Question about Mitsubishi LVP-S50UX Multimedia Projector
Keystone where is the keystone setting?
How do I correct a trapezoidal display?
This is called keystoning and there should be a setting on your projector that will compensate for this problem. Usually it will be called keystone adjustment or something like this.
Jun 07, 2015 | InFocus IN2104 Projector
I have problem with christie projector roadster x9
If your's is the "s" model there is no keystone adjustment provided. Otherwise the keystone adjustment is found under MENU then 1, Size and Position and under MENU 2, Image Settings. Also, refer to this excerpt from the manual:
NOTE: This function is not available in "S" models.
Adjust the keystone control if images appears non-rectangular or keystoned in shape-that is, smaller at either the top or bottom edge. The effect of keystone adjustment is similar to
physically tilting the projector forward or backward in relation to the screen, and it affects all sources.
NOTES: 1) Keystone is enabled for a source only if Size is 1000 and Size x Vertical Stretch is 1,000,000.
2) Keystone adjustment is not available in "S"
models. 3) Avoid using Keystone with Blanking.
Nov 19, 2014 | Office Equipment & Supplies
How do i fix the keystone
It should be in the installation menu if you can do this by remote or for older tvs it'll be round the back of the tv with some knobs that you can adjust for keystone and other settings
Oct 14, 2014 | Televison & Video
Keystone not working
Manual: http://www.mitsubishi-presentations.com/wp-content/files_mf/mitsubishi_manual_xd250ust.pdf
Installation>Wall Screen>Keystone
The automatic keystone adjustment may not be carried out correctly
because of the ambient temperature and the installation
conditions of the projector and the screen. In such cases, correct
the keystone manually.
• When the projector is projecting images where acceleration is
present, such as in a vehicle and aircraft, the automatic keystone
adjustment may not function correctly. In such a case, set AUTO
KEYSTONE in the INSTALLATION menu to OFF and correct the
keystone manually.
• You can correct the vertical keystones. However, their adjustment
ranges are limited in such correction.
When the keystone adjustment is carried out, the adjustment
value is indicated. Note that this value doesn't mean a projection
angle.
• The allowable range of the adjustment value in the keystone
adjustment varies depending on the installation conditions.
• When the keystone adjustment takes effect, the resolution
decreases. In addition, stripes may appear or straight lines may
bend in images with complicated patterns. They are not due to
product malfunctions.
• Noise may appear on the screen during the keystone adjustment
because of the type of the video signal being projected and the
setting values of the keystone adjustment. In such cases, set the
keystone adjustment values in the range where the image is displayed
without noise.
• When the keystone adjustment is carried out, the image may not
be displayed correctly because of the type of input signal.
Mar 13, 2014 | Mitsubishi XD250U-ST DLP Projector
My picture is not square how do I fix it
hi dear,
If your picture is irregular shape adjust keystone setting menu ->setting ->keystone
Sep 25, 2012 | Hitachi PJTX100 Multimedia Projector
How do I angle the projector at the side of a screen & get the screen view of it straight?
In projector menu you will find a setting called 'keystone correction'. Use horizontal and vertical keystone correction to correct the projected image.
Sep 24, 2011 | NEC MultiSync MT1030 Multimedia Projector
TILTED IMAGE
reset the settings to factory default.
Jan 26, 2009 | Eiki LC-SM4 Multimedia Projector
We accidentally hit a button on the projector hand control, and the picture on the screen is now wide at the top and goes narrow towards the bottom. dont know what we hit, but someting is wrong. The cd...
ooopssss, you hit the display setting your keystone setting. go to your menu and find the keystone adjustments of in your remote find that button to set keystone
May 03, 2008 | Televison & Video
Mitsubishi LVP-S50UX Multimedia Projector Logo
Top Mitsubishi Office Equipment & Supplies Experts
Martin Murray
Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
