Question about Malibu Intermatic Inc. ML300RTW 300-Watt Power Pack with Timer and Ground S
Can you run two seperate lighting systems with the Malibu 300 RTW
3 Suggested Answers
  • 128 Answers
SOURCE: Can you hook up two 12 gauge cables to the power
Hello yes you can the Important thing to remember here is not to exceed the wattage that the transformer puts out.
Add up the wattage of each bulb that you are running and ensure that you do not exceed 300 watts.
for example a 300 watt transformer could drive
a. 10 - 30 watt bulbs
b. 20 - 15 watt bulbs
c 75 - 4 watt bulbs
Its also ok to mix bulb wattage for example I use 10 watt bulbs in the fixtures in the front of the house but also power 4 20watt spotlights from the same transformer.
Hope that helps
Posted on Feb 26, 2010
gotgeek2
  • 565 Answers
SOURCE: I have a malibu ml200rt that won't work can I
Yes, you can replace the ML200RT with the ML300TW without a problem, and you will have an extra 100 watts for more lights if you want.
Posted on Nov 29, 2010
I have a Malibu 300 watt ML300rtw, timer goes until it reaches "on" pin then stops. if i manually turn timer, i hear click and lights go on - they turn off no problem. pins are not broken. what next?
Sounds like the mechanical timer assembly likely has never been lubricated, You may use a lightweight oil, such as WD-40, to lubricate the timer mechanism.
May 09, 2015 | Malibu ML300RTW - Low Voltage Power Pack...
I replaced an old Malibu 300 watt powerpack with a new digital 300 watt Malibu power pack and when I turn it on it runs for about a miniut and then shuts down. I have 15 11watt light on it, the same as the...
300 watt power pack should have 300 watt load.
You have 165 watt load.
Copy following link for general tips to get Malibu power pack to last longer.
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
Problem might be the photo eye.
http://waterheatertimer.org/images/Malibu-8100-9045-01-large.jpg
Rotate manual dial to ON position and see if lights turn ON.
Keep in mind the digital power pack has photoeye that is light sensitive, and must be exposed to dark light to activate.
For timed functions. Rotate manual dial until it points at timer. Press clock set function button, and use up-down buttons to set current time. Press timer ON button, and then use up-down to set ON timer. Then press timer OFF button , and use arrow keys to set OFF time.
This product has 1 year limited warranty, contrast with old-type analog power pack with 5-year warranty.
Malibu does not even post a manual on their site, which might have troubleshoot section to illuminate why your system has problem,
http://malibu.brinkmann.net/customer_service/owners_manuals.aspx
Nov 29, 2012 | Hardware & Accessories
Malibu 8100-0300-01
Promoters should include useful information. Not just air-head fluff.
Copy following link for actual useful do-it-yourself information such as warranty, troubleshoot, operation tips, manuals.
Aug 21, 2012 | Hardware & Accessories
My Malibu ML 300 RTW has stopped working, but I can hear the timer. No lights come on, though.
Sounds like the transformer died which isn't uncommon. One cause is overloading the circuit (too many lights) figure out the total wattage by adding the bulb watttage usually 11 by the amount of lights you have. I would buy a transformer with around 200 Watts higher than you need to allow for expansion and the transformer wont have to "work" as hard.
Aug 28, 2011 | Intermatic Malibu 300W Power Pack...
How u do a cheat code i mean whats a cheat code on smackdown vs raw 09 HUH!
Hi and welcome to FixYa
Passwords Unlockable CodesCheat Codes to input under options to unlock the following, the easy way: (Note: Alternate CODE's are case sensitive) Alternate CODEs to input under Options>Cheat Codes -
Effect Password Play as Boogeyman BoogeymanEatsWorms!! Play as Jillian Hall PlayAsJillianHallSvR Play as Layla UnlockECWDivaLayla09 Play as Snitsky UnlockSnitskySvR2009 Play as Tazz UnlockECWTazzSvR2009 Play as Vince McMahon VinceMcMahonNoChance Unlock Alternate Attire for Chris Jericho AltJerichoModelSvR09 Unlock Alternate Attire for CM Punk CMPunkAltCostumeSvR! Unlock Hornswoggle as a Non-Playable Manager HornswoggleAsManager Unlock Rey Mysterio Alternative Costume BooyakaBooyaka619SvR Unlock Ric Flair FlairWoooooooooooooo Unlock the Saturday Night Main Event Arena SatNightMainEventSvR Unlocks Curt Hawkins & Zack Ryder Ryder&HawkinsTagTeam
Unlockables Road To WrestleMania UnlockablesJust remember that every time you see something like "condition: to unlock bonus....." or something of that nature - it will be an unlockable
Unlockable How to Unlock Brothers of Destruction entrance In Undertaker's RTW make Finley bleed on week 8 CAS Moveset 1 In Batista/Rey's RTWM have Batista win the Royal Rumble, Rey lose to Edge at NWO, and then have Rey lose the tag titles against Morrison and Miz. CAS Moveset 2 In Batista/Rey's RTWM have Rey win the Royal Rumble, Batista lose to Edge at NWO, and then have Batista lose the tag titles against Morrison and Miz. Cena and Tony's Military Vehicle Entrance Complete Cena's Road to Wrestlemania. Code video for CAS Call out Mr.Kennedy at nWO in Jericho's RTWM. Then bust Kennedy open the week before WresteMania. Evolution Theme Song, Entrance video, And Trio entrance HHH RTW: Make sure Orton wins at No way out, And go on to beat him and shawn at wrestlemania Gauntlet Match During Cena's RTW defeat Mr. Kennedy in under 2.5 minutes on week 12 Generic Code Animation for CAE During Jericho's RTW, make Kennedy bleed on week 12 Generic IE Animation Set 2 Play as Triple H, and pin Edge in Week 1. Hornswoggle as non-playable manager On the second week of Undertaker's RTW, defeat Finley in less time than it took you to beat Santino Masked Man Beat Road to Wrestlemania with Chris Jericho. Mr. McMahon Finish Rey & Batista's RTWM. Old Jericho Model In Jericho's RTW, defeat Jeff Hardy without using a finisher on week 6 Rey Mysterio's Alternate Costume Play as Batista/Rey, and pin John Morrison in a Tag Team match. Santino Zombie When you get the choice in, Undertaker's RTW, face for the lader match Santino. Then beat him, win next week, then lose to Rey Mysterio the next week Saturday Night Main Event Arena Perform a finisher on all 3 opponents in your 2-on-3 tag match (must help partner beat edge for belt at NWO) on Batista/Mysterio's RTWM Snitsky In Cena's RTW, make MVP bleed on week 11 Special WrestleMania Jeep Entrance for CAE Complete Cena's RTW The Boogeyman Beat Road to Wrestlemania with The Undertaker. Tony Unlock "Tony" by going through John Cenas Road to Wrestlemania. UNLOCK CAS moveset #3 Whilst doing HHH RTW near the start UNLOCK CM Punk Alt. Attire Whilst doing CM Punk's RTW - In the second week, put Jeff Hardy through a table. UNLOCK DX Alt. Attire Whilst doing HHH RTW - In special ref match you play as referee, make sure Shawn Michael's is victorious and then go on to defeat him at WrestleMania. UNLOCK DX Entrance Whilst doing HHH RTW - Pedigree Randy Orton 3 time's to unlock UNLOCK Jillian Hall Whilst doing HHH RTW - Win Tag Match 3rd week of Feb UNLOCK Layla Whilst doing CM Punk's RTW - Defeat Big Daddy V at No way out, in 2 and a half minutes. UNLOCK Locker Room Whilst doing CM Punk's RTW - Pin John Morrison in an triple threat in March to unlock a new Backstage Brawl UNLOCK Ric Flair Whilst doing HHH RTW - In special ref match you play as referee, make sure Orton is victorious UNLOCK Tazz Whilst doing CM Punk's RTW - Complete CM Punk's Road To WrestleMania UNLOCK Tribute to the Troops Arena Whilst doing John Cena's RTW - Make MVP submit at the Tribute to the Troops arena. UNLOCK Zack Ryder & Curt Hawkins During the Mysterio/Batista RTW spear edge twice WCW Brand and Title Belt Complete the challenge for week three, while on Chris Jericho's Road to Wrestlemania story. Zombie Finlay Model Help Mysterio beat Zombie finlay in Taker's RTW
Hope this information was helpful
Sincerely,
aDynamite.
Mar 10, 2011 | THQ WWE Smackdown Vs Raw 2009
I have a malibu ml200rt that won't work can I replace with malibu ml 300 rtw. Thanks
Nov 29, 2010 | Malibu ML300RTW - Low Voltage Power Pack...
I just bought all new lights (5) for my Malibu ML300 RTW. This has been working great for the last 3-4 years. I ran new wire and cannot get these lights to work. I can hear the transformer humming, so I...
Be sure that the wire is connected to terminals "A" and "B". The "C" terminal is not used. Sometimes you have to squeeze the connectors on the lights pretty hard to get them to make good contact. Also, try connecting one of the old lights just to see if it works.
Sep 05, 2010 | Intermatic Malibu 300W Power Pack...
Can you hook up two 12 gauge cables to the power pack of the ML 300 RTW transformer. Power cable would run in different directions. Thank you Joe
c 75 - 4 watt bulbs
Hope that helps
Feb 26, 2010 | Malibu ML300RTW - Low Voltage Power Pack...
Malibu Intermatic Inc. ML300RTW  300-Watt Power Pack with Timer and Ground S Logo
Top Malibu Hardware & Accessories Experts
Gene Haynes
Scott Jelt
Scott Jelt
jdthefixer
Are you a Malibu Hardware and Accessory Expert? Answer questions, earn points and help others
