Question about Sharp Aquos LC-42D62U 42 in. LCD HDTV
Stb refsw switch - Sharp Aquos LC-42D62U 42 in. LCD HDTV
Connecting rca tv model#F20352SF to a tv converter box
  • Connect ANTENNA OUT of STB to antenna terminal on rear of TV OR, for better picture, connect 3-wire cable to color coded L AUDIO, R AUDIO, and video outputs on rear of STB and connect other ends to L AUDIO, R AUDIO, and video inputs on rear of TV.
  • If STB connected to antenna terminal of TV, set CH 3/4 switch on rear to whichever channel is NOT used in your area.
  • Connect antenna to ANTENNA IN of STB
  • Connect STB to power and use STB remote to turn on
  • Turn on TV
  • If STB connected to antenna terminal of TV, use TV remote to select channel 3 (or 4).
  • Use STB remote to select SETUP and perform channel search.
  • Use STB remote to change channels.
Oct 23, 2016 | RCA Televison & Video
Is there any way to turn on STB so I can program universal remote?
Every STB I have has a power switch. It may be on the front panel, the side, or ?
Jan 12, 2016 | Universal Televison & Video
I have a Super California FTA decoder that wants STB pin when i switch it ON. People what can i do?
I have a super Carifornia decoder that needs a STB Pin when I switch it on... People wat should I do?
Nov 01, 2011 | Audio Players & Recorders
I need the remote code for the insignia sound bar to use with my verizon fios remote control
Jeff Phillips What I did was connec the soundbar audio directly to the Verizon STB audio out and changed the remote to control the STB volume instead of the TV. Then I plugged the soundbar into the switched outlet on the back of the verizon STB.
Nov 25, 2010 | Televison & Video
Y/Pb/Pr outputs are green; needs
There is no calibration for the component video that I know of, check your cables you may have a bad Pr cable or the Pr/Pb ones may be mixed up.
Y (the green one) is for luminance, plug in ONLY this connector and you should see a black and white picture.
Now connect the Pr. You will now see red tones.
Now connect the Pb. And you will see blue tones.
Reverse the Pr and Pb and see what happens.
Oh and make sure you don't accidently have one plugged into a composite video or digital audio port.
Still not looking right?
Go into the input menu of the TV and change the component (or colourstream) input from RGB to Y/Pr/Pb. (most TVs do not have this feature.
Hope this helps!
Jan 24, 2010 | Samsung SIR-TS360 DirecTV DTV Receiver
Can't see or listen to stb when changing input source and go back
Maybe the STB detects that there is nothing "listening" on the other end of HDMI and turns its output off. Does it work again if you turn off+on the STB without touching receiver?
Jan 18, 2010 | Yamaha Rx-v465/rxv465 Home Theater...
Thomson DTI1000 DV3 STB
since switch over I cannot get any progammes everything is connected OK ,rechecked aerial connection with another digibox thats Ok all I get is a blue screen . Can anyone help ?
It is a Thomson DTI 1000 DV3 model
Nov 11, 2009 | Televison & Video
I own a Go-Video DVD-VCR Player, Model DV3140. I recently switched to Verizon service and find that I can no longer olay my DVDs/VCRs with the Fios System. Can you assist me in how to program my player...
Hi
You can reprogram it by following these instructions--
Power turns on or off both your STB and TV when you are in STB mode. (If you have a DVR STB, the DVR will continue to record scheduled programs when off.) However, you can reprogram how the Power Key works. If you want the Power Key to control multiple devices at once --
1. Press and hold the STB key.
2. While holding down the STB key, press OK.
3. Release both keys. The Device Keys will blink twice.
4. Press 9 - 7 - 7. The STB key will blink twice.
5. One after the other, press each Device Key you want the Power Key to control, in the order you want them to turn on or off. Each selected device Key will blink twice after it is pressed.
6. Press OK when done. The STB key will blink three times to indicate success in programming.
For example, to program the Power Key to turn on or off your TV, AUX and
STB, in that order with one press of the Power Key, press [STB+OK], [9-7-7],
[TV], [AUX], [STB], [OK].
These are the codes for GO Video DVD Player--
Go Video 0771, 0768, 0810, 0896, 1071, 1102, 1185, 1757
You can view/download the manual for the fios from this link--
Verizon fios remote programming
You can visit this link for more information--
Verizon FiOS Troubleshooting
If you want to doanload the user manual for your verizon set top box you can get it from here
Please do accept this solution and revert for further assistance.
Thanks
Rylee
May 30, 2009 | Televison & Video
Sharp Aquos LC-42D62U 42 in. LCD HDTV Logo
21 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
