Question about HP Deskjet 3512 Inkjet Multifunction Printer/Copier/Scanner
Incompatible cartridge refilled cartridge and now it wont work
5 Suggested Answers
  • 313 Answers
SOURCE: After refilling original HP60XL I get an incompatible ink cartrid
use GENUINE cartrigdges
Posted on Apr 13, 2010
  • 3 Answers
SOURCE: my HP C4480 will not recognize the refilled
These cartridges have expiration dates, they can be refilled until they hit that expiration date, Either go to a real refiller that will put a new chip on the cartridge or take the printer apart and remove the battery inside it, Walgreens doesn't know what they're doing when it comes to refilled cartridges
Posted on May 07, 2010
  • 23 Answers
SOURCE: had printer cartridge refilled but when i put it
I would never use refilled ink. This is a lesson. You can still print, yet the cartridge needs a new "chip" they should have given you when they refilled it. You can try: remove the cart. turn off printer, unplug it, then put old cart back in. Do this three or four times and the memory of the printer can only remember three or four resets and then put refilled cart in. Hope this works for you. I was told this for an HP 7130 (similar, yet older version).
Brock
Posted on Sep 16, 2010
SOURCE: incompatible ink cartridge ho 4500
I have had simlar problems with other brand inks on epson printer a guy in a computer shop were I bought the ink from told me to take the ink out wipe the chip with a clean cloth wipe in one direction, also your ink when new has a piece of thin plastic that now has a small hole in it as you have taken it out from printer put a small piece of sellotape over hole other wise printer will think you are putting old cartridge in again you might need to do this a few times, but bear in mind that this was done with an epson printer but it doe's solve the problem when it crops up from time to time.
Posted on Feb 25, 2012
"Incompatible Cartridge" error
Try uninstalling printer, reboot computer then reinstall printer drivers. do not accept HP updates as they block non HP consumables. Update manually if needs must.
May 09, 2013 | HP Officejet 6310 All-In-One InkJet...
Dell 810 printer showing "Incompatible cartridge" after cartridge
Return it! refilling cartridges often void your warranty. Not to mention the cartridges that come with the printer are usually 1/3 to 1/5 filled making you think that the new ones are over priced. Use original.
Jan 23, 2010 | Dell 810 All-In-One InkJet Printer
I have refillled my printer ink cartridge and it worked now it states it is incompatible. Can I bypass printer instruction
Hp printers cartridges have a circuit, which could be damaged in your case. That is the reason you are getting the error message. However, The use of refilled print cartridges alone does not affect either the warranty or any maintenance contract purchased from HP for its Inkjet printers. Repair will not be covered under the warranty or by the maintenance contract if an HP Inkjet printer failure or damage is found to be directly attributed to the use of a modified or refilled HP Inkjet print cartridge.
I strongly sugget you to use HP genuine ink cartrdiges. I understand that wont work out economically.
Sep 27, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
After replacing ink cartridge printer dose not reconize one of six
Using refilled in cartridges and incompatible inks result in the following problems.
  • Refilled ink cartridges might leak and cause product damage. One method for refilling ink cartridges is to drill a hole through the cartridge, refill the ink, and then plug it. In some cases this plug does not hold, and the ink runs into the product and damages the printed circuit boards.
  • Refilled ink cartridges frequently exhibit spotty printing or fail to print. This problem might be a direct result of the nozzles being plugged with dried ink. Because the vents of the refilled cartridges have been opened, air is able to enter the cartridge and dry the ink.
  • Refilled ink cartridges might exhibit lower print quality, for the following reasons.
    • Printing algorithms used to create the various colors are based on particular printer inks. Using incompatible inks might result in color matching problems.
    • Refilled cartridges might have damaged nozzle orifices, result in various problems with print quality.
    • company products to which the printer belongs to can use a time delay between pages to accommodate the properties of the specific media type and ink being used. This prevents smearing problems from one page to the next. Using incompatible ink will alter the effects of this time delay and might result in poor print quality.
  • printer might not recognize refilled ink cartridges. The refilling process may involve altering the ink cartridge enough that the product is unable to recognize it. The condition of the print cartridge electrical contacts deteriorates with use. This also results in the product being unable to recognize the refilled cartridge.
  • Refilled ink cartridges might get stuck in the product. Because the cartridges from other manufacturers have been altered, cartridges might become stuck in the product. This problem might require that the product be disassembled to remove the cartridge.
  • printer at times cannot predict the long-term effects on product reliability from using different ink formulations.
try this.
please rate my solution.
have a nice day.
Jul 08, 2009 | Office Equipment & Supplies
Hp 818 print cartridge show incompatible after refill, or show problem with print cartidge. how to use them after refill without any problem
Whoever is doing refill for you should know that HP cartridges have electronic sensors that measure level of ink. They should have procedure with which they either reset the counter or "fool" the cartridge to work after refill.
Basically, you can't do anything yourself.
May 03, 2009 | HP DeskJet F380 All-In-One Printer
Printing with generic cartridges
Lexmark International does not recommend the use of third party inks or inkjet cartridge refill kits. Genuine Lexmark inks and cartridges are perfectly matched to the printing system. Using genuine Lexmark ink and cartridges ensures that every document produced is of the highest possible print quality, providing long-term dependable service from your Lexmark printer.
Lexmark cannot assure the excellent print quality and reliability of its inkjet cartridges after a cartridge has been refilled. Using incompatible inks in an attempt to extend the life of a genuine Lexmark cartridge beyond its recommended usage can cause failures in several different areas of the printer. Inkjet cartridges and printer failures caused by refilling or a third party ink are not covered by your Lexmark printer Warranty, Extended Warranty or Service Agreement.
Please use genuine Lexmark cartridges for best results.
Apr 20, 2009 | Office Equipment & Supplies
Cannon Incompatible Ink Cartridge Issue
I refilled my ink cartridge and you have to reset the chip on the cartridge,go back where you refilled your ink and ask them to reset the chip.Thats if you refilled the ink or you baught a canon one return it to the store.
Dan
Sep 10, 2008 | Canon PIXMA iP3300 InkJet Photo Printer
HP Deskjet 3512 Inkjet Multifunction Printer/Copier/Scanner Logo
16 people viewed this question
Seeker5211
Seeker5211
