Question about Honda Eb 3500 Generator
Not producing electricity - Honda Eb 3500 Generator
Can you describe electric cars by HP or KW?
HP is just mechanical energy KW is electrical energy (mechanical and other) both are valid - conversion is .747 so yes car has total 960HP of which 160 is electric by a 120Kw motor ...
Jan 04, 2017 | Green Living
Is this for real
Solar generators produce electricity which is proportional to how much money you have.
Jan 24, 2016 | Solar Electrical Supplies
I have a PowerBack generator. It runs but does not produce electricity. How can I test it?
by plugging in a AC lamp if it lights up it is producing electricity. Suggest looking for circuit breaker on generator as possible cause of problem.
May 25, 2015 | Electrical Supplies
How does a basic metal detector work?
The simplest type of metal detector contains an oscillator which produces a current through a coil which in turn creates a magnetic field. If a piece of electrically conductive metal is close to the coil, it will produce an electric field of its own which is then measured and detected by the metal detector.
Jan 10, 2013 | Retail Supplies
How to increase efficiency of outflow electrical heaters without increase in electricity.
You are actually stuck right where you are, a electric heater is 100% effecient! 100% of the heat that it produces is put into the area where the heater is located.
A gas furnace will like 70 to 95 %, because part of the heat produced goes up the flue pipe.
I electric there is no waste, it is just the cost of the electricity required to run it.
The are other options, such as a heat pump, that are used to reduce the electric bill.
Have a great Day!
Sincerely,
Paul
Mar 31, 2010 | Heating & Cooling
Homelite generator model # LR 5500 not producing electricity
I have the same unit and same problem.
I have lost my owners manual. Did you figure out what needs to be done to correct the no output issue.
Mar 07, 2010 | Electrical Supplies
Wolf 800 generator. Engine will run but very electrical power is
is the engine running at the correct speed
3000 rpm to produce 50hz
3600 rpm to produce 60hz
Mar 06, 2010 | Electrical Supplies
Generator stopped producing electricity
if the generator has been sitting for a while you might have to excite the magnets to start producing power. plug in a reversible drill and with the generator running turn the drill in the reverse direction by hand while holding the trigger in the forward position.
Mar 24, 2009 | Yamaha 4500 Watt Electric Start Generator...
Honda Eb 3500 Generator Logo
27 people viewed this question
Top Honda Electrical Supplies Experts
John Trevino
Are you a Honda Electrical Supply Expert? Answer questions, earn points and help others
