Question about Welding Tools
Hydraulic diagram for bobcat t190
I have a major leak in the hydraulics and need help to find which hose it might be.
2 Suggested Answers
mastermaid
  • 502 Answers
SOURCE: Hydraulic system of Bobcat 642b
Ask here, they will find every Bobcat manual or schematics.
Posted on Mar 06, 2011
I need help with the hydraulic system.
The hydraulic system is the problem either the PTO is leaking or not pumping this controls all of the switches lights .Check your fluid levels and all filters in line look for leaks
Aug 27, 2016 | Seat Cars & Trucks
How do you bleed the hydraulics on a Bobcat 751 skid steer loader?
Hi Joseph:
Usually hydraulic components will "self clear" any air in the system just by trying to cycle through the functions a few times.
Have to ask the question............
Did you remove and replace the hoses one at a time, or did you take them all off at the same time?
The reason I ask is............ Could there be a remote possibility that any of the hose onnection locations were switched?
Sep 23, 2015 | Toys
How do you remove motor in 863 bobcat
Removing the motor would be my last resort. That is a bunch of work.
Be sure that you are totally sure that you can't get the hose while the engine is in.
Remember that working with hydraulics can be dangerous. Lower or support all equipment, and releive hydraulic pressure before disconnecting lines.
HINT: If the ends of the hose are accessible, disconnect them and tape a piece of cord to one end. Then ease the hose out of the restricted space. Leave the cord there, and use it to ease the replacement hose back in.
STAY SAFE!
Mar 16, 2015 | Toys
I have a 642B that the parking brake will not engage with the switch can anyone give me some advice as to what the problem can be.
a bobcat 642 has hydraulic parking brake , if the switch does not high light when pressed could be its bad if switch hiltes but unit still moves then hydraulic solinoid is leaking by or in rare cases your hydraulic axle motor has leaking seal (look on gound where machine sets overnight)
Sep 30, 2014 | Air Tools & Compressors
I have a t190 bobcat when you run it for 5 min the brake locks up
hi
i dont know this vehicle but would suggest you must have either a seized caliper / wheel cylinder or a hydraulic leak on your braking sytem. when you get the brakes warmed up the fluids reacts and locks them up. which wheel?
Poss your handbrake is not fully releasing which would soon lock up a wheel. jack it up, release brake and see if the wheels spin freely.
cheers
Roger
Apr 21, 2014 | Cars & Trucks
Need 773 bobcat auxiliary control wiring diagram, hydraulic diagram
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Bobcat 773
Apr 30, 2012 | Bobcat 773
2004 bobcat t190 w/ 04-09 error code. engine oil is breaking down prematurly. i know the code is low oil pressure. what r the chances my oil cooler is stopped up not allowing oil to circulate through it. i...
Oil cooler on that machine is for hydraulic oil. Is your fault for engine oil psi or charge psi? Charge psi unlocks brakes. Premature engine oil breaking down check for fuel in engine oil through lift pump or injection pump.
Mar 06, 2010 | RTO Construction Bobcat by Woody Click
Welding Tools Logo
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
