Question about Ryobi RHT2660DA Petrol Hedgetrimmer - 26cc Quick Fire Engine
How do i rewire a ryobi electric hedge trimmer
boscia
  • 163 Answers
SOURCE: add on hedge trimmer ryobi weed eater
I use a dremel with a sharpening stone, if u don't have one you can also use a power drill with a small sanding disk (1 inch) and course sand paper (30 or 40 grit). or you can use a bastard file. its too tight to use any kind of angle guide so just take your time and do it by eye. it shouldn't take much to get them sharp enough to do the job, over-sharpening is unnecessary and dangerous, and will make the blades dull faster. sharpen all the free blades, top and bottom, then start the trimmers to advance the blades to free up the sides you couldn't get. i use a light penetrating oil to clean the blades first, then lithium grease spray to lubricate.
Posted on Nov 28, 2008
  • 3 Answers
SOURCE: what is the gas & oil mixture for ryobi 26cc 22in hedge trimmer
If it is a 2 stroke engine, a 50:1 ratio should work. That's 50 parts gas to 1 part oil.
Posted on Dec 14, 2008
  • 398 Answers
SOURCE: reassembling blades on hedge trimmer
the blades are stuck , i spray my trimmer with wd40 before every use to keep them juicy you should too. also sometimes if you hit a large stick it will put a divot in the blade cause ing it to stick. as for putting it together, find some one who can do it without directions. but when you use them next make sure you soak em good with wd40 or something if you dont i guarantee they will always stick. wd40 willl not hurt any shrubbery, as ive been doing it for years.
Posted on Feb 26, 2009
SOURCE: Ryobi 18V Hedge Trimmer Blade Question
Just buy a file and push 3 or 4 down strokes down the same slope of the cutter toward the sharp edge. Never file on the flat top of the cutter, only on the slope. Support the frame using a saw horse or pick-up bed. The support makes the file cut the metal better. You can do the same thing with chain saws. You just need the file that fits the cutter. You just hold a consistant angle and count out the same number of strokes. Also, clean out junk between the moving parts, tighten any loose screws, and drop a few drops of 3 in 1 oil between the moving parts. Having things sharpened at a shop is inconvenient and expensive.
Posted on May 24, 2009
  • 32 Answers
SOURCE: I have a model # RY39500 ryobi hedge trimmer 2
Sounds like the air screws need adjusted on the carburator. If there are 2 the one with the L above needs to be turned althe way to the right but not to tight and then backed out 1/2 turn to left. The one with the H anove it do the same except back it out 1 and 1/4 turns to left. If it only has 1 screw dot he same but back out 2 complete turns. Hope this helps?
Ralph at woodworking57@hotmail.com
Posted on Sep 15, 2009
Testimonial: "Thank you, worked great!"
Engine running but blades dont move
if its electric/battery operated suspect stripped gears and throw it away as you tried to cut something to big with it. If its gas then suspect the same thing but it's repairable
Nov 30, 2013 | Ryobi 18V Hedge Trimmer
I need a manual for a Ryobi RHT500R Electric Hedge Trimmer 500 Watt - 55cm
I found the manual for the Ryobi hedge trimmer here: fr.ryobitools.eu/local/uploaded/catalog/e_RHT500R-600RL_UM_UK_v1.pdf . The bolts you describe hold the blade to the hedge trimmer's motor. They shouldn't have come loose. However you can check if any of the bolts are loose or have backed out of the motor.
I would suspect either a part of the branch is stuck between the blades. I have one of the small edge trimmer which gets noisy when I get a woody weed stuck in the unit. Unplug the trimmer and look at the blade for some bark stuck between the layers. On each side there are multiple blades that overlap at parts of the cutting cycle.
A parts diagram for the RHT500R is available here: http://www.magic-parts.co.uk/acatalog/Ryobi_RHT500R.php .
II hope this helps.
Aug 23, 2012 | Ryobi Garden
When in operation the Ryobi S430 string trimmer leaks oil continuously. How can I fix this problem?
Ryobi told me the unit can't have the s430 trimmer bottom end raised higher than the engine at any time, or it will leak. Apparently they released a product to compete with other companies for cheap 4 cycle trimmers without much care for the end user.
Nov 29, 2010 | Ryobi Factory-Reconditioned 30cc 18" Gas...
I have a ryobi hedge trimmer p2601 and the plastic handle broke. Is there a way to get a stronger handle or just a replacement?
May 29, 2010 | Ryobi 18V Hedge Trimmer
Hello I have a Ryobi HT26 hedge trimmer that is one year old. It starts fine but dies after I try to release the choke and pull the throttle. I cleaned the air intake that was semi plugged, replaced the...
Sorry but I have the same problem, did everything you did plus bought a new carb. I think these are just a bunch a ****. I have Ryobi electric tools which are okay but I am NEVER going to buy a buy Ryobi gas product again>
Nov 22, 2009 | Garden
How do fit a hedge trimmer attachment to a rbc 40 sb brushcutter ? thanks
This unit was not made to have interchangeable heads. Ryobi makes a hedge trimmer attachment for some of its units that are quick connect.
Otherwise, you may buy this attachment and see if you can interchange the head from the brushcutter to the hedge trimmer. You may find it more work than you want to tackle.
Sep 26, 2009 | Ryobi Garden
Hedge trimmer starts fine then stops after 5 minutes
Carburetor high speed adjustment ( screw nearest the filter ) open ( counterclockwise ) 1/2 turn.
Adjust again as needed to run when hot.
make sure the gas mixture ratio is as required.
Henry
Sep 20, 2009 | Ryobi Factory-Reconditioned 30cc 18" Gas...
Carbon brushes needed for Ryobi Hedge Trimmer Model RHT 618, 460
check with a small engine shop near you to see if they can get these parts for you.or you might fine them at www.partstree.com.
let me know what you fine out.ok
Jul 23, 2009 | Ryobi 26CC, 22 In. Hedge Trimmer
What is the gas & oil mixture for ryobi 26cc 22in hedge trimmer
Dec 10, 2008 | Ryobi 26CC, 22 In. Hedge Trimmer
Open Questions:
I have a Ryobi RHT 2660DA Hedge trimmer that will not start. I have tried the following things; 1. Replacing the spark plug. There is a good spark on both the old and new plug. 2. Adjusted the carburetor as suggested. 3. Put a teaspoon of fuel into the spark plug hole directly. Does not even try. 4. Tried easy start in the spark plug hole directly and into carburetor. No joy. 5. Took off carburetor and cleaned a suggested. No joy. 6. Replaced the available diaphragms (4 in all). No joy. 7. Replace carburetor with a new one. Same result. 8. Checked compression which was only about 50 per square inch. 9. Checked tightness of crankcase screws. All tight. 10. Replace crankcase gasket. Still same compression result. Again no joy. 11. This machine is about 5 years old but only used about 5 or 6 times so should not be a wear problem. 12. Replace mixture (did this early on in the sequence) 13. Took off exhaust which was full of fluid. Cleaned and dried, but to no avail. 14. Stripped unit down as I started to believe this was a timing or compression problems, but I cannot get the bottom clutch unit off (do not know how to remove it as it looks like an interference fit on the shaft. As a result I cannot get to the flywheel to see whether the key way or key has sheared or the timing has somehow moved. I am now at a lost of a way forward. I would appreciate any help or suggestions. At the moment I am left with what is an expensive piece of junk.
Jul 30, 2013 | Ryobi RHT2660DA Petrol Hedgetrimmer - 26cc...
Ryobi RHT2660DA Petrol Hedgetrimmer - 26cc Quick Fire Engine Logo
32 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
