Question about Philips Azur Gc4850/02 Steam Iron, 2600 Watt, Pale Blue
There is an earth to neutral fault internal and I need to take it apart how is this done
Short in wire - turns on but then shuts off with movement- then on again
THIS HAPPENS WHEN THERE IS A SHORT CIRCUIT OR THE POWER CORD IS DAMAGED.A REPLACEMENT WILL SOLVE THE PROBLEM.
Regards.
DON'T FORGET TO RATE MY SUGGESTION
Jul 06, 2011 | Black & Decker D2030 Iron
I have a Bush IN632 steam iron which is not generating steam. Can anyone point me in the correct direction as to what the fault may be?
took mine apart found that the base unit had limescale build up to such a level that the whole water chamber was full of limescale. Need a special security screwdriver
Jan 30, 2011 | Oreck TS100 Iron
Steam iron is not heating.
Yes you most likely can, they are very simply consisting basically of, a switch, a thermal fuse, a thermostat, and an element.. all wired into the Phase wire, the neutral, is simply the return. Take it apart and draw a diagram of how it all goes together and reverse the procedure.
May 09, 2010 | Irons
I have kenmore 81669 iron it is not getting hot
This usually happens for one of a few reasons, Check, Thermal Fuse, Check Element, Check, on/off switch. Check power cable, for continuity.Check Thermostat, Thats all there is inside an iron, Power comes in the Phase, the Black, or Brown wire, then, through the on/off switch, through a Thermal fuse, through the thermostats contacts, to the element, and the other side of the element goes to the Neutral return. usually White or Blue.of course the Earth is Green or Green/Yellow, stripe.and is connected to the metal case..
Apr 23, 2010 | Kenmore Professional SR365S Iron with Auto...
I replaced the badly worn cord on a Phillips steam iron and everytime I switch it on it throws the circuit breaker. I am assured that the iron was working OK before I replaced the cord, but because it is a...
There is a break in the insulation somewhere and tge wires are getting crossed or the active wire insulation is broken and it is shorting to the eaarth ground.
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Jan 23, 2010 | Micro Pro 7599 Iron
Hey there, Please guide me for the wire connections for Shark GI490 Iron along with the color code so that it can work back again. I will appreciate you assistance.
The advice given here is totally incorrect. Please ignore Azraelsrl solution. Being incorrect makes it very dangerous!!!
Blue or black = Neutral red or brown = phase green or green/yellow = earth.
If in doubt, you should get a qualified electrician to replace the cord to your iron. Getting it wrong... can easily kill someone!!!
regards robotek
Dec 06, 2009 | Euro-Pro Shark GI490 Iron
Iron just stopped working, no lights, no heat no iron Opened back panel to make sure no loose wires or damage inside. The inside still looks bran new and the wire cap connectors are intact. Iron may be 2-3...
check plug fuse, if ok, check continuity of the live, neutral and earth conductors for a break. if ok, element may be faulty. Any smell of carbon burning?
Oct 26, 2009 | Irons
2 yr old Tefal Pro Express Steam generator Iron Trips Fuses
hello does all the electric go off in your home if so theres a bad earth on the iron or the iron element is shorting out also make sure theres no water getting into the iron good luck
shaun
Mar 20, 2009 | Tefal UltraGlide plus 1656 Iron
Taking a Rowenta DX1900 Apart
To get the base off, you have to remove the 2 screws from the face.
the button for the reel has a screw behind it, that needs to be removed.
Take a thin piece of metal, like a spark plug gapper, and slide it in the side to push back the tabs. You have to do it on each side. Remove button and take out screw. The base will come off.
Now you need a special torx srewdriver that allows for the center of the screw to enter the screwdriver.......
Learned the hardway and didn't have the correct torx..... Good Luck
Feb 27, 2008 | Irons
Philips Azur Gc4850/02 Steam Iron, 2600 Watt, Pale Blue Logo
20 people viewed this question
Top Philips Irons Experts
ray gallant
Are you a Philips Iron Expert? Answer questions, earn points and help others
