Question about Dell 2335dn Multifunction Laser Printer
Dell 2335dn causes w 7 pro to exhaust memory
Dell 2335dn MFP application suite for W7 Pro-64 bit causes two different desktops to hang after 6 to 8 hours after system boot. The event logs show that services and processes started dying because quota has been exceeded and there is no free memory. One time we got a System Service Exception Bugcheck that pointed to Virtual Memory exhaustion. Dell has released multiple versions of the application suite since Oct 2013 and all of them pose the exact same issue. If we don't install the software, the desktops do not end up hanging. One item that keeps popping up is the Dgivecp service cannot be started due to a missing file. Dgivecp is a Samsung printer file.
Beni S-P
  • 1006 Answers
SOURCE: says driver not installed, gives runtime error
Download this program and run it:
Couse i think it can be registry problems
and run CHKDSK /R then restart pc
If u got help please rate this solution as FIXYA
Posted on Nov 20, 2007
  • 1224 Answers
SOURCE: dell laptop memory install
available physical memmory is what all your programs on your comp is using like windows virus software drivers im thinking you probably have spyware or bugs in your comp that could be bringing memmory down
total physical memmory is what you just put in
Posted on May 09, 2008
  • 69 Answers
SOURCE: hardware error:0502
1. Ink cartridges lids are open which is not allowing cartridges to move freely.
2. Ink cartridges carriage will not move from its original position(left) when front cover is opened
3. Encoder strip is Dirty.
4. Encoder strip is Out of position.
1. Open the front cover and check if ink cartridges lids are properly snapped in.
2. Turn the printer off and pull out the power cable from power socket, open the front cover and manually center the ink cartridges carriage.
Clean the metallic rod inside the printer using WD40 or Kleenex from Left corner to right corner properly.
3. Cleaning the encoder strip:
a. printer should be off and disconnected from power.
b. open the front cover.
c. Using a dry, lint free cloth, pinch the encoder strip on the right-hand side of the cartridge carriage and pull your fingers across it toward the right-hand side of the printer and you can move the cartridges carriage to clean the strip completely.
d. Note: The encoder strip is a narrow band of clear plastic and can be difficult to see without direct lighting running parallel to metallic rod.
e. Close the printer and try again to print.
4. Repositioning the Encoder strip.
a. Remove the power cord from the printer.
b. Open the front cover.
c. Gently slide the ink cartridge carrier to the middle of the printer.
d. Gently move the top part of the printer belt to the right.
e. Using an index finger, gently push encoder strip down and then back up, to get it back into the slot located on the back of the ink cartridge carrier.
f. Gently press the strip first to the rear, and then forward, to ensure that it is seated correctly.
g. Manually move the ink cartridge carrier to the left, then to the right, to check the positioning of the encoder strip.
h. Once the encoder strip has been re-seated, close the scanner lid.
i. Re-connect the power cord to the printer and try again to print.
Incorrect position of encoder strip
Correct position of Encoder strip
Hope it should fix the issue.
Posted on Nov 07, 2008
  • 340 Answers
SOURCE: Service Manual for Dell 3110 Printer?
Hi Rockdude :-)
you can download you manual from HERE: - you have to log in, but its free.
regards /Teis
Posted on Jan 09, 2009
SOURCE: 1720 Dell Laser printer Photoconductor Problem
I finally figured it out (with Dell Tech Support's help)! When you replace the drum, you MUST reset the counter as well. All you have to do is:
1) Turn off the power using the switch on the back of the printer. Open the front door of the printer.
2) Hold Continue button down, power on the printer, and continue to holding Continue down until the LEDs begin to flash. When the LEDs start to flash, release Continue button. The LEDs will continue flashing until only Error LED will be lit.
3) Close the front door. Continue, Ready/Data, Toner Low and Load Paper LEDs should be lit.
4) Wait till the printer completes the POST process. POST is complete when fan noise and rollers stops. After POST wait for 5 seconds
5) Press Cancel button 4 times slowly until the Toner Low LED is lit. This is the procedure resetting the counter.
6) Press and hold Continue until all LEDs begin to cycle in sequence, then release Continue. Now only the Toner Low LED will be lit.
7) Cycle the power of the printer (turn it off and then back on).
Posted on Apr 16, 2009
I want to upgrade my window 32 bit to 64 bit in dell optiplex 380 PC. but i don't have win CD or any recovery drive..didn't receive any system restore cd from dell.. what to do.?
1st ur oem dell key found on ur pc is compatible with both 32x and 64x but u must backup ur os before reinstalling use windows 7 maintenance section to do a full backup
2nd check ur oem version if on the key if pro or home premium then google to find an iso compatible with ur version but 64x after that head to the dell website and download the specific drivers
Dec 21, 2013 | Computers & Internet
Upgrade window 7 32bit to 64
Dec 21, 2013 | Dell OptiPlex 380 PC Desktop
W7 64 bit pro
These are the specs, but I don't see 64 Bits support. Hence it must be running 32 bit and Windows 32 Bit has a 3GB limitation. Furthermore, even if it did recognize it. Your applications must be written to utilize more RAM. For instance I have 16GB and never seen the usage go more 3GB.
2 x DIMM, Max. 4 GB, DDR2 533/ Non-ECC,Un-buffered Memory
May 17, 2013 | ASUS P5VD2-X Motherboard
Need to flash BIOS
Here is the link for your Dell Dimension E520 updated BIOS version 2.4.0 released on 7/11/2007. One confusion Windows 7 is not recommended by DELL for your model!
Oct 21, 2012 | Computers & Internet
Installing adobe acrobat pro 6 to windows 7
This is an old version of Acrobat that was written for NT, Win2K and XP. Due to changes in the OS, it's hard to get the program to install in Windows 7.
Which version of Win7 do you have? (32-bit or 64-bit and Home Premium, Pro or one of the other variants) Since you indicated this under the Dell Dimension E521 with 1 GB of memory, I'll guess Win7 Pro 64-bit. (This uses the 64 bit CPU) You can check by clicking Start > Control Panel > System and Security > System. If the Windows version ends with x64, it is the 64-bit version. Otherwise, you have the 32-bit version.
Under the 64-bit OS, you need one of the following workarounds: a second computer, a dual boot computer or a virtual computer running an older version of Windows. If your hardware supports virtualization, this might be a good bet if you can add memory to computer. With Win7 Pro or Ultimate, you can download and install Virtual PC and XP mode from Microsoft and run XP for free. Then install Acrobat in XP mode as if it were your only machine. (Note: the Virtual PC requires a share of your total memory and doesn't give it back to the main computer while it is running.)
The other methods listed require a licensed version of an older Windows OS.
If you have the 32-bit version of Windows 7, you can try the compatibility mode. Right click on the installer and choose Properties. In the compatibility tab, check always run in the compatibility mode and select an older version of Windows. Then click Apply to save the changes and then click OK. Then right click again and choose Run As Administrator. You may have to repeat the compatibility mode changes for the program itself.
You may want to consider upgrading to a Windows 7 compatible version of Acrobat. The current version is Version X.
I hope this helps.
Dec 26, 2011 | Dell Dimension E521 AMD Athlon 64 X2...
I have a dell inspiron 531s. it is freezing off and on. it would work well for a day then it would just freeze, not responding to the mouse or keyboard. i have reformated the hard drive change the memory...
I had the same issue. I upgraded to Windows 7 and things did work allot better but the hanging still occured. I ran system mechanic and found there was a drive problem. This was repared by the program.
The problem occured again last night and the system will not boot past the dell splash screen. I am thinking it might be the motherboard that is a fault. Mine is out of its 12 month warranty, so no way to get Dell to investigate further. Also check the systems logs after the hang happens and see if there was something logged that caused the hang.
I hope this helps?
Jan 01, 2011 | Dell Inspiron 531s Desktop Computer
Vista 32 Bit verses 64 Bit
Before you jump in and upgrade make sure your computer system is 64 bit ready otherwise it wont work at all....upgrading memory is never a bad thing will actually speed up things from running and will have a better response 7 does not require 64 bit but it desired if possible....
Apr 11, 2009 | Dell Dimension 3100 PC Desktop
Dell Inspiron 1525 Memory Card Reader Compatibility
There is no big differece between the two. Both of those can work on your DELL memory card. Cheers!!
Jan 25, 2009 | Computers & Internet
Dell 2335dn Multifunction Laser Printer Logo
37 people viewed this question
Top Dell Office Equipment & Supplies Experts
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
