Question about Brother MFC 420CN All-In-One InkJet Printer
Not recognising ink cartridges
Hi, I have taken "mixitup"'s advice,switched the machine off, removed all the cartridges, waited 2 minutes, and then switched back on and the printer is still not recognising the new cartridges....any ideas?
  • 832 Answers
Hmm, if my first hint wont work, try this: Do use original carts! Thirdparty ones have an other construction and wont work sometimes. If you dont have success do this: Open printer: http://www.hstt.net/refill-faq/inside.html#Brother_mfc215c Check the position of the inkcart circuit board. It might be loose. In some case you might need a new cart assy.
Posted on Oct 08, 2007
HP Deskjet 5940 won't recognise new black ink cartridge
Check to make sure that the contacts on the printhead carriage is clean.. Remove both cartridges. Unplug printer.Wait at least 3 minutes. Plug printer back in. Printer will turn on. Reinstall cartridges.
Dec 30, 2013 | HP Deskjet 5940 Photo InkJet Printer
Error 0xc18a0106
This is most common error in inkjet HP inkjet printers.But you are not mentioned model number, any how try this:
Step 1.
> Remove all the supplies like print heads & cartridges..
> Remove USB or any other device connectivity from system.
> Switch off the printer.
> Wait couple of minutes.
> Switch on the printer, wait till printer asked for the supplies.
> Insert supplies as per specified messages.
> Check for ready mode, insert data cable & give print command.
>>>Check.. no message.. END.
Step 2:
> If problem remain same..(I will suggest for tech guys)
> switch off the machine, remove all the supplies
> Open printer side covers.
> find out the CMOS batter mounted on formatter ,remove it..
> wait couple of minutes..
> with out CMOS batter do the above said step 1 process.
> check.. I hope it will resolve this issue..give print command.. verify..once its resolved CMOS batter has to be installed.
> Switch off the machine,
> insert CMOS battery,
> do again step1 process,,..
......END....
Best of luck...Thanks for choosing FIXYA
Dec 12, 2011 | HP PhotoSmart Office Equipment & Supplies
Lexmark x2650 isnt recognising the black ink cartridge
There could be two reasons for this 1. take out the black ink cartridge make sure you have taken the plastic sticker off. 2. The contacts at the back of the cartridge might be damaged. in which case you will have to get a new ink cartridge.
Mar 30, 2011 | Lexmark X2650 All-In-One InkJet Printer
Epson nx400 doesn't recognize ink cartridges
First of all let cartridge in the printer.... Then press Start.. it will say cartridge not recognised... then remove all cartridge (do not turn off printer).. then wait for 15 minutes...then again put cartridges in head... then press start..start...start..It will recognise on 2 to 3 tries.. Works on Epson TX210,200,410...If u want to be recognised then do not turn off printer...
Aug 13, 2010 | Epson Stylus NX400 InkJet Printer
Epson Stylus T21 printer not accepting ink supply system
Jul 11, 2010 | Epson Office Equipment & Supplies
My Brother MFC 440CN will not recognize a Brother
The usual obvious fix is to buy a new catridge, insert, power off machine, then switch back on to reset any sensors. But if the circuitry on the machine itself is faulty it wont fix it.
I used to own an MFC 260C. It had a perfectly good full ink catridge in it, that was working fine, until...it suddenly did not recognise the cartridge anymore.
I pulled the machine apart and found that 2 of the 4 sensors on the cct board at the back of the cartridge housing were loose. These sensors pass light through the exposed part of the cartridge to see if ink is there. So if these are faulty, you will never clear the "No Cartridge" or "Ink Empty..." or "Near Empty Ink ..." messages on the MFC260C and prbably other similar printers in the MFC range.
Why did they fail? Because the soldering on these sensors was poor quality.
I would never buy another Brother machine because of this, also because they design the machine to be totally useless unless all the ink ccartridges are full. Shame on you Brother, and kiss my *** for the $160 pile of junk I bought off you that was only on its second batch of cartridges (ie very little use)
Jan 23, 2010 | Brother Office Equipment & Supplies
The machine give me a massage said put in cartridge and I already change the ink and put it in
LEAVE PRINTER ON THEN,
1 remove ALL ink cartridges and close all covers
2 unplug power cord from back of printer
3 wait 4 minutes
4 plug power cord back in and wait for 10 minutes
5 when prompted install ink cartridges and wait a few minutes
click the setup button on the front of the printer scroll down to the tools menu and then run clean print head 3 times and last of all run align printer 1 time.
Jan 11, 2009 | Canon MultiPASS MP360 All-In-One InkJet...
Ink cartridge errror
3 wait 4 minutes
Click the setup button on the front of the printer scroll down to the tools menu and then run clean print head 3 times and last of all run align printer 1 time.
Dec 11, 2008 | Office Equipment & Supplies
Have a mfc-210c brother ink empty cyan replace ink. have put in a new lc41y ink cartridge . machine says open cover and reinstall ink cartridge. sortof done this 20 times!look forward to some advice...
May 03, 2008 | Office Equipment & Supplies
RECOGNITION OF GENUINE CANON INK CARTRIDGE
I posted the original problem. Although the cartridge was genuine I had taken it out and reinserted it as I wasn't sure I had loaded it correctly the first time. Advice from my local retailer was that this was a mistake. Canon PIXMA printers no longer recognise a cartridge once it has been removed. Solution was another new cartridge which I shan't remove until it's empty. When this second cartidge is empty I shall try the first cartridge again as it is still full and unused. It has yet to print anything! Why Canon's helpdesk couldn't help is a mystery. I conclude that Canon's printer management systems are unfriendly to users. They are friendly only to Canon. I hope my experience will help others especially those considering buying a Canon printer. dudbob
Jan 22, 2007 | Canon PIXMA iP1600 Printer
Brother MFC 420CN All-In-One InkJet Printer Logo
42 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
