Question about Garmin GPS
Garmin nuvi 2598 touch screen is frozen cannot do anything with it
Screen froze while on route. cannot update on computer and cannot switch off
  • 23 Answers
SOURCE: Touch screen not working on garmin nuvi 670
Has this been solved? Hold power switch to right for about 30 seconds then follow on screen help to recalibrate screens
Posted on Jun 12, 2009
  • 18 Answers
SOURCE: garmin 660 locked up / frozen
Resetting the device merely resets the power connection, on some devices there is a reset to manufacturer defaults on settings, but not your stored data. Working with GPS's 40 hours a week I constantly have to use the reset button when they lock up. Just press it in for a few seconds then if it doesn't power back up just hit the power button and everything should be fine.
Posted on May 09, 2008
  • 638 Answers
SOURCE: Broken Garmin GPS Nuvi 300 Touch Screen
I know of this site where your screen can be replaced.
http://www.sharc.net/nuvi_LCD_repair.htm
Posted on Jan 08, 2009
sharcnet
  • 2130 Answers
SOURCE: Garmin nuvi 660 touch screen froze? How to fix?
please see this link. read about non-responsive touchscreens.
http://www.sharc.net/gps_LCD_repair.htm
- Jim
Posted on May 12, 2010
SOURCE: My Garmin Nuvi 660 touch screen is frozen. I've
Sounds like your firmware needs updated. Just go to Garmin’s website then downloads and update your firmware. As long as there is no screen damage but just touch screen not working that will fix it. An easy test is to take out the battery and if the unit works for second then freezes you just need to update firmware. Turn off unit plug into computer via usb cable and do firmware update, that easy!!!! Hope that helps?
Posted on Aug 22, 2010
Frozen screen with Garmin
Try resetting it, otherwise leave it on for over a week until it's completely flat then try again
Feb 01, 2014 | Garmin nuvi 1390T Car GPS Receiver
Frozen just tried to update and froze up brand new
I would suggest you reset the unit,if that doesn't solve the problem, then you will have to update your garmin nuvi, I think its out of date and needs to be updated. Follow the procedures below on how to update your garmin nuvi:
1. Plug one end of the USB cable into your GPS and the other end into your desktop or laptop computer. The GPS device will load the appropriate driver automatically, and a message on your GPS tells you that it is connected to your computer via USB.
2. Open your Internet browser of choice and type in the following web addres: "http://www8.garmin.com/support/collection.jsp?product=999-99999-27 "
3. Download the appropriate version of the software for your computer (Windows or Apple) and Install the WebUpdater by following the wizard (accept defaults).
4. Click "Start," "Programs," "Garmin" and " WebUpdater" to update your firmware and your maps. Periodically check and make sure your software is current.
Also, in case you don't know how to reset your garmin nuvi, you can follow the steps below: There are two types of reset;
Performing a Standard Reset
1. Slide the power switch all the way to the left (with the Nuvi's screen facing you).
2. Hold the switch in the position for at least eight seconds.
3. Push the switch to the right to power the Nuvi back on.
Performing a Factory Reset
1. Turn your Nuvi off by sliding the power switch to the left.
2. Press your finger against the bottom right corner of the touchscreen. Hold your finger in this position.
3. Slide the power switch to the right to turn the Nuvi back on. Continue to hold you finger against the screen until you see the factory reset prompt. Tap "Yes" to perform the factory reset.
Good luck
Dec 26, 2011 | Magellan GPS
Garmin froze with a "Map Update Notice" the screen
The unit isn't frozen. If you tap the power button you will hear it beep and change screens. What has happened is your touchscreen has failed. This is a common problem. Your touchscreen needs replaced. If you want some troubleshooting info, please see this link. There is just too much info to retype here:
- Jim
Mar 20, 2011 | Garmin Nuvi 660 GPS Receiver
My Garmin Nuvi 660 touch screen is frozen. I've tried to reset it with the switch on the back. I've tried connecting it to my computer to reset it. Powering on and off don't work.
Aug 16, 2010 | Garmin Nuvi 660 GPS Receiver
My Garmin Nuvi 1390 has frozen on the 'loading maps' page I turned the unit on holding down the bottom right hand corner clicked yes when asked do I really want to erase all user data. What if the device...
Take care.
Jul 04, 2010 | Garmin nuvi 1390T Car GPS Receiver
Garmin nuvi 660 froze up.
This is not caused by an update. Please check your unit's serial # to see if it starts with a "12P", "14V" or "143". If so, these units have a specific touchscreen that can fail even without physical damage to the glass or screen. The only way to resolve it is to replace the touchscreen & glass. You will not lose any of your data. The unit is not frozen and you can verify it by quickly pressing the on/off button. If you hear a beep, it's not locked up. You touchscreen has failed and won't accept any input. Please see this link:
- Jim
Apr 10, 2010 | Garmin Nuvi 660 GPS Receiver
The screen on my Garmin Street Pilot C340 is frozen
I read the manual. There is a reset button underneath the plastic cover surrounding the screen (pry off w/ your thumb) -- push the reset if the power can't be turned off otherwise.
Oct 01, 2009 | Garmin StreetPilot c340 GPS Receiver
Garmin Nuvi 660 touch screen freezes up. Soft
I sat on the phone for 30 minutes waiting for Garmin support when my Nuvi suddenly had no touch screen response. They had me delete a file on the device (with it hooked to my computer) then reboot and it went thru a touch screen alignment and it worked.
Sadly, it has frozen again and I don't recall the file (it had been a GCD file in all caps, that is all I know and I don't see a file in all caps any more). I will be calling support tomorrow.
My take is that it *is* a firmware thing *and* there is some way to reset the firmware.
May 01, 2009 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 670 has frozen and will not switch off. I have held down the power switch for ages and this has no effect. Just got a locked screen of where it froze.
with the garmin off, hold down the right bottom of the screen and turn the garmin on, it will then ask you if you want to perform a hard reset. Choose yes and that should fix your problem.
Jul 17, 2008 | Garmin Nuvi 660 GPS Receiver
GPS Logo
490 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
