Question about Marantz SR5006
Turns off automatically
Marantz sr 5006 turns off by itself.
    Genius:
  • Marantz Master
  • 1,054 Answers
Probably have a short in the amp section that needs to be repaired.
Posted on Nov 20, 2013
SOURCE: Marantz sr 500 going to "protect" mode when on.
Change the audio amplifiers IC´s because are on short circuit
Posted on Oct 02, 2008
tech48
  • 624 Answers
SOURCE: marantz sr 4200
This is an indication of some bad solder connections on one of the boards. It could be the power supply board, amp board, or the digital board. I would like to be more specific, but this is not a common problem with those symptoms. Bad solder connection are a common problem and can cause many different unusual symptoms. Unless you have excellent soldering skills, it would be best to let a service center repair this for you. This is a very good receiver and is well worth getting fixed. If you have excellent soldering skills and are willing to take a chance on fixing it yourself you could save yourself some money, but be aware that if you make even one mistake while soldering, you could easily cause much more damage than you started with. Some of the components that may need to be resoldered are surface mounted IC's that are very difficult to resolder and if you have never done this before it is not a good idea to start learning how to solder on such a nice receiver.
Let me know if you need any further help.
Dave
Posted on Oct 27, 2008
SOURCE: Marantz SR 7200
It is likely that the PA stage has developed an offset voltage in the output stage. The faulty amplifier channel can be found by progressively disconnecting the collectors of the of the power transistors until the protection fault disappears. Once the faulty channel is found the the cause of the offset has to be traced to the faulty transistor or resistor. Don't forget that if you can smell smoke or burning then there are likely to be components(esp transistors) that have been damaged by the fault.
I had a Luxman unit that destroyed 5 transistors in the output stage that was due to an open .5W resistor in the driver stage.
Good luck.
Posted on Mar 29, 2009
  • 3 Answers
SOURCE: my Marantz sr 4001 receiver has no output. Is
my friend has the same problem with an SR 4001. the tech said it was an internal fuse soldered to the board. the display showed an error code that clued in the tech of the problem. I am trying to find the fuse on the board, and trying to get a value(Volts-amps) of the fuse
Posted on Jul 28, 2010
palaboy
  • 5807 Answers
SOURCE: marantz sr 5001 turns on but no sound
Answer lies on page 48 of your
Marantz SR 5001 Manual
If problem is not resolved, it may needs servicing.
Posted on Aug 24, 2012
Receiver turns off after it has played for a few minutes. I reset the light and it will run again for a while and then turns off.
There are a few possible causes:
1. Your receiver is broken.
2. One of your speakers has a short in it.
To tell which, disconnect all your speakers at the back of your Marantz, and turn it on. Does it stay on? If yes, then check your speaker wires and speakers one at a time for normal volume...
Dec 11, 2015 | Marantz Sr 6001 Receiver
Green screen
Try to reset to your Marantz to factory settings, or try the newest Firmware. :)
Jan 21, 2014 | Marantz Audio Players & Recorders
Reset Marantz sr5006 to factory settings
Hold the 'display' and 'zone select' buttons, then press power. Display should blink all segments. Let go of buttons, and your good to go
Jan 22, 2013 | Marantz Audio Players & Recorders
Marantz sr 5001 turns on but no sound
Aug 23, 2012 | Marantz SR5001
Do have an idiots guide as to how to wire up the SR-4200 to a TV
I will interperate this as:
"So you want to play sound through your Marantz SR-4200?"
You need to clarify what sort of system setup you have, however i will put down a few ways to wire this up to your TV.
If you have a Set-top-box that gets the TV Channels, that is where the sound comes from. If you have a TV that plugs straight into the wall, you will have to get the sound from the TV. Grab a RCA Stereo cable - (White and Red heads, if you don't know what they look like, Google it).
If you are unclear about this, i have tried to make a diagram down the bottom to explain how this is to work. What you will do is Take the sound from the Set-Top-Box or TV and reroute it into your fantastic Marantz SR-4200.
1. Plug Red Plug into the the Red Slot, and White into the White on the back of your set-top-box or TV Out (if you get it around the wrong way, the speakers will be reversed.)
2. Plug the other end of the cable into the back of your Marantz SR-4200 in the TAPE input or VHS input as they are analog signal inputs. Turn on Marantz SR-4200 and turn it onto Tape or Vhs (depending on where you plugged it in).
[Set-Top-Box or TV out] >-------> into >------> [Marantz SR-4200]
If you still don't get it, then try searching You-Tube for a guide "Plug Tv into Stereo". I myself couldn't turn up anything useful
Mar 09, 2010 | Marantz SR-4200 Receiver
I need the remote control code numbers for the SR-18 so I can turn it on with my Direct TV remote.Do you know what they are?
the best thing to do is a code search per the directv manual and hope the Marantz powers off when you find the code.
If it turns off, you have won half the battle. Save the code and try turning the Mar back on.
The issue is that these universal satellite remotes are very limited on there funtionality with audio systems.
Keep in mind that if you find a code that turns it on & off, you will probably be limited volume only. If you get those three functions, you are very happy and call it done.
Hope this helps.
This goes for all sounds systems and not only Marantz.
Jan 19, 2010 | Marantz SR-18EX Receiver
The receiver is turning itself off - i.e back to standby.
If you don't use the remote control is it okay? If so, tear apart your remote control, use a Q-tip to clean all the lines in the circuit board where the rubber contacts touch. Then make sure that the rubber buttons don't have any 'gunk' on them that are making them stick. Clean the rubber pad with a qtip with dishsoap. Dry well, put back together and see if she works. Report back on your success. Good luck.
Dec 29, 2009 | Marantz SR-7200 Receiver
What is the error POW 5 on a marantz sr 7500
I have a POW 5 failure on a marantz sr 7500. Anybody know how to fix?
Jun 02, 2009 | Marantz SR-7400 Receiver
Marantz SR 7200
Most often it is due to improper speaker loading. In other words, it needs to have from 4 to 8 ohms speaker load and you wired your speakers in parallel when they should have been wired in series. What would have been an 8 ohm speaker load in series, turns into a 2 ohm load when in parallel. And with dual voice coil speakers you just compound the problem. And don't even get me started on bridged outputs.
Anyway that is what usually causes an amp to fry. Good luck.
Aug 03, 2008 | Marantz SR-7000 Receiver
Marantz SR5006 Logo
95 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
