Question about Casio Privia Px-130 Px130 88 Key Digital Stage Piano Nu
Casio px-130 keyboard problem
Key is stuck in an up position. we cannot figure out how to open the keyboard to fix the key.
SOURCE: Casio Privia keyboard PX-100
There are a number of issues that could cause this, the most likely culprit is the power supply, when I say power supply I mean the internal power supply,
This means that you have already obtained a good "known to work" AC to DC power supply, and tested it on your keyboard to see if that is the problem.
If you have completed this step, then your next step is to test your unit with batteries only, if the keyboard works, then you know your problem, is internal to the keyboard.
There are two issues to check, before proceeding please read the following note.
 (a note here for those who have no experience working with internal electronics)
If you have no experience working with internal electronics I would not recommend, opening your keyboard.
Two reasons, one, will void warranty if it still is under warranty.
secondly, you could accidently cause more damage to the unit.
Now if you are still reading, and feeling confident, you know that as a child you have dissembled many many electronic devices, just to see how they work.
If you do decide to open the box, disconnect the power supply to the unit including any batteries.
open the box and locate the power on button, clean using a Dielectric cleaning agent, can be obtained at most electronic specialty stores.
clean the power button, may work but doubtful, usually the switch itself is usually bad, there is a way to test the switch, however, that is beyond the scope of this answer, if you are following this you will most likely have the knowledge to do this.
The second and more challenging issue will be the internal power supply to the keyboard, or the interface that connects to your ac to dc converter.
This can be much more trickier, and I wont go into it here.
If you test your power switch determine that it is good then you should consider getting the unit serviced by a technician.
If you examine the boards, (electronic circuit boards,) and notice burned, connections, (darker than other circuits) then most likely it will not be worth trying to fix.
Hope this helps somewhat, if nothing else, take this print out to your local service dealer, and that will help in getting your keyboard repaired,
Delete this part, before taking this to your dealer,
Most electronic products can be easily fixed with a power switch, or power supply, however, many dealers will not tell you this and give you an estimate of fixing the unit that far exceeds the actual cost of repair,
an example, in a local TV repair shop, a friend brought in a wide screen Plasma HD TV, quoted repair, $654.00  problem,
power supply, actual cost, $75.00 my friend ordered the part online and with the help of a friend installed the new power supply returning his unit to full functionality.
So beware,
Posted on Mar 05, 2008
  • 5603 Answers
SOURCE: My casio ct670 ToneBank keyboard isn't making much sound
Check that you don't have old batteries in the unit. Also that the auto power down is not activated.
If using a power adapter make sure it is the RIGHT one, both in polarity and current rating.
Posted on Sep 22, 2009
Testimonial: "Sorta helpful. How do I check for auto power down activation? Thanks for responding so soon. I'm not using batteries and used the original ac adapter."
  • 5603 Answers
SOURCE: I have a Casio Privia PX-320. The left side keys
Check that the front of the keys is not hitting the lower plastic case front. If they hit it, then you need to disassemble the case partly and see what has shifted. It is ALSO possible that something has caaaused the aftertouch sensor to move out of position and it is hitting the keys early. ANY of these conditions needs to be addressed before damage is done.
Posted on Dec 01, 2009
  • 1137 Answers
SOURCE: Casio Privia PX-120 cannot be connected to Reason or FL
When you are using midi the sounds from your keyboard aren't sent anywhere. What happens is control messages are sent over the midi cable from midi out to midi in on the other device which must have midi sounds on it (in your case the sound card) to make any sounds. The messages can be things like note on/of or pitch bend etc. If you want to send messages to produce a result on your laptop and still here something you can loop the messages by running from midi out on the device end ( your laptop) back to midi in on your keyboard. A much better explanation is available here:http://www.indiana.edu/~emusic/etext/MIDI/chapter3_MIDI.shtml I also signed up to this site (its free) that has great people and lots of info:http://www.recordingreview.com/ I recommend downloading Killer Home Recording setting up which at this time is also free and has the best advice you could want in it. I'd also recommend checking out Reaper which is comparable to Reason, Cubase or Protools. If this helps please let me know.
Posted on Jan 21, 2010
ic0729
  • 212 Answers
SOURCE: Need replacement key set for Casio LK-110
You would need to call casio for such parts or go to a part store which by googling it you can find the parts for this unit.
Posted on Mar 16, 2010
C key is sunken down. The hammer action counterbalance isn't working properly
Check it again. It may have something dragging on the key, maybe something sticky like soda or juice residue. You can also try swapping out the key with another C or F key that is less used. Good luck!
Sep 24, 2016 | Casio Privia PX150 Digital Piano
How to reset?
factory reset Procedure.
Turn the keyboard off then press and hold the TONE and FUNCTION buttons while you turn on
Aug 04, 2014 | Casio Privia Px-130 Px130 88 Key Digital...
How can I do an internal factory reset for my Privia PX-130?
Turn the Keyboard off the press and while holding down the [TONE] AND [FUNCTION] buttons power on the keyboard. Wait until all reset is done.
Aug 22, 2013 | Casio Privia Px330 Px-330 88 Key Digital...
I have a casio privia px-130, and I'm trying to use it as a MIDI on FL Studio, but it won't show up in FL Studio. Is there a driver that I have to download?
Check the midi channel. It needs to sync to FL Studio. Channel settings you'll need to look up in the privia manual...can be laborious - but worth it in the end :)
Apr 19, 2013 | Casio Privia Px-130 Px130 88 Key Digital...
A key can't raise up
The unit will have to be opened and the key restored to the normal position. Most have a spring, sometimes a leaf type that holds the key up and locked in. When opening the unit care must be used as there are ribbon cables between the halves of the cover.
Aug 16, 2011 | Casio Privia Px-130 Px130 88 Key Digital...
Can i tune the privia 130
Refer to page E22 in your user manual. Please note that the default pitch is crystal controlled and quite accurate, but if you need to detune it you can do so as well as changing the temperment.
Jul 03, 2011 | Casio PX 130 Privia 88 Key Digital...
Casio Privia px 130 One of the keys (e4) sometimes playes at full velocity even when pressed lightly. It happenes vary regularly which means I can no longer rely on the key playing softly. It is...
One of the two contacts for that key is not working. This could be dirty or damaged contact. They use a conductive rubber pills that the key presses against circuit board traces. One contact makes before the other and this is how velocity is sensed. Unless you are adept at this repair, I would recommend you take it in for repair. Chances are any part cost is negligible... mostly labor to open and access the contacts for cleaning. Clean ONLY with 99% isoprophyl alcohol and Q TIps... VERY GENTLY.
Jul 02, 2011 | Casio Privia Px-130 Px130 88 Key Digital...
When I connect my Privia PX-130 to my computer (and Logic) it works perfectly but if I connect the audio out (via line out) at the same time, the audio sounds dreadful, even if I'm not going through the...
I SUSPECT that the USB connection is ECHOING the data, causing multiple generators to be active. Those extra ones then are mixed into the line out of the keyboard. In your PC, make sure the echo setting is turned off, OR disable the sending out of audio via the USB. Alternatively, DISABLE MIDI/USB incoming to the keyboard.
Jan 21, 2011 | Casio Privia Px-130 Px130 88 Key Digital...
Casio Privia Px-130 Px130 88 Key Digital Stage Piano Nu Logo
50 people viewed this question
Top Casio Music Experts
Ben Armstrong
Piyal Perera
Piyal Perera
Are you a Casio Music Expert? Answer questions, earn points and help others
