Vox valvetronic amplifier static crackle
I recently purchased a second hand Vox VT50. t was fine for a few days and then started to crackle when certain notes were played. I replaced the tube as well as cleaning the jack inputs but the sound is still there on certain notes. This is using a new guitar and cable also. any thoughts or idesas?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 56 Answers
Check the speaker for a loose dustcap or separated spider.
Posted on Nov 20, 2013
4 Suggested Answers
SOURCE: guitar/amplifier 'buzz'
I have two amps .i need to know how to set the knobs on them. to get the best sound out of them .i have a crate and a drive elite.i am a beginner. they are both bass amps. so PLEASE HELP ME
Posted on Dec 27, 2007
Grubhead
  • 5391 Answers
SOURCE: i have a vox valvetronix vt 50 around 3 years
You will probably need to replace the large Electrolytic Capacitors in the power section. They can fail like that if left without power being applied for a long time.
If you see any other large ones (size wise) I would replace them too, just in case.
The big ones are prone to drying up more than the smaller ones you will see inside it.
Posted on Nov 24, 2009
  • 40 Answers
SOURCE: Hi , I have an original 1967 Vox AC 30 Top Boost
Using the fifth fret tuning method may give you your answer. If you play the same exact note on an alternate string, see if the same sound happens. If so then its probably amp. If not, then its probably the pick ups.
Posted on Dec 07, 2009
Can I use my vox vt50 amp to play my bass guitar?
You can use it, just keep the volume low. The amp doesn't care what yu play through it, but the speaker isn't designed for loud bottom end.
Dec 17, 2015 | Bass Music
Is it possible to lower the VOX VT50 transfo outgoing voltage?
bulbs have tolerance, that means it can work with + or - 6.3v just use the 7.6v which a diffrence of 1.is ok for it to work.
Jun 27, 2014 | VOX Amplification Vox Valvetronix VT50...
Vox vt40 factory reset
Consider reading the Manual for this amp, it explains how to reset to factory with the VFS5 footpedal. Or with the power off ..hold down CH1 & CH4 then turn power on.. when the Bank & Channel leds start blinking.. then release the Channel buttons. Next press the Tap switch ... the bank & channel leds will change from blinking to lit. with in a few seconds it will enter preset mode.
Apr 12, 2014 | VOX Amplification Vox VT40+ Valvetronix...
I have a vox valvetronic 50, which keeps blowing fuses as soon as it is switched on and leaves a burning smell. any ideas?
One or more parts in the power supply section is defective. I would recommend taking/sending the unit to a repair depot.
Oct 20, 2013 | VOX Amplification Vox VT30 Valvetronix...
We recently purchased the MS350 radios and are trying to use them handfree with the headsets. We plugged in the headsets, turned on the radios, but are unable to communicated back and forth using the VOX...
The three things which come to mind are:
1) Is the headset the VOX headset intended for the radio model? Sometimes the rings on the plug do not match the internal points of contact if it is not the intended headset. Not all headsets are VOX capable.
2) Is the headset plugged in all the way. (You mentioned plugging in and then turning on. This is good. You must always have the radio turned off when plugging or unplugging an audio device.)
3) Try pressing the PTT on the headset cord one time before switching the dip switch to VOX. (Assuming you have a headset with the small box in the line.)
Check your VOX/ iVOX settings. You will need VOX for using an audio device.
Lastly, if you continue to have difficulties, contact Motorola at the 800# provided in the user guide. They should be able to assist you.
Best regards.
Sep 23, 2013 | Motorola Hands-free Headset,for 2-Way...
Vox vt120+ cutting out and then coming back on. even when the jack lead is not in the jack input. the fuses all seem ok.
i live in mexico and musics stores here sucks I'm an engineer and y started experimenting i think its an IC the TAS5615 im about to order it but does anyone know for sure what it could be??
Sep 28, 2011 | VOX Amplification Vox VT20+ Valvetronix...
I have a vt50 and it has an extremely loud buzz when I turn it on with nothing plugged in. It sounds like the speaker is going to blow. I don't know what's wrong.
Yes you could blow the speaker. There is either a problem in the power supply or possibly the power amp chip has shorted to one of the power rails. Some of the vox stuff uses th LM3886 chip as the power amp. While these are supposedly protected, they can go bad. Download A schematic that MIGHT be close to your unit... it is for the VT30 but probably is similar:
http://elektrotanya.com/vox_ad15-30vt_sch.pdf/download.html
Scroll down to "Get Manual" and click on it to download the schematic. Do this test: Adjust the power level control. IF it doesn't vary the level significantly, then check the voltage across the speaker... IF it isn't less than 1 volt DC (bias) replace the LM3886 chip. Use thermal grease and any insulators they are using. Chip about $8 from Digikey.com. Note these come with two different pre-bent leads... make sure to get right ones. IF the output bias is with 1 volt DC of ground, check for bad filter caps and rectifiers.
Apr 30, 2011 | VOX Amplification Vox Valvetronix VT50...
I have a vox valvetronix vt 50 around 3 years
Nov 16, 2009 | Audio Players & Recorders
Tape stops
There is a switch on the right-hand side of the machine labelled 'VOX'. Set this switch to the 'OFF' position and you should be good to go.
'VOX' is voice-activated recording. It's designed to record only when someone is talking, and to pause when nothing is being said. In theory it's a great feature, but it never really works as good as you'd like. It'll usually miss the first few words you say, or it'll cut in & out while you're talking.
You can also set the 'VOX' sensitivity by adjusting the 'Tone/VOX' slider on the front of the machine.
Hope this helps...
Aug 13, 2009 | Dictaphone Audio Players & Recorders
JL 500/1 power problem.
There should be a small switch someware on the amp marked VOX or normal. I bet its on vox. if there is no switch then theres a jumper inside the unit to put it into a vox state. Vox Is when audio is at the input the amp goes on and when theres no voltage at the input the amp switches off.
Sep 22, 2006 | Jl Audio 500/1 Car Audio Amplifier
91 people viewed this question
 Grubhead
Grubhead
