Akai AA-8080 left channel output has filter issue. Garbled and scratchy output
Left channel low,output and garbled
  • 21 Answers
SOURCE: Amplifier problem
You may have a blown channel. Check for fuses inside but I don't think that it will help. Repair if the channel is dead is not worth doing as the amps value is probably lower than repair cost.
Posted on Sep 03, 2007
SOURCE: Left channel out
There are NO mechanical pots on the system. The "pots" for volume are a special bitsequence comparator, and the signal for the gain on the amp is a modulated matrix signal.
The most common problem for this kind of amps are the safety-thermal switch... They are normally located really close to the output for the speakers. Normally gray or black boxes (30x10x40mm). Flick your finger on them with volume at 9 o'clock...
If you can hear a click, and the sound appear again you've found the sollution.
NOTE! Hazardous currents are present inside the cabinet, mind your fingers, arms and other bodyparts.
Posted on Jan 23, 2008
pgh_pa_guy
  • 2992 Answers
SOURCE: akai recording problem
You might have a bad cable to the recorder (try swapping the right and left connections and see if the problem moves to the other channel), dirty tape heads (use a cotton swab and head cleaner or isopropyl alcohol to clean them), or a circuit problem inside the recorder. Hope this gets you started!
Posted on Nov 19, 2008
cpenzes
  • 1102 Answers
SOURCE: IBM A31 2652 Video garbled video at boot
update monitor driver
your screen may be going
how old is the system
Posted on Jan 26, 2009
  • 39 Answers
This is very possibly a hardware problem, namely a crack in the motherboard. Sorry, no easy or cheap fix for it if that's the case.
Posted on Mar 04, 2009
Onkyo HT-R510 left side speaker garbled
Out put transister could be fried ,Or the speaker is blowin,
Nov 29, 2012 | Onkyo Ht-r510 600w 6.1 Dts Home Theatre...
Sound is garbled on one channel only-using antenna.
Try using a different antenna or moving the antenna to a different ocation. if none of that works you might have a bad signal board. You can get parts at www.interliquidparts.com
Dec 12, 2011 | Sharp LC-52D64U 52 in. LCD HDTV
Kp51hw40 has ble shadow on images on the left 1/3 of the screen. It also displays lettering that garbled in that same left 1/3 of the screen
Convergence issue. The Sony type 1 convergence repair kit from www.tvrepairworld.com should solve that issue. That kit is the one for your model. It contains the parts and repair instructions on CD.
Sep 29, 2010 | Sony KP-51HW40 51" Rear Projection...
Headphone output distorted on one side. Replacement jack?
studiospares (in london) or radioshack in USA, unscrew and get busy with a soldering iron, its not too hard, only 4 cables.
Jan 22, 2010 | Behringer DJx700 5-Channel Pro DJ Mixer...
Feb 18, 2009 | IBM ThinkPad T42 Notebook
Jan 26, 2009 | IBM ThinkPad A31 Notebook
Bad sound-garbled and goes off on certain channels.
Go into the menu and make sure the SAP is off.
Oct 24, 2008 | Sansui DTV2760 27" TV
Sammsung s4253 plasma tv audio garbled on digital channels
I had the same problem with my S4253 using Directv. I then turned off the Dolby Digital on the sound settings on the Directv satellite box. Problem went away.
Oct 04, 2008 | Samsung HP-S4253 Television
Sound
your problem is a dirty filter in your audio resistance .. need to be clean the audio module ... or tring to change to other output will solve the problem
Dec 23, 2007 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Amplifier problem
Sep 02, 2007 | Audio Players & Recorders
 Grubhead
Grubhead
