Question about Maxtor OneTouch III 300GB 7200RPM Firewire/USB 2.0 External w/16MB Buffer Retail ***Free ... 300 GB Hard Drive
Can't backup I am unable to backup. I get a error code 2005. when I click backup now it automatically says backup complete and does not do a backup.
    Scholar:
  • 113 Answers
You need to sepecify which files in your system it can backup ;) this is found in the tools bar. good luck
Posted on Oct 09, 2007
SOURCE:
Need command prompt for Acer Aspire
The Windows Backup and Restore feature allows you to save files and system images to external backup devices such as hard drives and flash drives. However, backing up files become problematic if the directory your backing up files from isn't configured properly, or if you're having issues with the devices you're backing files to. There are ways to solve or work around backup problems quickly and safely.
Hard Drive b> A backup will not complete if the files you're backing up exceed the amount of space left on the external hard drive. If you're backing up large system files, Microsoft recommends saving the backup to an external hard drive that can hold at least 200 GB. If you're running out of space, you must delete content to create space for others or use another hard drive. Error Codes In some cases, Windows displays the following error codes when it's unable to complete a backup: "0x80070001 (Invalid Function)" or "0x81000037: Windows Backup failed while trying to read from the shadow copy on one of the volumes being backed up." These error messages usually appear if Windows is unable to backup a specific library or if you opt out of adjusting your backup settings and settle for the default settings in the Windows Backup and Restore Feature. Reparse Point b> If you're unable to backup a specific library and run into error code messages, removing the reparse point allows you to complete the backup. A reparse point is a file that contains information about the user on a computer. If it doesn't point to a location that contains some of the data you want to backup, error messages appear when you try to back up your files. Type "CMD" in the Start Search box to open the Command Prompt. In the Command Prompt, typing "DIR /AL /S" and pressing Enter lists the reparse points. Each entry says "JUNCTION," which also means reparse point. The entries also tell you the location of the reparse points in Windows Explorer. If you locate a specific reparse point in Windows Explorer, delete its mounted volume from the device's Properties. Once deleted, you should be able to back up your files. Discs b> If you're backing up files to a disc, you'll run into problems if the discs are non-rewritable and already contain data, or if they are severely scratched or damaged. Non-rewritable discs can only be used once, while rewritable discs can be used to read and write data several times. If the CD or DVD you're using is severely scratched, the optical disc drive spins harder than usual in an attempt to read it. If it's incapable of reading the disc, the backup feature may freeze or display an error.
Windows backup or restore errors 0x80070001, 0x81000037, or 0x80070003
http://support.microsoft.com/kb/973455 - workaroundissue12
Apr 20, 2013 | Computers & Internet
Hello i have a problem with my nokia 3110c whitch is : when i flash my phone with phoenix i got this result : Flashing started Creating product data items list Product data items list created Backup...
Now what is the condition of the phone ? If the phone has still problem, uninstall the previous file you have installed and re-install this one3110c file.Select the product code 0544311 or 0556977.This two files can use universal.Use fully charge battery or insert charger when message prompt.I hope there will be no error.Thanks good luck.
Aug 16, 2011 | Nokia N70 Cellular Phone
Jvm error 547
Here is the procedure to resolve:
Step #1
Before starting make sure that BlackBerry Desktop Software is installed on the computer.
Step#2
Make sure that you have installed updated device software installed in your PC.
Step#3
Users can perform a full or selective backup of the data using the Backup and Restore tool in BlackBerry Desktop Manager by completing the following steps:
Connect the BlackBerry device to the computer running BlackBerry Desktop Manager.
Open BlackBerry Desktop Manager.
Double-click Backup and Restore.
Select Backup to perform a full backup or select Advanced to perform a backup of specific databases.
Choose a location to save the backup file, then click Save.
Step#4
To perform a clean install of the BlackBerry Device Software, perform the following steps:
Connect the BlackBerry smartphone to the computer and open BlackBerry Desktop Manager.
Double-click the Application Loader icon.
Click Next to start the installation process.
Type your BlackBerry smartphone password, if prompted, and click OK.
Click the check boxes next to the names of the applications you want to load, and then click Next.
Click Advanced, and then click the check box beside Erase all currently installed applications.
Click Next.
Click the check box next to Do not automatically backup the application data during the loading process.
Clear the box next to Backup and restore applications installed wirelessly.
Click Next > Finish.
When the process has completed, the message The loading operation was successful will appear. Click Close to return to BlackBerry Desktop Manager.
Jan 18, 2010 | RIM BlackBerry Pearl 8100
ITS JUST STUCK ON THE SCREEN I CANT DO ANYTHING MY BLACKBERRY CURVE 8310 IS STUCK WITH THE ERROR CODE JVM ERROR 102
The BlackBerry smartphone stops responding, and the "JVM 102" error message is displayed:
JVM 102 error occurs when there is an issue with one or more of the .cod files installed on the BlackBerry smartphone.
To resolve this issue, perform a clean reload of the BlackBerry Device Software on the BlackBerry smartphone using the application loader tool.
Before proceeding, make sure that the latest version of BlackBerry Device Software is installed on the desktop computer by completing the following steps: To perform a clean installation of the BlackBerry Device Software using BlackBerry Desktop Manager 4.5 to 5.0, perform the following steps: Open BlackBerry Desktop Manager. Click Help. Select About Desktop Manager. Click the Device Software tab. Verify that the BlackBerry Device Software displayed is the latest version currently available from the wireless service provider. Warning: The following procedure will delete either all data, or all data and applications on the BlackBerry smartphone. Back up the BlackBerry smartphone data before proceeding. Connect the BlackBerry smartphone to the computer and open BlackBerry Desktop Manager. Double-click Application Loader. Click Next to start the installation process. Type your BlackBerry smartphone password, if prompted, and click OK. Select the check boxes next to the names of the applications to be loaded, and then click Next. Click Settings, and then select the check boxes beside Delete all application data and Erase all currently installed applications. Clear the check box next to Backup up device data automatically during the installation process. Click Ok > Next > Finish. When the process has completed, the message The loading operation was successful will appear. Click Close to return to BlackBerry Desktop Manager. To perform a clean installation of the BlackBerry Device Software using BlackBerry Desktop Manager 4.1 to 4.3, complete the steps 1-5 above and then proceed with the following: Click Advanced , and then select the check boxes beside Erase all application data and Erase all currently installed applications Click Next. Select the check box next to Do not automatically backup the application data during the loading process (if prompted). Clear the check box next to Backup and restore applications installed wirelessly (if prompted). Click Next > Finish.
I Hope it helped you.
Thank you for using ' Fixya ' and have a nice day!!
Nov 13, 2009 | RIM BlackBerry 7290
I have a BB 8830 World phone and get a JVM Error 513 message. How can it be reset?
This error occurs because all of the data and applications on the BlackBerry smartphone have been deleted.
The BlackBerry Device Software must be reloaded on to the BlackBerry smartphone.
To reload the BlackBerry Device Software you need the complete the following steps:
  1. Open BlackBerry Desktop Manager.
  2. Click Help.
  3. Select About Desktop Manager.
  4. Click the Device Software tab.
  5. Verify that the BlackBerry Device Software displayed is the latest version currently available from the wireless service provider.
  1. Connect the BlackBerry smartphone to the computer and open BlackBerry Desktop Manager.
  2. Double-click Application Loader.
  3. Click Next to start the installation process.
  4. Type your BlackBerry smartphone password, if prompted, and click OK.
  5. Select the check boxes next to the names of the applications to be loaded, and then click Next.
  6. Click Settings, and then select the check boxes beside Delete all application data and Erase all currently installed applications.
  7. Clear the check box next to Backup up device data automatically during the installation process.
  8. Click Ok > Next > Finish.
  9. When the process has completed, the message The loading operation was successful will appear. Click Close to return to BlackBerry Desktop Manager.
  1. Click Advanced , and then select the check boxes beside Erase all application data and Erase all currently installed applications
  2. Click Next.
  3. Select the check box next to Do not automatically backup the application data during the loading process (if prompted).
  4. Clear the check box next to Backup and restore applications installed wirelessly (if prompted).
  5. Click Next > Finish.
Nov 10, 2009 | RIM BlackBerry 8800
Blackberry flip jvm error 545
  2. Click Help.
Warning: The following procedure will delete either all data, or applications on the BlackBerry smartphone. Back up the BlackBerry smartphone data before proceeding.
To perform a full backup of the BlackBerry smartphone data complete the following steps:
  1. Connect the BlackBerry smartphone to the computer running BlackBerry Desktop Manager.
  2. Open BlackBerry Desktop Manager.
  3. Click Backup and Restore.
  4. Select Backup to perform a full backup.
  5. Select a location to save the backup file, and then click Save.
To perform a selective backup for one or more databases perform the following steps:
  4. Click on Advanced.
  5. Select the database(s) on the right side selection window for Device databases.
  6. Select the Arrow that points to the left side of the screen to transfer the database(s) to include in the backup.
  7. Verify the database(s) are on the left side selection window for the Computer databases.
  8. Click on File in the menu located at the top left hand side of the Desktop Manager.
  9. Name the backup file and select a location to save the file.
  10. Click the option to Save once the location for the file is selected.
Once you perform backup procedure, kindly then perform the following steps:
  • Click Ok > Next > Finish.
  • When the process has completed, the message The loading operation was successful will appear. Click Close to return to BlackBerry Desktop Manager.
  • To perform a clean installation of the BlackBerry Device Software using BlackBerry Desktop Manager 4.1 to 4.3, complete the steps 1-5 above and then proceed with the following:
    2. Click Next.
    Oct 22, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
    BB messenger error "Uncaught Exception: java.lang.null...
    When attempting to send messages from the BlackBerry device, the BlackBerry device user receives the following Java error called uncaught exception java.lang.illegal argument exception:
    To over come this error you need to complete the following steps:
    First, perform a full backup of the BlackBerry device data:
    1. Connect the BlackBerry device to the computer using the USB cable.
    2. Open BlackBerry Desktop Manager, and then double-click Backup and Restore.
    3. Click Backup.
    4. Save the backup file.
    Run the application loader tool and erase all data on the BlackBerry device:
    1. In BlackBerry Desktop Manager, double-click Application Loader.
    2. Click Next.
    3. On the Device Security Password screen, type the BlackBerry device security password, and then click Next.
    4. On the Device Application Selection screen, click Next.
    5. On the Completing the Application Loader Wizard screen, click Advanced. The Device Data Preservation screen is displayed.
    6. Select the Erase all application data check box, and then click Next.
    7. Select Do not automatically back up and restore the device application data during the loading process, and then click Next.
    8. Click Finish. The BlackBerry device resets. This might take several minutes.
    Hope I helped you.
    Thanks for using ' Fixya ' and have a nice day!!
    Oct 20, 2009 | RIM BlackBerry 8800
    Its says JVM error 513 reset
    The Blackberry Device Software must be reloaded on to the BlackBerry smartphone.
    1) Open BlackBerry Desktop Manager.
    2) Click Help.
    3) Select About Desktop Manager.
    4) Click the Device Software tab.
    5) Verify that the BlackBerry Device Software displayed is the latest version currently
    For instructions on how to download the latest versions of BlackBerry Desktop Manager
    and BlackBerry Device Software follow the steps:-
    1) Click the BlackBerry Device and Desktop Software link.
    2) Click the Download BlackBerry Device and Desktop Software link.
    3) Select the appropriate software from the drop-down list and click Next.
    4) Click the Download link.
    To perform a full backup of the BlackBerry smartphone data complete the following steps:-
    1)Connect the BlackBerry smartphone to the computer running BlackBerry Desktop Manager.
    2) Open BlackBerry Desktop Manager.
    3) Click Backup and Restore.
    4) Select Backup to perform a full backup.
    5) Select a location to save the backup file, and then click Save.
    To perform a selective backup for one or more databases perform the following steps:-
    1) Connect the BlackBerry smartphone to the computer running BlackBerry Desktop Manager.
    4) Click on Advanced.
    5) Select the database on the right side selection window for Device databases.
    6) Select the Arrow that points to the left side of the screen to transfer the database to include in the backup.
    7) Verify the database are on the left side selection window for the Computer databases.
    8) Click on File in the menu located at the top left hand side of the Desktop Manager.
    9) Name the backup file and select a location to save the file.
    10) Click the option to Save once the location for the file is selected.
    1) Connect the BlackBerry smartphone to the computer and open BlackBerry Desktop Manager.
    2) Double-click Application Loader.
    3) Click Next to start the installation process.
    4) Type your BlackBerry smartphone password, if prompted, and click OK.
    5) Select the check boxes next to the names of the applications to be loaded, and then click Next.
    6) Click Settings, and then select the check boxes beside Delete all application data and Erase all currently installed applications.
    7) Clear the check box next to Backup up device data automatically during the installation process.
    8) Click Ok > Next > Finish.
    9) When the process has completed, the message The loading operation was successful will appear. Click Close to return to BlackBerry Desktop Manager.
    following:-
    1) Click Advanced , and then select the check boxes beside Erase all application data and Erase all currently installed applications
    2) Click Next.
    3) Select the check box next to Do not automatically backup the application data during the loading process (if prompted).
    4) Clear the check box next to Backup and restore applications installed wirelessly(if prompted).
    5) Click Next > Finish.
    Oct 16, 2009 | RIM BlackBerry Pearl 8100
    I need to fix my Jvm error 513 on my black berry
    You will need to re-install the software on the device.
    Here is the procedure to install the software.
    Step #1
    Step#2
    Make sure that you have installed updated device software installed in your PC. Check this link to get update device software from carrier OS download site.
    Step#3
    1. Connect the BlackBerry device to the computer running BlackBerry Desktop Manager.
    3. Double-click Backup and Restore.
    4. Select Backup to perform a full backup or select Advanced to perform a backup of specific databases.
    5. Choose a location to save the backup file, then click Save.
    Step#4
    2. Double-click the Application Loader icon.
    5. Click the check boxes next to the names of the applications you want to load, and then click Next.
    6. Click Advanced, and then click the check box beside Erase all currently installed applications.
    7. Click Next.
    8. Click the check box next to Do not automatically backup the application data during the loading process.
    9. Clear the box next to Backup and restore applications installed wirelessly.
    10. Click Next > Finish.
    11. When the process has completed, the message The loading operation was successful will appear. Click Close to return to BlackBerry Desktop Manager
    Please rate this if it fixes your issue
    Jun 05, 2009 | RIM BlackBerry Pearl 8100
    A window appears with the following message. Time Machine Error Unable to complete backup. An error occurred while copying files to the backup volume.
    It appears to be a scheduled backup task not being completed.
    You can disable the task by going to the backup software and removing the backup schedule.
    I can't tell you the exact procedure since i don't know anything about your system.
    Aug 01, 2008 | Computers & Internet
    Open Questions:
    See all Maxtor OneTouch III 300GB 7200RPM Firewire/USB 2.0 Questions
    Maxtor OneTouch III 300GB 7200RPM Firewire/USB 2.0 External w/16MB Buffer Retail ***Free ... 300 GB Hard Drive Logo
    78 people viewed this question
    Top Maxtor Computers & Internet Experts
    Ekse
    Phil Whisenant
    Phil Whisenant
    Alun Cox
    Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
