Question about Merits P-327 Vision Super
Wrench Flashes 8 times - Merits P-327 Vision Super
What does eight flashes of the wrench indicator mean on the invacare Pronto m 41 power chair
A flash code of 8 indicates a computer controller problem. Check all the connections at the controller under the rear cover. A rebuild or replacement of the controller is probably necessary. Hope this helps.
Jun 10, 2016 | Invacare Health & Beauty
Catalina powerchair 8 wrench flashes
8 flashes on a invacare means controller fault,please contact dealer,and have a tech look at first so they can ordor u one,recomdation take chair to dealer if u can will save u money on a house call
Dec 21, 2013 | Electric Mobility Pronto M41 Power Chair...
A wrench light is on the indicator and the chair will not drive. Help! Thanks, Michael
When you turn the chair on and move the jostick the wrench light will flash you need to count the number of times it flashes to determine whats wrong ie 4 flashes pause 4 flashes pause. If its 4 flashes then you have a motor problem see my tips on flash codes to determine the problem. Whatever the problem is you will have to have the chair fixed by a tech or the provider that sold you your chair Hope this helps
May 31, 2011 | Electric Mobility Invacare Pronto M41...
I have a golden companion scooter and it wont move it flashes a green light but i haave no info on where to obtain the trouble codes
The L.E.D. located on the tiller
dashboard will indicate with flash codes what problem is occurring.
L.E.D. Flashes 1 time and pauses, 1 time and pauses…. Batteries are low,
scooter will still operate.
L.E.D. Flashes 2 times and pauses, 2 times and pauses…. Batteries are very
low, scooter will not operate.
L.E.D. Flashes 3 times and pauses, 3 times and pauses….Over voltage to
controller.
L.E.D. Flashes 5 times and pauses, 5 times and pauses….Brake is in the
freewheel position or connection to brake is open.
L.E.D. Flashes 6 times and pauses, 6 times and pauses….Paddle or speed
potentiometer problem.
L.E.D. Flashes 7 times and pauses, 7 times and pauses….Paddle or speed
L.E.D. Flashes 8 times and pauses, 8 times and pauses….Motor
disconnected or faulty.
L.E.D. Flashes 9 times and pauses, 9 times and pause….Controller fault.
I hope this helps they are pretty standard codes I got this from Golden Tech Web Site
Aug 17, 2010 | Golden Technologies Golden CompanioN II -...
How to change the spark plugs
if its your first time you need a haynes repair manual.you need a spark plug boot puller.you need 3/8 ratchet wrench.spark plug sockets.from size 5/8 to 13/16.you probably need size 5/8 socket.you need extensions different sizes.and universal joints.to reach hard to get plugs.you need torque wrench. and spark plug gap set.
Jul 07, 2009 | 2002 Kia Sportage
'99 Mercury Cougar - Seatbelt light flashes 8 times in pattern
? I wounder what color is your lamp - red or yellow (amber) and just so you know most parts stores now days can tell what a code is with out charging a dime to you.
Apr 28, 2009 | 1999 Mercury Cougar
Toshiba 1360 copier
Turn it on holding down 0 and 8. Key in 89, press start. press 0, press start. Turn it off and on.
Mar 18, 2008 | Toshiba 1360 Black and White Copier
Merits P-327 Vision Super Logo
Top Merits Health & Beauty Experts
Ngoro
Ngoro
Robin Hill
Robin Hill
Are you a Merits Health and Beauty Expert? Answer questions, earn points and help others
