Model: Crius-W-A The wireless remote only has a range of 25 ft. We need 100+ ft.
3 Suggested Answers
co7196
  • 3433 Answers
SOURCE: 220 VAC, 25 amp service line for a 50 ft long
8 ga on the 100
10ga on the 50
Posted on Nov 12, 2009
  • 271 Answers
SOURCE: need a manual for westinghouse rf remote for indoor lights, 100 ft range
DID YOU PLACE THE BATTERIES THE RIGHT WAY AND NOT REVERSE POLARITY?
Posted on Dec 02, 2014
Flywheel torque spec's for 1983 Ford F-100
Could it be a F-150 instead?
Ford Engine Bolt Torque Chart Bolt Torque Spec Chart for Ford Engines
These specs are for stock-type bolts with light engine oil applied to the threads and the underside of the bolt head. Moly and other lubes offer reduced friction and increased bolt tension, which will affect the torque figure. If you use after-market performance bolts like ARP's, you should follow the recommended torque specifications.
260, 289, 302 Torque Spec.
Fastener Type Torque Spec Main cap bolts 60-70 ft-lbs Outer main cap bolts 35-40 ft-lbs. Connecting rod bolts (40-45 ft-lbs. for 289 HP & Boss 302) Cylinder head bolts 65-72 ft-lbs. Rocker arms 17-23 ft-lbs. Intake manifold bolts 23-25 ft-lbs Oil pump bolt 23-28 ft-lbs. Cam bolts 40-45 ft-lbs. Cam thrust plate bolts 8-10 ft-lbs. Harmonic damper bolts 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-15 ft-lbs. 351W Torque Spec.
Fastener Type Torque Spec Main cap bolts 95-105 ft-lbs Connecting rod bolts 40-45 ft-lbs. Cylinder head bolts 90-100 ft-lbs. Rocker arms 17-23 ft-lbs. Intake manifold bolts 23-25 ft-lbs. Oil pump bolts 23-28 ft-lbs. Cam bolts 40-45 ft-lbs. Cam thrust plate bolts 8-10 ft-lbs. Harmonic damper bolt 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-15 ft-lbs. 351C, 351M Torque Spec.
Fastener Type Torque Spec Main cap bolts 95-105 ft-lbs. Connecting rod bolts 40-45 ft-lbs. (45-50 ft-lbs. For Boss 351C) Cylinder head bolts 105 ft-lbs. (125 ft-lbs. For Boss 351C) Rocker arms (non-adjustable) Rocker arms (non-adjustable) 5/16in. intake manifold bolts 21-25 ft-lbs. 3/8in. intake manifold bolts 28-23 ft-lbs Oil pump bolt 25 ft-lbs. Cam bolts 40-45 ft-lbs. Cam thrust plate bolts 9-12 ft-lbs. Harmonic damper bolt 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-18 ft-lbs. 360, 390, 406, 427, 428FE Torque Spec.
Fastener Type Torque Spec Main cap bolts 95-105 ft-lbs. Crossbolts for 406-427 40 ft-lbs. Connecting rod bolts 40-45 ft-lbs. (53-58 ft-lbs. For 406 and 427) Cylinder head bolts 80-90 ft-lbs. (100-110 ft-lbs. For 1963-67 427) Rocker arm shaft bolts 40-45 ft-lbs. Intake manifold bolts 32-35 ft-lbs. Oil pump bolt 12-15 ft-lbs. Cam bolts 40-45 ft-lbs. Harmonic damper bolt 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-15 ft-lbs. 429-460 Torque Spec.
Fastener Type Torque Spec Main cap bolts 95-105 ft-lbs Connecting rod bolts 40-45 ft-lbs. Cylinder head bolts 140 ft-lbs. Rocker arms (non-adjustable) 18-22 ft-lbs. Intake manifold bolts 25-30 ft-lbs. Oil pump bolt 25 ft-lbs. Cam bolts 40-45 ft-lbs. Harmonic damper bolt 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-18 ft-lbs.
Dec 18, 2015 | Ford Cars & Trucks
What are the torques on a 22hp ohv briggs and stratton head and also push rods
VERIFY your engine model numbers
Briggs & Stratton Intek V-Twin
Engine Model Numbers 407777 and 44P777
Cylinders 2 (Dual cylinder)
ITEM N m (Newton metres) lb-in Spark Plug Torque 20 180 Back Plate (to cylinder) 11 100 Blower Housing Screws 9 80 Breather Screws 6 55 Carburetor to Manifold 7 65 Cylinder Head Bolts 25 220 Cylinder Shield 7 65 Crankcase Cover 23 200 Engine Mounting Bolts 48 35 lb-ft Electric Clutch Mounting Bolt 75 55 lb-ft Exhaust Manifold 16 140 Fan Retainer Bolts 16 140 Flywheel Nut 203 150 lb-ft Armature Mounting Screws 3 25 Intake Manifold Bolts 9 80 Rocker Arm Adjustment Lock Nut 7 62 Rocker Support Screws 11.3 100 Valve Cover Cap Screws 11 100 Carburetor to Intake 7 65 Valve Clearance (Cold) 0.10-0.13 mm (0.004-0.005 in)
WARNING: Uneven tightening will warp the head. Tighten Cylinder Head Bolts down evenly by hand. Then using torque wrench tighten in sequence, in 9 N m (80 lb-in) increments to 25 N m (220 lb-in).
Intake valve push rods are aluminum.
Exhaust valve push rods are steel.
DO NOT interchange push rods.
Removal and Re-installation sequence for bolt removal and tightening.
Mar 21, 2015 | Garden
Need a manual for westinghouse rf remote for indoor lights, 100 ft range
Dec 02, 2014 | Cars & Trucks
I have a wireless router but cant seem to take my laptop in to another room for use. screen comes up that says no connection,should'nt i be able to use it wireless within the 100 feet range?
In my experience being within 50 ft of various routers I have had seems to be the best singal strength. Any further then that I start having connection issues. So based on my experiences I would say the answer is No to your question. That is based on 'G' system routers. I have heard the 'N' routers have greater range and speed.
Nov 10, 2010 | 2wire (1000-400108-001) Router
What is the distance that you can be between devices on the Aerocomm Connexlink serial adapters?
I could not find any specific data on gthe Connex adapter, but most routers have a range of around 100 ft or so router to wireless computer.
Dec 15, 2009 | AeroComm ConnexLink (CL200) Wireless...
Need to know torque specs for rod and head bolts on a quincy model 350-11 air compresser
25-35 ft. lbs. Never saw any air compressor head bolts any other torque range If that number is a little squishy for you, call Quincy up tomorrow at
212-222-7700
Aug 21, 2009 | Air Tools & Compressors
Need to boost my wireless signal for remote laptop
It's almost a DIY deal, but how close are you to Corpus?
The unit you need is a Wireless access point. My favorite, fairly inexpensive, WAP is made by TP Link. http://www.tplink.com/products/product_des.asp?id=116
You can start with one, at ***********'s, add an external antenna, and set it up as a client pointing to your wireless internet connection. If that doesn't work, you duplicate the equipment set up as a wireless access point at your location.
Post back if you need purchasing help or are near Corpus.
Carl
Jun 28, 2009 | 2wire 2700HG-B Router (2700HGB)
I need to expand my att dsl coverage with an range expander but don't know which one to use. I have a 2wire modem but can't get an answer from ATT about which range expander to use or where to get it
Linksys makes a simple range expander you can use. Most expanders do not need to be connected to the network by a data cable. Just put it within range of your main access point or wireless router, and it "bounces" the signals out to remote wireless devices.
Try the Linksys WRE54G ($70-$100)
Jun 16, 2009 | 2wire 2700HG-B Router (2700HGB)
Linksys wireless router connectivity problem
router is fine just try to change the key value 1,6, and 11 it will work this setting you can done by openning router config page
Dec 30, 2007 | Linksys Wireless-G WRT54G Router
46 people viewed this question
k24674
jasbo
jasbo
