable box with your cable service and it is upgraded for video and audio rca jacks output you can run red white and yellow wires to tv input where the DVD is connected or additional jacks if available. This bypasses the tuner
Jan 01, 2008 | Televison & Video
CONNECT CABLE TO MY PROJECTOR
Depending on the specific model of your Mitsubishi DLP, you can have either S video, RCA, VGA or a few other choices of INput connection.
Depending on your cable provider and hookup, you can either have a plain cable with F connector or a cable box normally with RCA connectors and a remote control.
If you have a simple cable connection that attaches direct to a TV (no remote, no box), you would need a TV Tuner to be able to receive the different channels whose output would be a composite video signal into the yellow RCA jack. You would need an RCA to RCA cable to in turn connect it to your Yellow RCA Video INput of the projector. In the absence of a tuner, an old VCR with such a feature would also serve the purpose. In some instances either units may also have an S video connection.
If you have a cable box with with remote, then there is no need for a tuner or VCR since its output would already match the projector's input.
Either way you would need a separate audio amplifier/speaker  for the sound.
Hope this be of some help/idea. Pls post back how things turns up or should you need additional information.
Good luck and kind regards.
Oct 23, 2007 | Office Equipment & Supplies
RCA 52" tv. model # D52W20
The silver box is called the TUNER. Call an RCA distributor, such as Union Electronics or Herman-Panson and order it by description by asking for the tuner for your model number. Have the location number on the board, just in case.
Sep 01, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA F25422 25" TV Logo
186 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
