Bosch exxl 7. When you select a cycle it automatically thinks the cycle has finished
2 Suggested Answers
SOURCE: annoying beep when wash cycle finishes on bosch classixx 1400 express
Starting with the rotary switch in the off position, turn it one click clockwise, press and hold on the bottom right hand button, turn the rotary switch one more click CW and release the button. The number displayed is the volume for button presses, press the centre right hand button to increase/turn off (0). Turn the rotary switch one more click CW to select end of cycle volume, agjust and set the rotary switch to off to leave set up mode.
Posted on Sep 12, 2009
Bosch maxx Classic. 7 yo. Washing cycles are not finishing. Timer is showing 1 but does not turn off. Clothes are still quite wet. Have cleaned filter. Anything else I can do?
Looks like the solenoid that controls the drain motor is malfunctioning.
Whenever this happens, the water does not get drained fully and remains in the chamber thus keeping the clothes still wet.
Speak to your local service representative and get the part replaced.
Feb 22, 2015 | Bosch Washing Machines
My Bosch dishwasher Model #SHX4APO5UC/06 wont finish the cycle and it wont drain. We have checked hoses and they are not clogged. Is it something with the control panel?
Check your motherboard for burnt contacts. Easy to remove in the door. If you able resolder and give it a try. Cheaper then a new mother board.
Aug 11, 2014 | Bosch Dishwashers
F14 fault on Bosch Maxx 7 I have low water power, could this be the problem? Machine bleeped at me then stopped. I have turned my machine off, but the washing cycle had not finished.
Hello
A power glitch may cause this error. Try unplugging the Unit for two minutes to see if that fixes the error.
You may need to restart wash cycle.
Apr 06, 2011 | Bosch Washing Machines
Can't get a Bosch MAXX 5 WAA24161GB to start. Changed fuse and socket, but machine still won't work?
hello, have you checked the glass fuse inside the washer make sure you use the same rated fuse the value will be on the end of the fuse hope it helps
regards
shaun
Mar 06, 2011 | Bosch Washing Machines
Water left after finishing wash
I have a Bosch Dishwasher and the E-Nr is SGS4362EU/03. The machine is approximately 4 years old, in good condition and has been working very well. Suddenly, there is water remaining after it completes a 50 degrees C wash cycle. This is also evident with the pre wash cycle and the 65 degrees wash cycle.
I have checked and cleaned the filters. I have loosened the internal pump white cover (Torx T 20 screw) and checked for any physical blockage - none. I have also checked for any drainage hose kinks - none.
I have tried a series of empty washes and the machine drains the water during the wash cycles. The dishes are also have a dull colour and show show signs of not being properly rinsed during the wash cycle.
Please assist.
Reagrds,
Brian
Dec 27, 2008 | Bosch 24 in. SHY56A05 Stainless Steel...
Annoying beep when wash cycle finishes on bosch classixx 1400 express
Dec 06, 2008 | Washing Machines
Very annoying beep when finished programme
When the machine is on, but not running, press and hold the "pre-wash" button. After a few seconds it will begin that beep noise, keep holding it in until the beep volume goes down and finally stops completely (5-10 secs). Once the beep has stopped, release the button and voila, no more annoying beeps at the end of your cycle.
To restore the end of cycle notification (beep) do the same thing as described above, but release the button earlier while the beep is still going.
Nov 23, 2008 | Bosch Classixx WFL 2066 Front Load Washer
Bosch axxis door won't open
michele99, So when you put it on drain, do you here the machine trying to drain the water? After it finishes draining, (you have to wait a few minutes, it should then have a blinking light
on the Finished/Door locked light.
Are you waiting for it to finish?
May 08, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Bosch dishwasher
is all the water draining from the tub? if not the pressure switch will not reset and it will continue to try and clear it self...check drainage system.
2. pressure switch is jammed on..build up in the sensing chamber..common..or switch faulty...rarely
3. if water is in the bottom panel most have a flood switch which automatically operates the pump in case its over filling
Dec 04, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Washing Machines Logo
15 people viewed this question
Top Washing Machines Experts
