Printshop 6 abnormal program termination fis - Computers & Internet
2 Suggested Answers
SOURCE: quattro pro x3 abnormal program termination
1. Click Start, Programs, Accessories and Run.
2. In the open window, type: regedit and click OK.
3. Choose the following path
HKEY_CURRENT_USERS\Software\Corel\User\Assistant\13\Recent Work\Quattro
Pro\
4. Right click on the Quattro Pro folder, select delete.
5. Say yes when prompted to delete the key.
6. Close the Registry Editor
7. Launch Quattro Pro
This key will be re-created when you reopen Quattro Pro. I ran into this problem when when I tried to open a QP SS on my hard drive after previously opening one from my thumb drive. Now I copy to my hard drive first.
Posted on Dec 06, 2008
Runtime error abnormal program termination
Sounds like you have ran a scan on your drive and the software has become corrupt.
Download the utility from Seagate and try again
Feb 08, 2014 | Seagate Back Up Plus Desktop Drive...
Installing print shop 23 on windows 8.1 get framework incompatibility error. what should i do?
I now have PrintShop 23.1 up and running on my Windows 8.1. This is what worked for me:
1. First, RIGHT CLICK on the Printshop icon on your desktop, select Properties, click on Compatibility, and make the selection to run the program in Compatibility Mode for Windows 8. Click Apply, then OK to exit.
2. Double click the Printshop icon on your desk top to open Printshop. If it works - great! However, if it does NOT work, it means the .NET framework required to run the program was uninstalled or corrupted by the Windows 8.1 upgrade and needs to be reinstalled, so please do the following.
3. From your Control Panel, select Programs and Features; in Programs and Features, uninstall Printshop. (You get to the Control Panel by clicking on Settings in your desktop popout taskbar, usually on the right side.) 4. Check to make sure the Microsoft .NET framework is also uninstalled. If not, attempt to uninstall. If you have recently gone to Windows 8.1, it may be partly or fully uninstalled because the 8.1 upgrade might have removed (or damaged) part of it. If it will not uninstall, don't worry! Proceed . . . 5. Follow this step even if you see no sign of the .NET framework in Programs and Features. It is almost certain that you have debris from it on your computer because this is a known problem, and Printshop will not reinstall unless the debris is removed. THEREFORE, clean your computer by using the Microsoft .NET Framework Cleanup Tool found at the following link:
.NET Framework Cleanup Tool http://blogs.msdn.com/b/astebner/archive/2008/08/28/8904493.aspx
6. AFTER Printshop is once again installed, it will very likely NOT RUN unless you follow Step #1, above, to run it in Windows 8 Compatibility Mode.
Dec 20, 2013 | Broderbund The Print Shop 23 Deluxe
Broderbund print shop signature greetings older program won't install on my windows 8 pc
It will not install. That is why I kept my old xp computer. Some older programs will not run on Windows 8 and newer as they use apps to run the program. You can see of printshop has an app. As for installing the program using the cd...forget it.
Oct 15, 2013 | Broderbund PrintShop Signature Greetings...
Runtime error that says abnormal program termination
i tried and it worked like this
deinstall windows sp 3
download microsoft 2008 c++ library
install vcs 1.0
install update vcs 1.0 may 2008 from panasonic support
May 06, 2009 | Panasonic SDR-H60 HDD Camcorder
I have an old printshop deluxe program and i am not able to load it into my new comp with vista.I love that program. I like the borders and i know how to use it.lol anyway it tells me my computer isnt...
This is one of the most common complaints with Vista - your old programs may not work. Your only solutions are to either buy a copy of Windows XP (what I would do, personally) and lose the Vista, or find a Vista-compatible version of Printshop. You can try this link, which Microsoft says it will update for free to make your old printshop compatable. If that doesn't work, there are 1000's of excellent free print programs at download.com here.
Apr 18, 2009 | Broderbund PrintMaster Platinum 16
Picture it 2002 terminates when trying to open a project
Hi all!!! I am soooo excited!! I found a solution to fix the abnormal program termination with my picture it 2002!!!! Many, many thanks to John Inzer who made this info available!! I am no computer expert, but persistence and research paid off! My software is now up and running!!!! Click on the link below: microsoft.com/downloads....etc.
The best part is that it doesn't cost anything!!
Eve
Albirt wrote:
> Hi. I am having same problems with picture it.
> "Runtime error / abnormal program termination" message when I try to
> open picture.
> Windows XP and Picture It 2002 Photo.
> Could you reload file to yousendit ?
> Thanks
No problem....try the following link:
http://www.yousendit.com/download/UmNLcmxTSWVrWS92Wmc9PQ
The patch is also available from
Microsoft Download Center:
Picture It! Publishing 2002:
Patch for 19299 (PI19299.exe)
http://tinyurl.com/dfeq28
or...
http://www.microsoft.com/downloads/details.aspx?displaylang=en&FamilyID=0fb68178-d6bd-41bd-9f00-f44ac7ca9e28
Mar 08, 2009 | Microsoft Picture It! 2002 for PC
Program "Printshop CD Label Creator
the problem will solve after registration. go to the printshop web site and register your product.
Nov 26, 2008 | Computers & Internet
Install Printshop V.5 on a computer using Vista
The Printshop V5 program is supposed to run with Windows 98 or Me, therefore in order to use it with Vista or XP, you should open it using Compatibility mode--> Right click on the program icon--> properties-->Compatibility--> select Windows 98 or Windows Me
Oct 31, 2008 | Computers & Internet
Can not load your program printshop 2009
What makes you think that PrintShop 2009 is somehow OUR program? Fixya doesn't produce software but it does produce techs to help with your software issues.
Print Shop is produced by the company here
Questions concerning specific issues about program installation or loading might best be taken there
Aug 24, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
