Question about Cooper Wiring Devices Combination Switch & Receptacle
Trying to wire switch and plug combination where the switch will turn off the plug
    Sergeant:
  • 272 Answers
Black wire to brass connection on switch. White wire to silver connector on receptacle. Add a wire from the silver side of switch to the brass side of the receptacle. When switch is on current flows through to it to receptacle then out white when something is connected to the receptacle.
Posted on Feb 03, 2015
Switch /comb gets hot in wall
This is fire hazard.
Call electrician.
What is plugged into outlet?
Are wire and breaker sized correctly?
Do you have aluminum wire?
http://waterheatertimer.org/Color-codewire.html
Otherwise turn off circuit breaker, pull out device and inspect for melted wires.
Use nose to find source of heat and burning.
Inspect if you have aluminum wire. Do not use aluminum wire.
Aluminum wire will burn down your house today.
Use only copper wire.
Replace combination device with new.
http://waterheatertimer.org/How-to-wire-combination-switch-outlet.html
Apr 17, 2013 | Pass & Seymour #691CC6 Comb...
How can I fix the back lights on my 2002 jeep grand cheroke Laredo.
I assume "back lights" refers to the rear lamps and that "light fixture" refers to the entire right rear lamp assembly. There is a combination flasher in the junction block that controls flashing of the turn signals and the hazard function. The multi-function switch (on steering column?)selects left and right turn signals and the hazard operation. If the left side tail/stop lamp and turn lamp are OK, compare the lamp installation on the left rear with the lamp installation on your new right rear lamp assembly. If all checks out, turn on the park lamps and check the BLK/YEL wire for 12 volts to the tail light filament of the combination lamp. Next, turn the ignition switch on but do not start. Set the turn signal switch (MFS) for a right turn. Check the BRN/RED wire for 12 volts to flash the separate turn lamp. Finally, have someone step on the foot brake and check the WHT/TAN wire for 12 volts to the stop light filament of the combination lamp. If any voltage is missing, the trouble may be in the combination switch, the multi-function switch, or due to a missing ground connection (BLK wire) to the right rear lamp assembly.
Sep 09, 2012 | Jeep 2002 Grand Cherokee LAREDO
How to wire a combination switch & receptical to plug in a garbage disposal?
Bring a cable with 3 wires (hot, neutral, and ground) into the combination switch and receptical. The hot wire connects to the LINE portion to power on the receptical. Use another cable with 3 wires to connect the LOAD portion on the switch to power on the disposal. The black wire is the HOT wire that should be switched. The white wire is the NEUTRAL that can be tied together, and the green wire is the GROUND that can also be tied together.
Aug 14, 2011 | Hardware & Accessories
Hello I have 2 black wires and 2 white wires coming out of the wall. With 1 ground My question is I want the switch to turn on/off the out let. How do I wire this up? Cheers, D.
Leviton 8299 combination switch and receptacle with GFCI manual
http://waterheatertimer.org/pdf/Leviton-8299-instruction-manual.pdf
You don't say what kind of device you are replacing.
Instructions below may be way off base if you are trying to replace a 3-way switch.
Instructions below are for replacing a switch-plug combo.
Add a comment any time, and clarify your device your are replacing.
Electricians don't guess, they test.
First thing we need to test is Hot and Neutral wires.
Note where each wire was connected to old device before removal.
Note the wire that was connected to brass, dark, and silver screws.
The screw color is coded, and will verify testing.
Separate wires and turn on power.
Test each wire to bare ground wire.
Tester will light up on Hot wire. Mark the hot wire.
Test Hot wire to each other wire (except bare ground wire)
Tester will light up on Neutral wire. Mark the Neutral.
The other two wires are presumed to go to Load (light, fan, motor)
Now lets look at back of the 8299 device.
On back of device directly behind receptacle part of device is the word LINE.
Hot wire connects to brass colored LINE screw.
Neutral wire connects to silver colored LINE screw.
These two wires will power the device, and power the receptacle.
Next we want to wire the switch.
Notice on drawing below, that switch Loads (light fan motor) are connected to two wires on back of 8299.
Again referring to back of device as reference point, black wire going to Load connects to wire on left side. White wire going to Load connects to wire on right side.
Now turn on power and test that switch and receptacle both operate as expected.
If operation is not correct, then add a comment and say what the second black and white wires connect to.
Dec 22, 2010 | Leviton 8299 Combination Switch / Smart...
Wipper fuse keeps blowing out
As the question is concerned i think it is a electric circuit problem.. So you need to follow these instructions to curb the problem.
You'll need a voltmeter / continuity tester to test the windshield wiper switch, your ground wires and the wiring between the motor & the switch. You should be able to figure out where your problem is and fix it. It's just going to take you time to isolate the problem. If you're not familiar with troubleshooting electrical problems, then you'll have to take your car in to a mechanic or automotive wiring specialist.
Thanks for using FixYa - a 4 THUMBS rating and POSITIVE TESTIMONIAL is appreciated for answering your FREE question.
Oct 25, 2010 | 1997 Toyota Celica
I have a 12/2 w ground source. I want to use a Leviton 5224 combination switch to control a double plug. The top swithch for the top plug and the bottom switch for the bottom plug. I will use 12/3 with...
from power source black/hot wire to switch, white and bare/ground wires wire nut white to white bare to bare. run then to outlet white wire to silver screw bare to green screw. black wires to outlet from top switch to top of outlet bottom switch to bottom outlet break off fin on hot side of outlet should be brass screws dont' forget to turn off power before you start.
Nov 04, 2009 | Electrical Supplies
On my 1996 Mustang GT, when I turn on my headlights, my dashboard lights go out. Is that a fuse, ground or some other issue?
The proposed problem sounds like the problem I had with a 95 Mustang. Check the tail lights as well as the dash lights. If both are out when the headlights are switched on, the problem more than likely is with the headlight switch. The 95 had a poorly designed wire and plug configuration going into the switch. The wiring was too small and the plug would literally melt. The headlight switch and plug has to be replaced in this case. The problem was supposed to have been cleared with the 96 Mustang; however, a persistent problem may suggest checking the plug/switch combination.
Aug 29, 2009 | Ford Mustang Cars & Trucks
How to wire 4 prawn 250 volt plug
The 2 wires coming off the double breaker should go to the x & y of the plug. The ground should go to ground (green or bare) and the other prawn left over is the neutral wire, it goes to the buss bar in the breaker box with the grounds ( usually with a bunch of white wires )
Apr 05, 2009 | Cooper Wiring Devices ACE AC-DC...
Cooper Wiring Devices Combination Switch & Receptacle Logo
172 people viewed this question
Top Cooper Wiring Devices Electrical Supplies Experts
ken skalski
Jim Y
Jim Y
Are you a Cooper Wiring Devices Electrical Supply Expert? Answer questions, earn points and help others
