Question about Frigidaire Washing Machines
Fwfb9100eso spin cycle doesn't work
Frigidare fwfb9100eso will not spin , but makes a noise when in spin mode
Posted on Mar 25, 2014
Wont spin
Good Morning Anthony,
I see that you are having trouble with your Frigidaire washer, model# FWFB9100ES0 not spinning. There are a couple things I would do. First check the dispenser drawer and make sure it is closed. This can hinder the appliance from spinning the clothes out. Another thing to check would be that the load isn't too small. If it's a small load it can become unbalanced. Add 1 or 2 similar items to help balance the load. If these suggestions do not work, you can always try resetting the washer by either unplugging it or cutting the power at the circuit breaker for at least 2-3 minutes. When you restore power try the cycle again. If you are still having trouble, I suggest contacting either the manufacturer or your local authorized technician. I hope this has helped.
-Best Regards-
WP
Mar 25, 2014 | Frigidaire Washing Machines
INDESIT WIB101 WONT SPIN
Have you checked the lid safety switch? Even if it doesn't spin, the cycle timer will continue.
Nov 16, 2013 | Washing Machines
Kenmore Washer Doesn't Agitate
Don't be too sure the drive coupler hasn't failed or is failing
Jun 15, 2013 | Kenmore 24032\24036 Top Load Washer
Spin cycle doesn't work...sounds like its spinning but it's not.
Does it agitate in the wash cycle?if not, you need to check the "motor coupling" on the unit. Below is a video to show you how. Here is a kink to the part.
Aug 03, 2011 | Roper RAS8445KQ Top Load Washer
Spin cycle will not work on siemens xlm 1400 and filter has been cleaned what to do
If the spin cycle is not working, it could be several things. How is it not working? If it won't do anything, i.e. doesn't turn, then I would suspect the transmission since the spin cycle is the high side of the transmission. If it spins but does not take the water out of the unit, then I would suspect, either the pump or the timer.
Good luck and have a great day!
Jun 09, 2011 | Washing Machines
Will not fill with water but works on spin cycle
If your washer won't fill with water, but works in the spin cycle then the washer is sensing that water is in the tub. If there isn't water in the tub, then it is probably a sensor. If there is water but the spin cycle doesn't get it out, then look at the pump or control board.
Jun 08, 2011 | Maytag Washing Machines
Model GLTF167A0S0 Serial XC22704657... The final spin frequently doesn't work. I tried another wash cycle and the "high speed" spin didn't work. I can manually start the cycle and it...
If the water is pumping out fine you may need new shocks. But if it is slow pump the shaft on the pump is loose and causing the noise and possibly the spin issue. If it is loud when it does go into a spin (sounds like a jet engine) you have bad bearings. Big bucks to fix.
Jun 03, 2011 | Frigidaire GLTF1670A Front Load Washer
MY MOFFAT WASHER SPIN SCYCLE WILL NOT WORK THE WASHER WIL NOT SPIN TO REMOVE THE WATER
moffat washing machine does not remove water after spin cycle
May 29, 2010 | Washing Machines
Spin cycle doesn,t work
Hi. this is a failed timer device. simply replacing the timer control module will eliminate these issues you are having.
May 27, 2009 | Roper RAX7244KQ Top Load Washer
Washing Machines Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
