Printer dgi ned tcp/ip
3 Suggested Answers
  • 217 Answers
SOURCE: HP Laserjet 4050. Can I connect from my TCP/IP to JetDirect?
To use a printer DIRECTLY into your PC or laptop (without plugging both into a network hib, or switch), you need to use a CROSSOVER patch cable.
Posted on Apr 05, 2010
  • 2567 Answers
SOURCE: I have a hp laserjet
You should enter the IP address assigned & set up on the printer.
Please refer to the following article from HP for more details:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=115&prodSeriesId=238800&prodTypeId=18972&prodSeriesId=238800&objectID=bpj07116
Posted on May 18, 2011
Please tell me how to configure ip address in printer 4350
Press Check mark (SELECT button) to open the menus.
2. Use (UP button) or (DOWN button) to scroll to CONFIGURE DEVICE menu, and then press
(SELECT button).
3. Use (UP button) or (DOWN button) to scroll to I/O submenu, and then press
(SELECT button).
4. Use (UP button) or (DOWN button) to scroll to EMBEDDED JETDIRECT MENU
5. Use (UP button) or (DOWN button) to scroll to TCP/IP
Then: Select whether the TCP/IP protocol
stack is enabled or disabled. You can set several
TCP/IP parameters.
Select the TCP/IP CONFIGURE METHOD to
configure the EIO card. For the MANUAL option,
set the values for IP ADDRESS , SUBNET
MASK , LOCAL GATEWAY, and DEFAULT
GATEWAY
Nov 14, 2010 | HP LaserJet 4350 Printer
I cannot get the printer on my network. What settings must I use with DHCP to automatically pull the IP address and be identified on the network? HP 5100 dtn
On the control panel, navigate to the Configuration menu and within it, to the EIO menu. Navigate to CFG NETWORK and select YES. Navigate to TCP/IP and select ON. Navigate to CFG TCP/IP and select YES. Navigate to BOOTP and select NO. Navigate to DHCP and if you want automatic IP addressing, select YES. If you select NO for DHCP, you will be able to manually set the TCP/IP parameters, including IP address, subnet mask and default gateway.
Nov 05, 2010 | HP LaserJet 5100dtn Printer
No matter what i do i cannot enable TCP/IP or Parallel port. I enable through the system setup but when the fiery restarts and and the test print is printed it just keeps telling me TCP/IP enable :NO and...
Is not simple if you don't the program. It find in www.support.xerox.com . When you install the driver , please connect the printer, TCP /IP must be static IP and not DHCP. Because the ip is change when the swicth is desconnect.
Nov 03, 2010 | Xerox DocuColor 12 Printer
I WANT TO BE ABLE TO PRINT FROM MY COMPUTER TO MY PRINTER
  1. Either set a static IP for the printer or attach your computer directly using USB.
  2. Setup the printer on your computer using the driver for the printer. If the printer has Postscript capabilities the PS driver is better than the PCL driver.
  3. If the printer is USB setup like any other printer, if the printer is IP then specify a local port in the Wizard and type the IP.
  4. Choose the driver and install
  5. Afterwards go under properties and select the printer components such as duplexer, extra trays, etc.
May 03, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
How to give ip address to workcentre m133 network printer
: You must be a System Administrator to perform this solution. 1. Press the [Log In / Out] button on the Control Panel. The Login screen will be displayed. 2. Enter the System Administrator userID using the numeric keypad on the Control Panel, or select the [Keyboard] button on the Touch Screen to enter the userID, and then select [Save] on the Touch Screen. 3. If necessary, enter the System Administrator password using the numeric keypad, or select the [Keyboard] button to enter the password, and then select [Save] on the Touch Screen. NOTE: The default userID is 11111, and the default password is x-admin (must be entered in lower case). If the userID and / or password have been forgotten, a service call must be placed. 4. Select [Confirm] on the Touch Screen. The System Administrator Menu screen will be displayed. 5. Select [System Settings] twice. The System Settings screen will be displayed. 6. Select [Network Settings]. The Network Settings screen will be displayed. 7. Select [Protocol Settings]. The Protocol Settings screen will be displayed. 8. Select [TCP/IP - Get IP Address], and then select [Change Settings]. The TCP/IP - Get IP Address screen will be displayed. 9. Select [Manual], and then select [Save]. The Protocol Settings screen will be displayed. 10. Select [TCP/IP - IP Address], and then select [Change Settings]. The TCP/IP - IP Address screen will be displayed. 11. Enter the machines IP Address using the numeric keypad, and then select [Save]. The Protocol Settings screen will be displayed. 12. Select [TCP/IP Subnet Mask], and then select [Change Settings]. The TCP/IP Subnet Mask screen will be displayed. 13. Enter the machines Subnet Mask using the numeric keypad, and then select [Save]. The Protocol Settings screen will be displayed. 14. Select [TCP/IP Gateway Address], and then select [Change Settings]. The TCP/IP Gateway Address screen will be displayed. 15. Enter the machines TCP/IP Gateway Address using the numeric keypad, and then select [Save]. The Protocol Settings screen will be displayed. 16. Select [Close] three times. 17. Select [Exit]. The machine will reboot automatically.
Jun 09, 2009 | Xerox WorkCentre M15i Laser Printer
Installing hp laserjet 4100dtn over the network using tcp/ip addr
Hi admin30:
Here is some info for you.
EIO menu (networked printers)
The EIO (enhanced input/output) menu appears only when an EIO device is installed in an EIO slot
on the printer (such as an HP JetDirect print server). The items in the menu depend on the particular
accessory product installed. If the printer contains an HP JetDirect print server EIO card, you can
configure basic networking parameters using the EIO menu. These and other parameters can also
be configured through HP Web JetAdmin.
Table 27. EIO menu
Item Values Explanation
CFG NETWORK=NO NO
YES
Select whether or not you want to use
the HP JetDirect menu.
NO: Bypass the HP JetDirect menu.
YES: Use the HP JetDirect menu. You
must change this to YES each time you
want to use the menu.
Note
You must select CFG NETWORK=YES to
display the following items.
IPX/SPX=ON ON
OFF
Select whether the IPX/SPX protocol
stack (in Novell NetWare networks, for
example) is enabled (ON) or disabled
(OFF).
DLC/LLC=ON ON
OFF
Select whether the DLC/LLC protocol
stack is enabled (ON) or disabled (OFF).
TCP/IP=ON ON
OFF
ATALK=ON ON
OFF
FG IPX/SPX=NO NO
YES
Select whether you want to use the IPX/
SPX menu and set IPX/SPX protocol
parameters.
NO: Bypass the IPX/SPX menu items.
YES: Use the IPX/SPX menu items.
In the IPX/SPX menu, you can specify
the frame-type parameter used on your
network.
The default is AUTO, to automatically set
and limit the frame type to the first one
detected.
For Ethernet cards, frame type
selections are EN_8023, EN_II,
EN_8022, EN_SNAP.
For Token Ring cards, frame type
selections include TR_8022, TR_SNAP.
In the IPX/SPX menu for Token Ring
cards, you can also specify NetWare
Source Routing parameters, which are
SRC RT=AUTO (default), OFF, SINGLE R, or
ALL RT.
CFG TCP/IP=NO NO
YES
TCP/IP menu and set TCP/IP protocol
parameters.
NO: Bypass the TCP/IP menu items.
YES: Use the TCP/IP menu items.
In the TCP/IP menu, you can specify
BOOTP=YES or DHCP=YES for TCP/IP
parameters to be automatically loaded
from a bootP or DHCP server when the
printer is turned on.
If you specify BOOTP=NO and DHCP=NO, you
can manually set the following TCP/IP
parameters from the control panel: each
byte of the IP address (IP), Subnet Mask
(SM), Syslog Server (LG), and Default
Gateway (GW). You can also manually
set the idle timeout period.
Print an HP JetDirect configuration page
to verify your settings. However, note that
the print server might overwrite selected
parameters with values that ensure
proper operation.
Table 27. EIO menu (continued)
Select whether the Apple EtherTalk
protocol stack is enabled (ON) or disabled
(OFF).
May 26, 2009 | HP LaserJet 4100dtn Printer
Xp home & wireless printer won't install
Add the printer in a TCP/IP port and assign it that IP address. /Add Printer/local connection then set it to TCP/IP port and the printers ip address.
Jan 15, 2009 | Microsoft Windows XP Home Edition
My vista laptops find my belkin router, but i am unable to print with the belkin print server. Both work perfect with my XP pro home compuer. Have changed ip/tcp address acording to belkin website but with...
Is the printer driver installed on the vista machine? You might need to install the driver as if it was local, then create a virtual tcp/ip port to print to, and reassign the printer to the tcp/ip port.
Sep 16, 2008 | Office Equipment & Supplies
Tcpip is disable on a xerox 8550 printer. How to enable it manually
Here are the steps to set up a static IP on your printer.
  1. With the printer displaying 'Ready to Print', press the [Up] or [Down] arrow button on the Control Panel and select [Printer Setup] on the Display Screen, and then press the [OK] button.
  2. Press the [Up] or [Down] arrow button to select [Connection Setup], and then press the [OK] button.
  3. Press the [Up] or [Down] arrow button to select [Network Setup], and then press the [OK] button.
  4. Press the [Up] or [Down] arrow button to select [TCP/IP Setup], and then press the [OK] button.
  5. If necessary, press the [Up] or [Down] arrow button to select [TCP/IP], and then press the [OK] button to select [On].
  6. If necessary, press the [Up] or [Down] arrow button to select [DHCP/BOOTP], and then press the [OK] button to select [Off].
  7. Press the [Up] or [Down] arrow button to select [TCP/IP Address], and then press the [OK] button.
  8. Press the [Up] or [Down] arrow to scroll to the correct number for the first 3 digits of the address.
  9. Press the [OK] button to accept and move to the next three digits. Repeat until the required IP Address is displayed, and then press the [OK] button to return to the TCP/IP Setup Menu.
  10. Press the [Up] or [Down] arrow to select [TCP/IP Network], and then press the [OK] button.
  11. Press the [Up] or [Down] arrow to scroll to the correct number for the first 3 digits of the network mask.
  12. Press the [OK] button to accept and move to the next three digits. Repeat until the required Network Mask is displayed, and then press the [OK] button to return to the TCP/IP Setup Menu.
  13. Press the [Up] or [Down] arrow to select [TCP/IP Gateway], and then press the [OK] button.
  14. Press the [Up] or [Down] arrow to scroll to the correct number for the first 3 digits of the Gateway Address.
  15. Press the [OK] button to accept and move to the next three digits. Repeat until the required Gateway Address is displayed, and then press the [OK] button to return to the TCP/IP Setup Menu.
  16. Press the [Up] or [Down] arrow to select [Exit], and then press the [OK] button.
May 20, 2008 | Xerox Office Equipment & Supplies
Networking a printer on a Netgear Router
Did you cofigure the IP address on the printer?You need to configure the IP address before add printer.
Mar 11, 2008 | Samsung CLX 3160fn All-In-One Printer
19 people viewed this question
k24674
