Question about Camelbak Camping, Backpacking & Hiking
Get cap off fill - Camelbak Camping, Backpacking & Hiking
I need to know why the Hoover Max Extreme keeps telling me t check the tank?
Hi! The solution and water goes in the top tank. Dirty water is suctioned into the bottom tank as you're scrubbing your floors. To fill the clean water tank, remove the clean water tank cap. The cap serves as a measuring cap for the solution. Fill the cap with Hoover carpet washer solution to the fill line. Pour detergent into tank. Fill the rest of the clean water tank with hot tap water and twist the cap back on. You are now ready to clean. Hope this helps!
Aug 20, 2014 | Hoover SteamVac F5914-900 SpinScrub...
Tip
Cheap coolant overflow cap
Contaminated coolant contributes to engine damage by clogging up the radiator, reducing efficiency of the coolant to remove engine heat. an uncapped overflow tank is a route for debris and contaminents to enter your cooling system and if ignored, circulate crud thoughout the system and clog your radiator. So if you have lost your coolant cap,(which is easy to do) dont just say "oh, well" there is a temporary fix that will keep your coolant clean until you can get to an auto parts store and replace your cap with the proper cap. all you will need is a plastic bottle, or container cap and some electric tape, or, yes, even duct tape. eyeball the approximate inside diameter of the radiator overflow tank fill hole. place the bottle cap over the fill hole, but dont let go of the cap. if the cap is smaller than the hole wrap electrical, or duct tape around the cap a few times and replace bottle cap over the fill hole. the cap should fit snug in the fill hole. make sure you dont press cap into the fill hole too deep that you cant pull it out with your fingers. if you do you can pull it out with needle nose pliers. this will keep your coolant clean until you can get to an auto parts store and replace the cap with a proper cap.
on Dec 28, 2010 | Dodge Ram 1500 Cars & Trucks
Can my fuze for fan on radiator be bad
first change thermostat , when filling with coolant let the cap away start engine then fill her up until thermostat open then put back the cap ,, fill the reserve tank to the mark.
Apr 29, 2014 | 1999 Chevrolet Cavalier
Filling radiator
find radiator cap , either on the radiator or header tank ! remove cap and fill till just below rad cap hole or if header tank fill to max line on the side of tank ! P...
Nov 21, 2013 | 2005 Honda CBF 500 ABS
I can not find my oil cap in my 1971 Ford mustang Mach 1 where would it be at?
Look on the drivers side front of the valve cover and you will see the oil fill cap. It is the large cap with a hose connected to it. Here is a photo of the oil fill cap located, lower part of photo dead center. clay58_51.png
Jun 03, 2011 | Ford Mustang Cars & Trucks
Is the only way to fill the coolant for my Honda Shadow Sabre 1100 is by the small cap near the passengers right foot peg?
I filled my radiator with coolant by removing the cover on the right side of the gas tank just behind the handle bars. When you remove the cover, you will see the radiator cap. Remove the cap and begin filling with the appropriate coolant.
Sep 20, 2010 | 2002 Honda VT 1100 C2 Shadow Sabre
Transmission fluid
alot of the newer cars do not have a checker. If you have no leak then its full. You just service it at the recommended intervals. How you fill them is you have a drain and a full cap. You remove the full cap and fill till it comes out. The fill cap is on the side of the trans and is accessable from the bottom
Jul 29, 2010 | 2007 Pontiac G6 GT Convertible
How do i fill my reservoir and radiator
make sure the engine is cold, if you try to open the radiator cap while engine is hot you can get badly burned. get a container of coolant mixed with water, should be 50/50 mix. first open the radiator cap, which is at front of engine compartment near the center. roundish cap with 2 wings on sides. turn counterclockwise while pressing down to release cap. then fill to top with coolant mix. replace cap, turning clockwise till tight. then follow the small rubber hose from radiator cap area to the coolant resevoir. this container doesn't need to be filled completely, it has a full line. fill to that.
Feb 20, 2010 | 2003 Honda Civic
HOW TO FILL RADIATOR ON V6 WITH TWO CAPS TO
Just fill the engine one and check in a day to top off the reservoir.
Jul 02, 2009 | 1993 Toyota Camry V6
Camping, Backpacking & Hiking Logo
53 people viewed this question
Top Camelbak Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Camelbak Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
