Question about Angelcare Deluxe Movement Sensor & Sound Baby Monitor
Display not working on anglecare monitor - Angelcare Deluxe Movement Sensor & Sound Baby Monitor
How do I get the secondary monitor to work with Windows 10.
I do not think win 10 has 2nd monitor capability
Jan 19, 2016 | Computers & Internet
It display every thing for few second and get off display itself but not power when i switch off on then it come back then again get off
Here's some tricks I would try...
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or orange or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your display on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Good luck.
Jul 18, 2014 | Computers & Internet
Lcd acer al1917w display blang white
6. If the power light is on and yellow or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
Apr 05, 2014 | Acer Ferrari Computers & Internet
Display not working but system functioning
tried with other monitor just to ensure if the problem is only with in the monitor. if the same problem, the cause it could be the inverter board for screen back light which has component being shorted.
Aug 15, 2012 | Samsung SyncMaster 713N 17" LCD Monitor
6349 cannot display
Try another monitor on the desktop. You problem is either the monitor or the video card. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the desktop. If the borrowed monitor shows the display and works ok, then your original monitor is bad. If the borrowed monitor does not show the display just like your original monitor did not show a display, then the Video Card in the computer is bad.
May 05, 2012 | Computers & Internet
How do I use the Anglecare Deluxe Movement sensor moniter without the movement sensor? I would like to be able to hear the audio even if the baby is not sleeping on the pad but is in the room. Thanks.
mine has a switch on the back of the base unit with three options. one of which being sound only. another being sound and movement, and the third being tic off.
Oct 19, 2010 | Angelcare Deluxe Movement Sensor & Sound...
The power lite goes on and off and screen wont lite up
telepathy do not work, you need to state what computer brand, what model, what monitor, meantime follow that procedure:
1. switch off computer and monitor
2. disconnect all cables on the back of the computer and monitor
3. re-connect all cables
4. re-power your monitor (is light on? any message on the screen?)
5. re-power your computer - is there any activity on the screen?
if there is no joy:
6. change monitor for known working one and check for display,
7. connect your monitor to known working computer,
is there a display on your monitor? is there a display on borrowed monitor?
if there is display on borrowed monitor, that mean that your monitor is at fault, especially if your monitor do not work on another machine.
if neither monitor work on your machine but both work on other, this will indicate video card at fault (most probable) or motherboard, or memory all of these need to be assessed before further proceedig can be advised.
before further help is sought, state clearly what computer, motherboard type and model (all in one?), video card model, monitor model
if you find this advice helpful, vote for me
Jul 31, 2010 | Computers & Internet
Powers on then back off in two seconds...I don't know how to open the case without destroying it..
hello,
Seems that your problem is not your Samsung Monitor. Please check very well. Since this is basically an indication that your CPU is not working that is why there is no display in the monitor and the yellow light turns to orange.
  1. Please try to use another monitor if you still have one that is working well. Then power up your computer and see if there is display on the monitor. If there is, then your reported monitor really has a problem. And if there is no display even in the new working monitor, then the CPU is in frozen state that is why there is no display on the monitor.
May 08, 2010 | Samsung SyncMaster 204B 20.1" LCD Monitor
My newer flat screen monitor went black but works fine when hooked up to another computer and I have an older monitor that I hooked up and the older one works fine...??
That sounds like a display/resolution setting problem on your PC. I doubt there is anything actually wrong with the PC or the monitor, since both work with different combinations, so its most likely just a setting.
Some monitors don't display anything when they get a signal/resolution that is not compatible with their displays. I would try changing the display settings on your computer with your old monitor, then switch monitors and see if your newer monitor works.
Here's how to adjust the display resolution:
If in XP, right-click on the desktop and go to Properties, and select the tab for display settings and adjust/lower the resolution. If in Vista/Win7 right-click the desktop and select Screen Resolution/Display Settings and adjust it there.
Feb 15, 2010 | Rosewill R900J 19" Flat Panel LCD Monitor
X2 gen 17" lcd monitor, no display
This indicates either a problem with the monitor cable(ie shorted) or the display adapter. Try plugging the monitor into a different computer and if it works you will need to install a new display adapter in your computer. If it doewn't work on the new one either you can try a different monitor cable if yours isn't permanently connected. Hope this helps
Mar 29, 2009 | X2 MG17R 17" LCD Monitor
Angelcare Deluxe Movement Sensor & Sound Baby Monitor Logo
74 people viewed this question
Top Angelcare Baby Gear Experts
Pamela Leach
Pamela Leach
Are you an Angelcare Baby Gear Expert? Answer questions, earn points and help others
