Question about Magnavox MDV3000/F7 Player
Disk does not spin - Magnavox MDV3000/F7 Player
My PS2 Slim disk wont spin. No type of disk DVD, CD, Or anything will make it spin. New CD tested, still not spinning. I heard there is a laser that reads the disk. I tried cleaning it(Open up the disk...
there might be som problem with the disk driver and it might be due to starter also ..u try to remove the top of the driveand try spinning by yourself and it will start automatically and if not u can try this site to check this site
Nov 12, 2010 | Sony PlayStation 2 Slimline Console
My notebook suddenly shut down itself, then after i restart, it show select which drive to boot (but no option to let me select). Then i try to reformat it, but it show no harddisk install? i have try...
This means that no "bootable" CD-ROM was loaded into the CD-drive, *AND* that the "bootable" files could *NOT* be read from the disk-drive.
> it show no hard-disk install
Well, it shows that either:
* no electrical power is reaching the disk-drive
* the electronics "underneath" the spinning-part of the disk-drive have failed
* the "spinning" part of the disk-drive is not spinning (dead motor?)
* the disk is spinning, but nothing can be read from the disk-drive.
Try connecting the disk-drive to another computer.
If it is detected, that's good.
If not, then your disk-drive has a BIG problem,
and replacing it (with or without exercising any "warranty'") is your only way to move forward.
Sep 30, 2010 | ASUS A3Ac Notebook
Disk wont spin
The lens assembly is directly associated with a non spinning disk issue.
Here was my situation.
I purchased a used PS2 slim from an ebay seller that had the disk read error. I bought another lens from another ebay seller and when installed it, the disk would not spin. I then replaced the new lens assembly with my old one and the disk started spinning again but I still had the disk read error. I contacted the seller to send me a replacement lens assembly for the defective one I received.
Bottom line is if your lens assembly is bad, the disk will not spin. You can replace the lens assembly for about $4 or $5 on ebay.
This mostly occurs to all slimline PS2 it is a common problem.
Mar 20, 2010 | Sony PlayStation 2 Slimline Console
What do i do if the thing that spins the disk is not spinning?
see if there is anything stuck in the spinning thing any little thing
Feb 15, 2010 | Sony PlayStation 2 (PS2) Console
Ps3 blu-ray player will not work
No it will not.... It surges the disk 2-3 times senses there is a disk and then starts it spinning if there was a disk in there.
Mar 03, 2009 | Sony PlayStation® 3 (60 GB) Console
"No Disk" message on front display
If when you insert the disk you hear a whirring and clicking noise, CD spins, and does not read, then that is a problem with the DVD lens.
The DVD lens try to focus on the DVD track, by moving lens pickup and spinning the disk, but cannot read the tracks because the lens is dirty or defective.
Try first cleaning the lens with a DVD cleaner disk. And also if you can see the lens from the outside try blowing some canned air on it.
If this still does not help, then the lens pickup may be faulty, in this case you often replace the whole DVD drive unit inside the DVD player.
Dec 27, 2008 | Pioneer DV-343 DVD Player
Pioneer PD-F907 CD wont play most of the time
MOST LIKELY IT SOUNDS LIKE THE MOTOR THAT SPINS THE DISC - NEEDS REPLACING
Jun 26, 2008 | Pioneer PD-F907 CD Player
Disk doesn't spin up
check the disk, clean it, put back in. disk my be bad.
Nov 24, 2007 | Sony PlayStation 2 (PS2) Console
1600 DVR disc don't spin anymore
check the motor it could be bad.good luck.
Apr 18, 2007 | Cyberhome DVR 1600 DVD Recorder
Magnavox MDV3000/F7 Player Logo
14 people viewed this question
Top Magnavox Televison & Video Experts
Demonic-2011
Demonic-2011
Tom Chichester
Are you a Magnavox Televison and Video Expert? Answer questions, earn points and help others
