Question about Kenwood KVT-514 Car DVD Player
Reset button on model kenwood 514 - Kenwood KVT-514 Car DVD Player
Help me crack the security code on my kenwood KVT-514 DVD car stereo????
Here's a video tank daWG suggested as a solution to your problem from YouTube:
how to unlock code kenwood stereo.3gp
Mar 23, 2013 | Kenwood KVT-514 Car DVD Player
How can I update tha software for keenwood KVT-514
Try this link. http://www.helpowl.com/p/Kenwood/KVT-514/Research/53126?search=Kenwood+Kvt-514+Update&x=79&y=17
Feb 17, 2013 | Car Audio & Video
My Kenwood kvt-514 is not turning on
unplug the battery wait ten seconds plug it back in....
Aug 10, 2012 | Kenwood KVT-514 Car DVD Player
Codigo de seguridad de kenwood kvt-514
buenas,, hace tiempo compre un repro kenwood kvt-514 y al encenderlo me sale en la pantalla CODE SET y no tengo el codigo,, hay manera de desbloquearlo sin el codigo que me solicita...???
Mar 20, 2012 | Kenwood Sirius KDC-MP522 CD Player
How to pair your phone to the bluetooth on th kenwood kvt-514
Go into your Setup menu and scroll down to bluetooth settings.
From here you should see a screen that says "HFP connect device", "A2DP connect device" and "Receiver pin code".
Press the "Set" button to the right side of "A2DP" and it should bring you to another screen that says Pair device.
Go onto your phone settings and make sure you have your bluetooth setting on your phone set to "make discoverable"
Press the search button on the Kenwood unit on the right side and it will start scanning for available devices in the vicinity
Also press the Search button on your phone so it also starts scanning.
Next you should get a message on both your phone that shows the Kvt-514 and also a message on the Kenwood that shows either the model of your phone or your "nickname" (if you named your phone)
Select the Kvt-514 on your phone and it will prompt you for the pin code that was on the first bluetooth setup screen...most likely 1111 (you can also set a different pin code using the "set" button to the right side of the "Receiver Pin Code" on the first bluetooth setup screen)
Enter the Pin code and select "Pair" on your phone.
You should get a confirmation on both the Kvt-514 and your phone that they are connected and you're good to go.
Apr 02, 2011 | Kenwood KVT-514 Car DVD Player
Kenwood kvt 514 can't turn on the sub
in the main option menu for choosing tuner dvd video etc. scroll down one and youll see "standby" put that on then scroll through the options and turn on the sub
Jun 28, 2010 | Kenwood KVT-514 Car DVD Player
How to unlock code for kenwood kvt-514
Did anyone ever figure this out? I need to know also
May 16, 2010 | Kenwood KVT-514 Car DVD Player
Reset dlink 614+ router, forgot password
I don't know for the 614 as there isn't a model like that... Your picture shows a DI-514. Here is the process for that model.
To hard-reset the D-Link Plus DI-514 to Factory Default Settings, please do
the following:
• Leave the device powered on, do not disconnect the power
• Press the reset button and hold (use a paper clip)
• Keep the button pressed about 10 seconds
• Release the button
The DI-514 will then automatically reboot itself.
If you truly have a 614, can you post more about the model number? It's usually written on the bottom of the router.
Aug 30, 2009 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
Kenwood KVT-514 Car DVD Player Logo
26 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
